Hi all,
We have 2 WAN interfaces:
- FasterEthernet8 (DHCP assigned fixed 192.168.1.10), routed through 192.168.1.1
- Dialer1 (direct external IP Negotiaded address).
The default route 0.0.0.0 is set to Dialer1 and FastEthernet8 (with metric 254), so we can internet, but all goes through Dialer1.
Packets arriving from outside (from WAN to LAN) through Dialer1 are forwarded to the correct internal IP-address (for example port 443 should be forwarded to our local IP 192.168.39.4). Also, the return packet is correctly send back through Dialer1.
But... when a packet arrives through FastEthernet8, it's correctly NAT-translated to 192.168.39.4, however the return
packet from our internal server goes back through Dialer1, instead of FastEthernet8.
Here are some syslog-events:
*Oct 12 14:18:21.380 PCTime: NAT*: o: tcp (69.163.149.200, 47883) -> (192.168.1.10, 443) [36630]
*Oct 12 14:18:21.380 PCTime: NAT*: s=69.163.149.200, d=192.168.1.10->192.168.39.4 [36630]
*Oct 12 14:18:21.380 PCTime: NAT*: i: tcp (192.168.39.4, 443) -> (69.163.149.200, 47883) [5054]
*Oct 12 14:18:21.380 PCTime: NAT*: s=192.168.39.4->192.168.1.10, d=69.163.149.200 [5054]
As you can see, our server replies, but the packet is never sent out through 192.168.1.1.
Anybody an idea why? Thanks!
KR,
Peter
From your explanation, I understand that your default-route through Fastethernet 8 is with metric 254. So it is not there in routing table. So when return packet comes back via lan 1, it does trsnslation usign the existing ststic nat entry and send the packet via the dialer 1 route which is present in routing table
Hi Rajs,
Thanks for your reply, however I did try removing the metric, so both Dialer1 and FE8 are on metric 1, but in this case we can still internet from inside (although now it goes through FE8), but every port forward from outside->inside doesn't work anymore (neither to Dialer1 nor to FE8).
Maybe I should give some more details on the config. Here's part of it:
ip cef
interface FastEthernet8
description $ETH-WAN$
ip address dhcp
ip flow ingress
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface GigabitEthernet0
no ip address
ip flow ingress
duplex auto
speed auto
pppoe enable group global
pppoe-client dial-pool-number 1
interface Vlan1
ip address 172.31.255.1 255.255.255.0 secondary
ip address 192.168.39.1 255.255.255.0
ip nat inside
ip tcp adjust-mss 1452
interface Dialer1
ip address negotiated
ip mtu 1492
ip flow ingress
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication pap callin
ppp pap sent-username xxx password xxx
crypto map SDM_CMAP_1
ip nat pool MAIL 192.168.39.4 192.168.39.4 netmask 255.255.255.0 type rotary
ip nat inside source route-map COAX interface FastEthernet8 overload
ip nat inside source route-map FIBER interface Dialer1 overload
ip nat inside destination list Mail pool MAIL
ip route 0.0.0.0 0.0.0.0 Dialer1 track 1
ip route 8.8.4.4 255.255.255.255 FastEthernet8 192.168.1.1
ip route 8.8.8.8 255.255.255.255 Dialer1
ip access-list extended Mail
permit object-group Mail_Ports any any
ip sla 1
icmp-echo 8.8.8.8
timeout 1000
threshold 40
frequency 3
ip sla schedule 1 life forever start-time now
ip sla 2
icmp-echo 8.8.4.4
timeout 1000
threshold 40
frequency 3
ip sla schedule 2 life forever start-time now
track 1 ip sla 1 reachability
delay down 15 up 10
track 2 ip sla 2 reachability
delay down 15 up 10
access-list 100 remark CCP_ACL Category=16
access-list 100 permit ip 192.168.39.0 0.0.0.255 192.168.38.0 0.0.0.255
access-list 101 remark CCP_ACL Category=2
access-list 101 remark IPSec Rule
access-list 101 deny ip 192.168.39.0 0.0.0.255 192.168.38.0 0.0.0.255
access-list 101 permit ip 192.168.39.0 0.0.0.255 any
access-list 101 permit ip 192.168.40.0 0.0.0.255 any
access-list 101 permit ip 172.31.255.0 0.0.0.255 any
dialer-list 1 protocol ip permit
no cdp run
route-map COAX permit 10
match ip address 101
match interface FastEthernet8
route-map FIBER permit 10
match interface Dialer1
What I actually want is having Dialer1 as main internet route with FE8 as backup route (when Dialer1 drops), as well as accepting port-forwards from both interfaces, routing the answer from our server back the 'right' route... Is that possible?
Thanks again and kind regards,
Peter
