1811 - Voice VLAN DHCP Problems
adamtodd16
Level 3
Level 3
I can't believe I am asking this, but I must be missing something. Setting up an 1811 in a lab environment (no WAN connection). Very basic configuration, but cannot seem to get DHCP working for phones. This device is standalone right now with no other devices connected (except 2 phones and a laptop).
Any help would be greatly appreciated. Config below:
Current configuration : 2864 bytes
version 12.3
hostname C1811-BaseCamp
boot-start-marker
boot-end-marker
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
no aaa new-model
ip subnet-zero
ip cef
ip dhcp excluded-address 10.96.16.1 10.96.16.49
ip dhcp excluded-address 10.96.16.91 10.96.16.255
ip dhcp excluded-address 192.168.16.1 192.168.16.49
ip dhcp excluded-address 192.168.16.91 192.168.16.255
ip dhcp pool DATA
   network 10.96.16.0 255.255.255.0
   default-router 10.96.16.254
   netbios-name-server 10.96.17.2
   domain-name cookeaqua.com
   dns-server 10.96.16.1 10.96.17.2 10.1.200.50
   lease 0 1
ip dhcp pool VOICE
   network 192.168.16.0 255.255.255.0
   default-router 192.168.16.254
   option 150 ip 192.168.16.240
   lease 0 1
no ip domain lookup
ip domain name cookeaqua.com
ip ssh version 2
ip inspect log drop-pkt
ip inspect name FIREWALL tcp
ip inspect name FIREWALL udp
ip inspect name FIREWALL ftp
ip inspect name FIREWALL fragment maximum 256 timeout 1
ip ips po max-events 100
no ftp-server write-enable
interface FastEthernet0
ip address dhcp
shutdown
duplex auto
speed auto
interface FastEthernet1
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet2
switchport access vlan 26
no ip address
spanning-tree portfast
interface FastEthernet3
switchport access vlan 16
switchport voice vlan 26
no ip address
interface FastEthernet4
no ip address
interface FastEthernet5
no ip address
interface FastEthernet6
no ip address
interface FastEthernet7
no ip address
interface FastEthernet8
no ip address
interface FastEthernet9
no ip address
interface Vlan1
no ip address
shutdown
interface Vlan16
ip address 10.96.16.254 255.255.255.0
interface Vlan26
ip address 192.168.16.254 255.255.255.0
interface Async1
no ip address
ip classless
ip route 0.0.0.0 0.0.0.0 10.96.16.250
no ip http server
no ip http secure-server
control-plane
line con 0
line 1
stopbits 1
speed 115200
flowcontrol hardware
line aux 0
line vty 0 4
login
end
9 Replies 9
cadet alain
can you do this:
logging buffered debug
no service timestamp debug
logging buffered 100000
do clear log
do debug ip dhcp server packet
shut/no shut the voice VLAN SVI and then
do sh log
post output here
Regards.
Alain
Benjamin Kools
Have you created the vlans themselves? Do a show vlan brief to ensure it exists, and show interface vlan 26 to verify that it is showing up, line protocol up.
adamtodd16
Level 3
Level 3
Hi Cadet - I will do some of the logging tomorrow morning when I am back in the lab.
Benjamin - the VLANs are fully created and active.
That is definitely quite odd then. Are dhcp addresses being assigned to the data vlan just fine? One thing you could test is put a port statically in the voice vlan - switchport access vlan 16 and just see if your laptop can get an IP out of the scope. I also notice you're running 12.3 code, do you have the ability to update to 12.4?
Ben
Hi Adam,
you should try to take out this line:
and verify first if the IP Phones get an IP in this way. Then you could assign a TFTP Server for the configs..
Alessio
Couple things with the config....
Make sure CDP is enabled. The phones use that to let the switch know it is a phone.
I do not see an IP Helper address for the Voice vlan and since the DHCP server IP address is in a different subnet you will need this.
In the DHCP config for the voice vlan I do not see thet domain name, dns servers, netbios server defined.
interface FastEthernet2 has VLAN 26 but it is set as access not voice.
interface FastEthernet8 does not have the voice vlan defined
Also does the phone get any IP address?
What model phone are you using?
Can you see the MAC addresses of the phones when you run show mac-add dyn
Are the PC connected through the phones or do the phones and PC's each have their own connection?
Mike
Okay - I made a poor assumption previously and have found the root of the problem.
When I have:
On a switchport, the voice vlan does not show ip on the port under vlan-switch.
If I only add switchport access vlan 26 to the port, then the phone gets DHCP on that VLAN.
So it appears to be an issue with having 2 vlans on the one switchport.
Any ideas?
You can have two vlans on the same port as long as one is access and the other is voice.
Did you make the correction I showed above? Also what about the questions I asked above?
Mike
Hi Mike,
I just completed an IOS upgrade on the device and all vlan assignments are now working correctly. The phone has received the correct vlan and dhcp information. All good now.
Thanks!
Adam
