1841 -> ZBF <> MailServer:IP, port 110,25 ?
mauric
hello dear prof!
i have running now in me little network a Mailserver, please i don't know
how to open the port 25,110 on me Cisco 1841 so that this Email-Server
with the static address in internal Network are reachable from the hole world.
i have configured a on 1841 Zone based firewall without DMZ Zone, but now,
i don't see no way to this. Can give me here any little help,please so that i can
do any static entry for example all traffic from 0.0.0.0 > 10.10.10.25 : 25, 110 allow
i have create picture of me idea.
thanks for your help!
Mauri
First you need some NATs:
ip nat inside source static tcp 192.168.1.xx 25 interfaceFastEthernet0/0 25
ip nat inside source static tcp 192.168.1.xx 110 interfaceFastEthernet0/0 110
Your zone based firewall is incomplete and not in use, so you don't need to do anything to make the NATs work.  You can take a look at one config wizard for a Cisco 897 to see how to build a complete working zone based firewall config.
http://www.ifm.net.nz/cookbooks/890-isr-wizard.html
9 Replies 9
Philip D'Ath
You will need to share your configuration for us to be able to suggest any changes.
Here are me running Conifg, thanks meny time for your Investigation.
best regards
Mauri
Please Gentlemans!
may I kindly wan't ask for a possible answer!
best regards
Mauri
Thanks 1000 ! for your Help
so me ZBF are not complet :-(, please are possible to give me material to read a lillte more about this, so are possible that me ZBF are running like a Firewall that are complet, and not only a half time shot......
i found on Cisco Homepage any books.... like 700 site, but are possible that here exist any smaler one for understabd this, i respect this feature, and iam a fan from this! so i will to learn and setup correctly, can you give me here any possible links help Help information in which direction i need to go, top amcomplish this.
Regards and thaks for your Help!
Mauri
try to open port 25,110 and 21, but i don't have success.
ip nat inside source static tcp 192.168.1.20 21 interface FastEthernet0/0 21
access-list 1 permit 192.168.1.0 0.0.0.255
access-list 110 permit tcp any host 192.168.1.20 eq ftp
access-list 110 permit ip any any
also trying:
ip nat inside source static tcp 192.168.1.20 21 PublicIP 21 extendable
but if scaning port 21, are closed, and no Connection available.
Mauri
Hello.
Please, i need to open port 21 from "Wan->Lan, site" on me Cisco 1841,
for any help i'am Happy
Mauri
You'll just need to add a single NAT like you did last time.
thanks for your answer
Yes, i have done, i add this NAT but without success ! port 21, 25, 110 still are closed
