09-07-2011 12:41 PM - edited 03-07-2019 02:05 AM
Hi all,
I had a very disappointed experience today during the planned upgrade on my 2960 to IOS version 12.2(58)SE2 after business hours. We have a small office with 3x 2960 and a couple of 2950. There is a single 2960 called as the "central" as its the STP root, and most other switches are directly connected to the central. The remaining switches are conected to one of the switches conneting to the central.
I tested the aforementioned IOS on 2x 2960 las t week, but did not upgrade the central one. The 2x switches ran fine for a week, so I decided to upgrade the central one: basically it was a disaster. After the restart, the central became immediately unavailable via SSH (though admin IP pingable). I connected to the console, and realized that even console does not work, as I received the error message: "Low memory", and the console session could not be started. I restarted the switch once again (had to cut the power) and this time I managed to connect via the serial: the free memory was approx 2 MB, though its was over 5 MB if running 12.2(55)SE1. After 1-2 mins, free memory decreased down to 1.8 megs. SSH was still not functioning. At this time, fearing of a sudden memory leak during the night, I had to rollback to the previous version.
My config is quite simple: RSTP root, DHCP snooping, 1 LACP etherchannel, only 5x VLANs with VTP server, MOTD and BANNER (yeah I know its a risky feature since the previous IOS) I wonder what can be the problem here?
I have attached the running config of the central 2960 (removed some sensitive entries)
10-03-2011 12:38 PM
At least the 58SE2 release notes has been updated last week, added this issue as an open caveat.
Although I find "funny" that 2 trunk ports and 5 VLANs configured mean "too much" in cisco terminology.
10-03-2011 02:01 PM
From what I was told, the 15.0(1)SE wasn't really tested thoroughly.
10-05-2011 06:21 AM
LOL, why am I not surprised...?
10-22-2011 11:58 AM
Do you know any planned date to release a fixed version? I expect it should fall into the quarterly 2960 IOS update (its about time in the coming days), I really need it. 55SE is causing frequent STP topology changes / temporary blockings I experience it at least a couple of times per week, and this new 58SE seriously fails for the already known reason.
10-22-2011 12:20 PM
Hi Richard,
There are no regular quarterly updates for 2960.There will be maintenance build for 15.0(1)SE soon.I don't have the exact date right now.
10-22-2011 05:22 PM
Wooo-hooo!
11-03-2011 11:23 AM
Can you give an estimated release date (like in 2 weeks, or a month?)
11-03-2011 02:24 PM
How does March 2012 sound to you?
11-04-2011 12:36 AM
Very bad
12-04-2011 09:08 PM
12-15-2011 04:43 AM
Has this (15.0.1SE1) been pulled back by Cisco, as I cannot see it listed on the download page under 2960, I can only see the 6 months old 15.0.1SE.
12-15-2011 02:04 PM
Looks like it's been pulled. I can't find this version any more (across the board).
12-16-2011 12:28 AM
poor quality assurance kicks back :-|
12-16-2011 07:19 PM
I created a TAC Case. It's confirmed. 15.0(1)SE1 has been pulled because they found something sinister.
12-19-2011 06:13 PM
15.0(1)SE1 is now back Richard. This is a totally re-built file to 15.0(1)SE1 which is ALSO called 15.0(1)SE1.
So you need to re-download this IOS from Cisco, overwrite the old one with the same filename and re-upload (and reload) your switch.
