1921 rack mount
siskotech
1921 router doesn't ship with rack mount kit.
How would cisco sugest mount this in the rack?
8 Replies 8
Leo Laohoo
1.4 Ordering Common Items Across Cisco 3900, 2900, and 1900 Series Routers
• 19-inch rack-mount brackets (for the Cisco 1921, you must order the rack-mount kit because it does not ship by default)
Ordering Guide:  Cisco Integrated Services Routers Generation 2
... and look under Table 16.
Hello,  I cannot find it on this table.
Table 16. Cables, Rack-Mount Brackets, Blank Faceplates, and FIPS Shields for Cisco 3900, 2900, and 1900 Series Routers
Ordering SKU
Description
CAB-CONSOLE-RJ45
Console Cable 6ft with RJ45 and DB9F (Both system and spare)
CAB-AUX-RJ45
Auxiliary Cable 8ft with RJ45 and DB25M (Both system and spare)
CAB-CONSOLE-USB
Console Cable 6 ft with USB Type A and mini-B connectors (Both system and spare)
ACS-3900-RM-23=
23 inch rack mount kit for Cisco 3925 - 3945EISR (only as spare)
ACS-2900-RM-23=
23 inch rack mount kit for Cisco 2911/2921/2951 ISR (only as spare)
ACS-2901-RM-23=
23 inch rack mount kit for Cisco 2901 ISR (only as spare)
SM-S-BLANK=
Removable faceplate for SM slot on Cisco 2900, 3900 ISR (only as spare)
SM-BLANK-KIT=
Blank faceplate for SM slot with divider on Cisco 2951 & 3925 (only as spare)
HWIC-BLANK=
Blank faceplate for HWIC/EHWIC slot on Cisco ISR (only as spare)
HWIC-BLANK-KIT=
Blank faceplate for HWIC slot with divider for Cisco1941 ISR (only as spare)
HWIC-SLOT-DIVIDER=
HWIC/EHWIC Slot Divider (Guide) for Cisco 1900, 2900, 3900 ISR (only as spare)
SM-SLOT-DIVIDER=
SM Slot Divider (Guide) for Cisco 2900, 3900 ISR (only as spare)
ACS-CF-COVER=
Compact Flash Cover (Guard) for Cisco 1900, 2900, 3900 ISR (only as spare)
FIPS-SHIELD-3900=
FIPS opacity shield for Cisco 3925 - 3945EISR
FIPS-SHIELD-2921=
FIPS opacity shield for Cisco 2921 ISR
FIPS-SHIELD-2951=
FIPS opacity shield for Cisco 2951 ISR
FIPS-SHIELD-2911=
FIPS opacity shield for Cisco 2911 ISR
FIPS-SHIELD-2901=
FIPS opacity shield for Cisco 2901 ISR
FIPS-SHIELD-1900=
FIPS opacity shield for Cisco 1905, Cisco 1921 ISR
Not sure why it is not on that table, but the part number is "ACS-1900-RM-19".
Hmmm ... Someone's taken the SKU out.  Don't know why.
Try Amazon
manuelmaiztegui
Why would Cisco not include the rack mount kit?  I find it insulting that I bought an expensive product and now I need to scramble to find a part that should be there.
Cisco don't treat your customers this way!
Because the 1921 is intended for very small SOHO deployments. It only has a sustained throughput rating of 15 Mbps. You typically would not be using a rack in a deployment that small, you would just stick it on a desk or a shelf.
Some folks do use it for other things though, which is why they made the rack mount kit. It's a separate item because it is not typical to need it.
I was told the 1921 is a replacement of the 1841 line and those used to come with the rack mount kit.  Are you saying the 1921 is a lower line than the 1841?
Thank you for the reply
The 1921 is a lower end model then the 1841. It has less sustained throughput then the 1841's 38 Mbps.
A proper replacement for the 1841 would be a 1941, though at this point you may want to consider going straight to a 4321, or a 4331.
