09-07-2011 12:41 PM - edited 03-07-2019 02:05 AM
Hi all,
I had a very disappointed experience today during the planned upgrade on my 2960 to IOS version 12.2(58)SE2 after business hours. We have a small office with 3x 2960 and a couple of 2950. There is a single 2960 called as the "central" as its the STP root, and most other switches are directly connected to the central. The remaining switches are conected to one of the switches conneting to the central.
I tested the aforementioned IOS on 2x 2960 las t week, but did not upgrade the central one. The 2x switches ran fine for a week, so I decided to upgrade the central one: basically it was a disaster. After the restart, the central became immediately unavailable via SSH (though admin IP pingable). I connected to the console, and realized that even console does not work, as I received the error message: "Low memory", and the console session could not be started. I restarted the switch once again (had to cut the power) and this time I managed to connect via the serial: the free memory was approx 2 MB, though its was over 5 MB if running 12.2(55)SE1. After 1-2 mins, free memory decreased down to 1.8 megs. SSH was still not functioning. At this time, fearing of a sudden memory leak during the night, I had to rollback to the previous version.
My config is quite simple: RSTP root, DHCP snooping, 1 LACP etherchannel, only 5x VLANs with VTP server, MOTD and BANNER (yeah I know its a risky feature since the previous IOS) I wonder what can be the problem here?
I have attached the running config of the central 2960 (removed some sensitive entries)
09-17-2013 10:06 AM
I see Cisco has updated the 15.0(2) software to SE4. Has anyone tried it and if so, is it working better?
I had been running the 15.0(2)SE2 since April with no apparant problems until about three weeks ago. Then I started experiencing the problem listed in this thread with a few of the 2960's we have. We also have seen where connections randomly drop out, meaning you can be surfing the Internet, then it just stops and IE (or whatever browser) says it can't connect to the host. You usually can wait a few seconds, hit refresh and the page loads. The connections are individual computers, not a whole switch at a time. One computer can be surfing just fine but the one next to it times out. I've been pulling my hair out trying to find the answer to this one.
09-17-2013 07:49 PM
All my 2960/G/S are running 15.0(2)SE4.
All my 3750/G/E/X and 3560/G/E/X are running 12.2(55)SE8.
I am currently testing 15.2(1)E on a 3560CG (compact switch). Will be testing this version on the 2960S.
15.2(1)E is only valid for newer switches. This version will no longer be supported on legacy 3750/G, 3560/G and 2960/G.
So far, I am pleased at the performance of 15.0(2)SE4 on the 2960/G/S. I will not be using this version on Cat 3K as I've been burnt before because our Cat6K are all distribution while our 2960/G/S are the access layer switches.
09-25-2013 06:34 AM
Today we ran into the same problem on 2960S-48FPS-L in Stack configuration. IOS: 15.2(1)E
ssh/telnet not available via console "%% Low on memory; try again later"
another 2960s stack is running on 15.0(1)SE2 uptime: 1 year, 25 weeks, so far no problems
Leo, how long you are running on 15.0(2)SE4 with 2960s? Looking for a release which is more stable than both installed
09-26-2013 03:10 PM
Tested 15.0(2)SE4 since the day it was released and all of my 2960/G/S and 3560CG are running this version. Do not see any issues with performance or CPU.
09-26-2013 08:55 AM
I've just tried upgrading one of my WS-C2960-24TT-L to 15.0(2)SE4 and process memory used was at 84% straight away. So I'm rolling back to 12.2(55)SE8 with its 69% memory used.
09-27-2013 04:37 PM
Jonathan,
I'm keen to learn/know what you've got in your 2960 (non-S or non-X, I presume?). All of my switches are currently running PoE and 802.1x. Either one can sometimes cause CPU to spike.
I'm not saying 12.2(55)SE8 is bad, on the contrary I've always been recommending people load the 12.2(55)SE5 and later IOS because this is one of the most well-behaved IOS versions I've ever come across.
Back to your issue, do you have SNMP traps enabled? If you do, do you have ALL SNMP traps enabled?
09-30-2013 12:41 AM
Hi Leo,
Yes a WS-C2960-24TT-L, not an S or X. There's no POE, 802.1x or SNMP traps configured. What I'm seeing with 15.0(2)SE4, and to a lesser extent 12.2(58)SE2, is not a spike in CPU use. Rather it's an increase in the amount of processor pool memory.
Here's the proccess memory from a 2960 running 12.2(55)SE8:-
Processor Pool Total: 22324560 Used: 15462024 Free: 6862536
I/O Pool Total: 4194304 Used: 2493704 Free: 1700600
Driver te Pool Total: 1048576 Used: 40 Free: 1048536
And here from a 2960 running 12.2(58)SE2:-
Processor Pool Total: 21586420 Used: 17291128 Free: 4295292
I/O Pool Total: 4194304 Used: 2375332 Free: 1818972
12.2(58)SE2 uses over 80% of the available processor memory and seems to have a memory leak which causes this to grow further over time. 12.(55)SE8 uses a more reasonable 69%.
Jonathan
09-30-2013 12:57 AM
Hi Jonathan,
If you have a spare switch running the 15.0(2)SE4 IOS, can you post the outcome of the command "sh proc cpu | ex 0.00" and "sh proc mem | ex 0.00"?
I would like to see the functions causing this. Again, this is odd.
09-30-2013 05:21 AM
Leo, here is one of mine for an extra reference. This is from a WS-C2960-48TT-L running 15.0(2)SE4.
CPU utilization for five seconds: 19%/0%; one minute: 22%; five minutes: 22%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
4 12817472 669631 19141 0.31% 1.11% 0.83% 0 Check heaps
72 6408920 77899014 82 0.47% 0.48% 0.35% 0 Fifo Error Detec
85 1734802 43343846 40 0.15% 0.17% 0.14% 0 HLFM address lea
87 1057856 43573689 24 0.31% 0.10% 0.06% 0 HLFM address ret
130 135747765 38124082 3560 13.11% 13.89% 14.26% 0 Hulc LED Process
139 793281 304962 2601 0.15% 0.08% 0.06% 0 HQM Stack Proces
Processor Pool Total: 21505748 Used: 18086080 Free: 3419668
I/O Pool Total: 4194304 Used: 2384460 Free: 1809844
PID TTY Allocated Freed Holding Getbufs Retbufs Process
0 0 23584456 6303228 14152864 0 0 *Init*
0 0 12180 282956 12180 0 0 *Sched*
0 0 16994536 16145860 813224 3795303 1341026 *Dead*
0 0 0 0 394440 0 0 *MallocLite*
1 0 254912 242652 19420 0 0 Chunk Manager
2 0 232 232 4160 0 0 Load Meter
3 0 0 0 10032 0 0 Connection Mgr
4 0 4688 232 11668 0 0 Check heaps
5 0 91420708 94799096 42192 60305908 62229899 Pool Manager
6 0 0 0 7160 0 0 DiscardQ Backgro
7 0 232 232 7160 0 0 Timers
8 0 0 0 4160 0 0 WATCH_AFS
9 0 196211500 196254948 7620 0 0 crypto sw pk pro
10 0 0 0 25160 0 0 Crash writer
11 0 340 0 7500 0 0 Exception contro
12 0 174206580 174160148 53592 0 0 ARP Input
13 0 4108 4108 7160 0 0 ARP Background
14 0 0 0 7160 0 0 AAA_SERVER_DEADT
15 0 0 0 13160 0 0 Policy Manager
16 0 47476 59500 44776 0 8840 Entity MIB API
17 0 0 0 7160 0 0 IFS Agent Manage
18 0 0 0 7160 0 0 IPC Event Notifi
19 0 0 0 7160 0 0 IPC Mcast Pendin
20 0 0 0 7220 0 0 IPC Dynamic Cach
21 0 0 0 7160 0 0 IPC Session Serv
22 0 0 0 7160 0 0 IPC Zone Manager
23 0 0 0 7160 0 0 IPC Periodic Tim
24 0 0 0 7160 0 0 IPC Deferred Por
25 0 0 0 7160 0 0 IPC Process leve
26 0 1688 0 8848 0 0 IPC Seat Manager
27 0 0 0 7160 0 0 IPC Check Queue
28 0 0 0 7160 0 0 IPC Seat RX Cont
29 0 0 0 7160 0 0 IPC Seat TX Cont
30 0 0 0 7160 0 0 IPC Keep Alive M
31 0 0 0 7160 0 0 IPC Loadometer
32 0 72540 72540 7160 0 0 PrstVbl
33 0 232 232 13160 0 0 XML Proxy Client
34 0 0 0 7160 0 0 Dynamic ARP Insp
35 0 0 0 7160 0 0 ARP Snoop
36 0 232 232 7160 0 0 SMART
37 0 232 232 7160 0 0 GraphIt
38 0 0 0 7224 0 0 Critical Bkgnd
39 0 38352 288 19304 0 0 Net Background
40 0 0 0 13160 0 0 IDB Work
41 0 34936 232 13160 20304 0 Logger
42 0 232 232 7160 0 0 TTY Background
43 0 96644 84496 59352 0 0 IF-MGR control p
44 0 0 0 7160 0 0 IF-MGR event pro
45 0 0 0 7160 0 0 Net Input
46 0 232 232 7160 0 0 Compute load avg
47 0 2892 0 7160 1692 0 Per-minute Jobs
48 0 43304 26400 27064 0 0 Per-Second Jobs
49 0 0 0 7160 0 0 AggMgr Process
50 0 0 0 7160 0 0 Transport Port A
51 0 0 0 7160 0 0 HC Counter Timer
52 0 0 0 7160 0 0 SFF8472
53 0 232 232 7160 0 0 DownWhenLooped
54 0 0 0 7160 0 0 HULC ACL Tcam Me
55 0 0 0 7160 0 0 HRPC lpip reques
56 0 232 232 7160 0 0 HLPIP Sync Proce
57 0 0 0 7160 0 0 HRPC EnergyWise
58 0 0 0 7160 0 0 HRPC actual powe
59 0 0 0 7160 0 0 PSP Timer
60 0 0 0 7160 0 0 HULC QM Tcam Mem
61 0 34858284 34858284 7160 0 0 Authenticate Pro
62 0 0 0 7160 0 0 HULC PBR Tcam Me
63 0 368232 15779268 377792 0 0 EEM ED ND
64 0 4556 0 14716 0 0 EEM ED Identity
65 0 4556 0 14716 0 0 EEM ED MAT
66 0 7812 0 7812 0 0 HL2MCM
67 0 7820 0 7820 0 0 HL2MCM
68 0 0 0 7160 0 0 HRPC asic-stats
69 0 0 0 4160 0 0 HRPC hsm request
70 0 4088 0 17312 0 0 Stack Mgr
71 0 889176 142984 499632 0 0 Stack Mgr Notifi
72 0 9952 232 16880 0 0 Fifo Error Detec
73 0 1224 1224 4160 0 0 Adjust Regions
74 0 0 0 7160 0 0 hrpc -> response
75 0 0 0 7160 0 0 hrpc -> request
76 0 65848 532 7160 0 0 hrpc <- response
77 0 0 0 7160 0 0 HRPC hcomp reque
78 0 656 232 7160 0 0 HULC Device Mana
79 0 108 108 7160 0 0 HRPC hdm non blo
80 0 176 176 7160 0 0 HRPC hdm blockin
81 0 0 0 13160 0 0 HIPC bkgrd proce
82 0 232 232 7160 0 0 Hulc Port-Securi
83 0 0 0 7160 0 0 HRPC hpsecure re
84 0 0 0 7160 0 0 HRPC hlfm reques
85 0 52168948 232 65300 0 0 HLFM address lea
86 0 232 232 7160 0 0 HLFM aging proce
87 0 232 232 7160 0 0 HLFM address ret
88 0 0 0 7160 0 0 HRPC hulc misc r
89 0 0 0 7160 0 0 HULC Tcam Memory
90 0 0 0 13160 0 0 HVLAN main bkgrd
91 0 232 232 7160 0 0 HVLAN Mapped Vla
92 0 232 232 7160 0 0 Vlan shutdown Pr
93 0 65740 0 7160 0 0 HRPC vlan reques
94 0 0 0 7160 0 0 HULC VLAN REF Ba
95 0 0 0 7160 0 0 HRPC ilp request
96 0 0 0 7160 0 0 HULC PM Vector P
97 0 0 0 7160 0 0 HPM Msg Retry Pr
98 0 3018596 3477228 7540 0 0 SpanTree Helper
99 0 11338840 9542944 21036 0 0 hpm main process
100 0 232 232 7160 0 0 HPM Stack Sync P
101 0 0 0 25160 0 0 HRPC pm request
102 0 232 232 7160 0 0 hpm counter proc
103 0 0 0 7160 0 0 HRPC pm-counters
104 0 0 0 7160 0 0 hpm vp events ca
105 0 0 0 7160 0 0 HRPC hcmp reques
106 0 0 0 7160 0 0 HACL Queue Proce
107 0 0 0 7160 0 0 HRPC acl request
108 0 232 1460 61160 0 0 HACL Acl Manager
109 0 0 0 7160 0 0 HRPC backup inte
111 0 0 0 7160 0 0 HRPC cdp request
112 0 0 0 7160 0 0 HULC CISP Proces
113 0 0 0 7160 0 0 HRPC lldp reques
114 0 0 0 7160 0 0 HRPC dot1x reque
115 0 10044 0 17204 0 0 HULC DOT1X Proce
116 0 0 0 4160 0 0 HRPC system mtu
117 0 0 0 7160 0 0 SMI MSG Retry Pr
118 0 0 0 10160 0 0 HRPC Smart Insta
119 0 0 0 7160 0 0 HRPC sdm request
120 0 232 232 7160 0 0 Hulc Storm Contr
121 0 232 232 7160 0 0 HSTP Sync Proces
122 0 0 0 7160 0 0 HRPC stp_cli req
123 0 0 0 7160 0 0 HRPC stp_state_s
124 0 232 232 7160 0 0 S/W Bridge Proce
125 0 0 0 7160 0 0 HRPC hudld reque
126 0 0 0 7160 0 0 HRPC vqpc reques
127 0 0 0 7160 0 0 HRPC aim request
128 0 0 0 13160 0 0 HCEF ADJ Refresh
129 0 0 0 7160 0 0 HRPC hled reques
130 0 232 232 10160 0 0 Hulc LED Process
131 0 0 0 13160 0 0 HL3U bkgrd proce
132 0 0 0 7160 0 0 HRPC hl3u reques
133 0 0 0 61160 0 0 HL3U PBR bkgrd p
134 0 0 0 7160 0 0 HL3U PBR n-h res
135 0 0 0 7160 0 0 HRPC dtp request
136 0 0 0 7160 0 0 HRPC show_forwar
137 0 0 0 7160 0 0 HRPC snmp reques
138 0 0 0 7160 0 0 HULC SNMP Proces
139 0 3754693148 3753092060 8996 933984 0 HQM Stack Proces
140 0 2435742844 2435725492 61160 10152 0 HRPC qos request
141 0 0 0 7160 0 0 HRPC span reques
142 0 0 0 7160 0 0 HRPC system post
143 0 0 0 7160 0 0 Hulc Reload Mana
144 0 0 0 7160 0 0 HRPC hrcli-event
145 0 232 232 10160 0 0 image mgr
146 0 232 50063844 7160 0 0 PI MATM Aging Pr
147 0 71328 0 78488 0 0 Switch Backup In
148 0 0 0 7160 0 0 MMN bkgrd proces
149 0 4506624 5480564 189996 0 0 Auth Manager
150 0 0 0 7160 0 0 AUTH POLICY Fram
151 0 843236 841652 8744 0 0 Dot1x Mgr Proces
152 0 12025296 9410104 35208 0 0 802.1x switch
153 0 0 0 7160 0 0 802.1x Webauth F
154 0 880 232 7808 0 0 DTP Protocol
155 0 0 0 7160 0 0 EAP Framework
156 0 0 0 7160 0 0 EAP Test
157 0 0 0 7160 0 0 HRPC dai request
158 0 0 0 4160 0 0 HULC DAI Process
159 0 0 0 7160 0 0 HRPC ip device t
160 0 0 0 7160 0 0 HRPC ip source g
161 0 0 0 7160 0 0 HULC IP Source g
162 0 524 232 7452 0 0 UDLD
163 0 216 0 7376 0 0 Port-Security
164 0 232 232 10160 0 0 IP Host Track Pr
165 0 0 0 7160 0 0 Link State Group
166 0 0 171716 7160 0 0 VMATM Callback
167 0 232 232 7160 0 0 CMD HANDLER
168 0 216 0 13376 0 0 CEF switching ba
169 0 216 0 4376 0 0 ADJ NSF process
170 0 0 0 7160 0 0 HRPC sisf reques
171 0 0 0 7160 0 0 HULC SISF Proces
172 0 0 0 7160 0 0 HULC SISF Source
173 0 232 232 7160 0 0 AAA Server
174 0 0 0 7160 0 0 AAA ACCT Proc
175 0 49352 0 56512 0 0 ACCT Periodic Pr
176 0 0 0 7172 0 0 AAA System Acct
177 0 0 0 7160 0 0 Auth-proxy AAA B
178 0 0 0 7160 0 0 IP Admin SM Proc
179 0 32553284 2072 562512 263952 0 CDP Protocol
180 1 41492 35112 31412 0 0 Virtual Exec
181 0 0 0 7176 0 0 Critical Auth
182 0 232 232 7160 0 0 AAA Dictionary R
183 0 0 0 7160 0 0 DHCP Snooping
184 0 0 0 7160 0 0 DHCP Snooping db
185 0 7944 2672 18432 0 0 IP ARP Adjacency
186 0 33012 0 40172 0 0 IP ARP Retry Age
187 0 65371536 3204 33596 0 0 IP Input
188 0 0 0 7160 0 0 ICMP event handl
189 0 232 232 10160 0 0 IP ARP Track
190 0 0 0 7160 0 0 IPv6 ping proces
192 0 13204 864 38404 0 0 SMI Director DB
193 0 0 15773108 7160 0 0 SMI CDP Update H
194 0 680 0 25840 0 0 SMI Backup Proce
195 0 3892 232 10820 0 0 SMI IBC server p
196 0 372 0 13532 0 0 SMI IBC client p
197 0 4884 232 17812 0 0 SMI IBC Download
198 0 3416728 232 7376 0 0 Spanning Tree
199 0 5044 0 12204 0 0 Spanning Tree St
200 0 232 232 7160 0 0 Ethchnl
201 0 0 65347896 13160 0 0 TCP Timer
202 0 74820 0 13160 0 0 TCP Protocols
203 0 0 0 7160 0 0 Socket Timers
204 0 292486968 292306240 60612 76140 0 HTTP CORE
205 0 232 232 7160 0 0 Cluster L2
206 0 0 0 7160 0 0 Cluster RARP
207 0 13131112 13130288 7984 0 0 Cluster Base
208 0 6188 68 19280 0 0 CEF background p
209 0 216 0 13420 0 0 fib_fib_bfd_sb e
210 0 0 0 10160 0 0 IP IRDP
211 0 0 0 7160 0 0 RARP Input
212 0 448 232 7376 0 0 Dot1x Supplicant
213 0 448 232 7376 0 0 Dot1x Supplicant
214 0 448 232 7376 0 0 Dot1x Supplicant
215 0 0 0 7160 0 0 MAB Framework
216 0 0 0 7160 0 0 HRPC dhcp snoopi
217 0 0 0 7160 0 0 HULC DHCP Snoopi
218 0 1292352 3358960 8108 0 0 IGMPSN L2MCM
219 0 0 0 7160 0 0 IGMPSN MRD
220 0 0 0 7160 0 0 IGMPSN
221 0 0 0 7160 0 0 IGMPQR
222 0 14852 232 11748 0 0 L2TRACE SERVER
223 0 1292724 3357740 8384 0 0 MLDSN L2MCM
224 0 0 0 7160 0 0 MRD
225 0 0 0 7160 0 0 MLD_SNOOP
226 0 0 0 13160 0 0 Routing Topology
227 0 26384 7208 19244 0 0 CEF: IPv4 proces
228 0 216 0 7376 0 0 ADJ background
229 0 216 0 13384 0 0 ADJ resolve proc
230 0 1120 0 14280 0 0 IP RIB Update
231 0 216 0 13376 0 0 Collection proce
232 0 11805460 11798216 8536 2268 0 NIST rng proc
233 0 232 232 10160 0 0 static
234 0 0 0 10160 0 0 IPv6 RIB Event H
235 0 13733220 13733220 7160 0 0 QoS stats proces
236 0 0 0 7160 0 0 SNMP Timers
237 0 1936 232 8864 0 0 TPLUS
238 0 0 0 7032 0 0 HCMP sync proces
239 0 0 0 7160 0 0 EPM MAIN PROCESS
240 0 232 232 7160 0 0 AAA Cached Serve
241 0 232 232 7160 0 0 LOCAL AAA
242 0 232 232 7160 0 0 ENABLE AAA
243 0 232 232 7160 0 0 LINE AAA
244 0 1936 232 8864 0 0 LDAP process
246 0 0 0 7160 0 0 HRPC hl2mcm igmp
247 0 0 0 7160 0 0 HRPC hl2mcm mlds
248 0 0 0 7160 0 0 HRPC x_setup req
249 0 0 0 7160 0 0 crypto engine pr
250 0 0 0 13160 0 0 encrypt proc
251 0 219248 184236 48968 0 0 Crypto CA
252 0 0 0 13160 0 0 Crypto PKI-CRL
253 0 4884 232 11812 0 0 VTP Trap Process
254 0 232 232 25160 0 0 ASP Process Crea
255 0 232 232 7160 0 0 DHCP Security He
256 0 0 0 7160 0 0 HCD Process
257 0 0 0 7160 0 0 HRPC cable diagn
259 0 3140160 6387500 7160 0 0 PM Callback
260 0 232 232 7160 0 0 dhcp snooping sw
261 0 0 220 7160 0 0 DiagCard1/-1
262 0 232 728580 7160 0 0 AAA SEND STOP EV
263 0 0 0 13160 0 0 Test AAA Client
264 0 0 0 7160 0 0 Syslog Traps
266 0 216 0 7376 0 0 Online Diag EEM
267 0 85072 0 92292 0 0 EEM Server
268 0 11476 1720 16916 0 0 EEM Policy Direc
270 0 4556 0 14716 0 0 EEM ED OIR
271 0 4556 0 14716 0 0 EEM ED Timer
272 0 693476 693476 13160 0 0 Syslog
273 0 232 232 4160 0 0 STP FAST TRANSIT
274 0 232 232 4160 0 0 CSRT RAPID TRANS
275 0 66196 16772 61988 0 0 Call Home proces
276 0 4556 0 14716 0 0 EEM ED Test
277 0 4556 0 14716 0 0 EEM ED Config
278 0 4556 0 14716 0 0 EEM ED Env
279 0 4556 0 14716 0 0 EM ED GOLD
280 0 31116 6428 17244 2340 0 VLAN Manager
281 0 0 0 7160 0 0 Call Home Timer
282 0 47548 0 15632 0 0 SSH Event handle
284 0 1506733408 1491135436 28592 507600 0 IP SNMP
285 0 52460132 0 13180 0 0 PDU DISPATCHER
286 0 449321228 516509596 13176 0 0 SNMP ENGINE
287 0 11200 232 24172 0 0 IP SNMPV6
288 0 0 0 13184 0 0 SNMP ConfCopyPro
289 0 0 0 13220 0 0 SNMP Traps
290 0 63932 17724 52000 0 0 NTP
20462460 Total
10-01-2013 02:40 PM
Thanks for the output, Aubrey.
I can't find anything wrong with your CPU utilization. CPU that low gives me the impression your switch doesn't have any config in it. That's a good sign, by the way!
10-02-2013 05:55 AM
Leo, you are correct. There are no vlan's, etc set up on this switch. Here is an output for sh proc cpu with a little more utilization:
CPU utilization for five seconds: 32%/0%; one minute: 29%; five minutes: 30%
4 14118619 740918 19055 0.45% 0.82% 0.76% 0 Check heaps
12 2325948 4950179 469 0.15% 0.18% 0.15% 0 ARP Input
61 2527294 22262 113525 4.13% 0.81% 0.44% 0 Authenticate Pro
72 28039253 82132498 341 1.37% 0.99% 0.94% 0 Fifo Error Detec
85 7740513 46535001 166 0.30% 0.25% 0.27% 0 HLFM address lea
87 5553862 46759142 118 0.30% 0.25% 0.22% 0 HLFM address ret
130 250039996 42432539 5892 19.32% 19.75% 20.38% 0 Hulc LED Process
140 1843723 678975 2715 0.15% 0.08% 0.08% 0 HRPC qos request
180 67 120 558 0.91% 0.09% 0.02% 1 Virtual Exec
186 4994872 46534740 107 0.15% 0.16% 0.16% 0 IP ARP Retry Age
187 4632559 14793098 313 0.15% 0.25% 0.26% 0 IP Input
259 1284353 9533753 134 0.15% 0.04% 0.04% 0 PM Callback
In my monitoring, I haven't seen it above 37%. Here is that one:
CPU utilization for five seconds: 37%/0%; one minute: 35%; five minutes: 32%
39 740083 494930 1495 0.15% 0.07% 0.03% 0 Net Background
72 28040571 82139912 341 0.47% 0.66% 0.85% 0 Fifo Error Detec
85 7740962 46539171 166 0.15% 0.22% 0.25% 0 HLFM address lea
87 5554156 46763363 118 0.31% 0.15% 0.18% 0 HLFM address ret
130 250079837 42436520 5893 30.71% 25.06% 21.84% 0 Hulc LED Process
187 4633144 14795705 313 0.31% 0.32% 0.28% 0 IP Input
10-02-2013 03:18 AM
Hi Leo,
Sorry for the delay. Had trouble tracking down a spare switch. The output you requested is below. This is for a
WS-C2960-24TT-L with default config and just one interface active (so I could update the firmware).
Switch#sh proc cpu | ex 0.00
CPU utilization for five seconds: 4%/0%; one minute: 4%; five minutes: 1%
Switch#sh proc mem | ex 0.00
Processor Pool Total: 21505748 Used: 16838900 Free: 4666848
I/O Pool Total: 4194304 Used: 2419708 Free: 1774596
0 0 22370528 5917764 13784140 0 0 *Init*
0 0 12180 172432 12180 0 0 *Sched*
0 0 15665136 15088332 581768 3602595 1182914 *Dead*
1 0 6588 1544 13748 0 0 Chunk Manager
4 0 4716 232 11696 0 0 Check heaps
5 0 3396 3396 10556 2196 2196 Pool Manager
9 0 503532 506956 7692 0 0 crypto sw pk pro
12 0 0 0 7160 0 0 ARP Input
13 0 3712 3712 7160 0 0 ARP Background
16 0 21668 5472 23356 0 0 Entity MIB API
32 0 232 232 7160 0 0 PrstVbl
39 0 36156 288 17156 0 0 Net Background
41 0 26260 232 39188 15228 0 Logger
42 0 25664 232 7496 0 0 TTY Background
43 0 94916 84496 57624 0 0 IF-MGR control p
47 0 0 0 7160 0 0 Per-minute Jobs
48 0 35912 27456 18616 0 0 Per-Second Jobs
61 0 3736 3736 7160 0 0 Authenticate Pro
63 0 368232 1588 377792 0 0 EEM ED ND
66 0 7784 0 7784 0 0 HL2MCM
67 0 7784 0 7784 0 0 HL2MCM
70 0 4088 0 17248 0 0 Stack Mgr
71 0 643660 139340 281928 0 0 Stack Mgr Notifi
72 0 5344 232 12272 0 0 Fifo Error Detec
73 0 1336 1336 4160 0 0 Adjust Regions
76 0 65848 436 7160 0 0 hrpc <- response
78 0 560 232 7160 0 0 HULC Device Mana
85 0 232 232 7160 0 0 HLFM address lea
98 0 2840 2508 7540 0 0 SpanTree Helper
99 0 2412 232 12340 0 0 hpm main process
104 0 0 0 7172 0 0 hpm vp events ca
108 0 232 1412 61160 0 0 HACL Acl Manager
139 0 546652 544816 8996 0 0 HQM Stack Proces
140 0 264360 264360 61160 0 0 HRPC qos request
146 0 232 232 7160 0 0 PI MATM Aging Pr
149 0 135632 10492 138300 0 0 Auth Manager
151 0 232 232 7160 0 0 Dot1x Mgr Proces
152 0 34912 4856 27804 0 0 802.1x switch
166 0 0 0 7160 0 0 VMATM Callback
177 0 0 0 7172 0 0 Auth-proxy AAA B
179 0 537656 300 545616 0 0 CDP Protocol
180 0 28508 22156 31448 0 0 Exec
185 0 1104 0 14264 0 0 IP ARP Adjacency
187 0 0 0 13160 0 0 IP Input
192 0 13204 236 38404 0 0 SMI Director DB
193 0 0 752 7160 0 0 SMI CDP Update H
198 0 1736 232 7376 0 0 Spanning Tree
201 0 0 0 13160 0 0 TCP Timer
202 0 0 0 13160 0 0 TCP Protocols
204 0 11860 0 22020 0 0 HTTP CORE
207 0 1504 968 7696 0 0 Cluster Base
208 0 6264 76 19348 0 0 CEF background p
218 0 1856 3648 8016 0 0 IGMPSN L2MCM
219 0 1264 1264 7264 0 0 IGMPSN MRD
222 0 14848 232 11744 0 0 L2TRACE SERVER
223 0 1820 3180 8404 0 0 MLDSN L2MCM
227 0 26384 7208 19252 0 0 CEF: IPv4 proces
229 0 216 0 13376 0 0 ADJ resolve proc
231 0 0 0 7160 0 0 HRPC hl2mcm igmp
232 0 0 0 7160 0 0 HRPC hl2mcm mlds
235 0 736 736 7160 0 0 QoS stats proces
246 0 216 0 13376 0 0 Collection proce
247 0 31780 30404 8536 0 0 NIST rng proc
251 0 221240 186220 48908 0 0 Crypto CA
259 0 12400 45256 7160 0 0 PM Callback
262 0 232 232 7160 0 0 AAA SEND STOP EV
267 0 85072 0 92232 0 0 EEM Server
269 0 0 0 4160 0 0 Rom Random Updat
272 0 3816 3816 13160 0 0 Syslog
275 0 66248 16772 62040 0 0 Call Home proces
280 0 29072 6428 28340 2340 0 VLAN Manager
282 0 8484 0 15640 0 0 SSH Event handle
19198748 Total
10-02-2013 04:47 AM
Jonathan,
I don't see anything suspicious either. CPU utilization is very low. You sure you have a config on this switch?
10-02-2013 05:00 AM
Hi Leo,
My issue isn't CPU utilisation, it's memory utilisation.
Here's the proccess memory running 12.2(55)SE8:-
Processor Pool Total: 22324560 Used: 14177896 Free: 8146664
I/O Pool Total: 4194304 Used: 2389856 Free: 1804448
And running 15.0(2)SE4:-
Jonathan
10-02-2013 03:34 PM
Processor Pool Total: 66575784 Used: 46250672 Free: 20325112
I/O Pool Total: 14680064 Used: 12279420 Free: 2400644Driver te Pool Total: 1048576 Used: 40 Free: 1048536
Above is mine from a stack of 4 2960S running 15.0(2)SE4 with PoE and 802.1x.
