1941W Replacement
amar.patelDD
I know that the 1941W has gone EOL and the replacement is a standard 1941 with an external AP. Does the AP need to be autonomous?
Sandeep Choudhary
HI Amar,
The Cisco 1941 supports dual radios - 802.11 b/g/n and 802.11a/n and is capable of operating in both autonomous and unified modes.
http://www.cisco.com/en/US/prod/collateral/routers/ps10538/data_sheet_c78_556319.html
Hi Sandeep,
That's what I got from the data sheet also. There needs to be a controller of some sort if we are to use it in unified mode?
Amar
Hi Amar,
Yes, you need a controller in Unified Mode.
I think these are called as Embeded AP.
http://www.cisco.com/en/US/docs/wireless/controller/7.4/configuration/guides/lwap/config_lwap_chapter_0110.html
Also check this Thread:
https://supportforums.cisco.com/message/3737097
Regads
Dont forget to rate helpful posts.
