07-18-2014 02:27 AM - edited 03-07-2019 08:06 PM
I would buy a 1911 series router with a lan EHWIC-D-8ESG module. I saw forums that this router does not support the communication ports between switches because it does not have the MGF (Multi Gigabit Fabric).
Could you please confirm?
Can we allow communication between vlans without FGM?
thanks, Mickael.
07-18-2014 05:33 AM
See table-4 in this link. For the 1900 series, the max number of vlans supported is 16.
http://www.cisco.com/c/en/us/products/collateral/routers/3900-series-integrated-services-routers-isr/data_sheet_c78-612808.html
07-21-2014 02:56 AM
But the problem doesn't in the max number of vlan supported by router. I would like to have confirmation about the possibility that communication between vlan is enable without MGF for the router 1911.
Mickael.
