2511-RJ issue
amardeep.2007
I just started R&S lab and 2511 is not booting up.
It booted completely twice, I mapped two hosts to Async ports to test and saved config.
Now it stuck whcile booting. Please provide any pointers to resolve this issue. Thanks
System Bootstrap, Version 11.0(10c), SOFTWARE
Copyright (c) 1986-1996 by cisco Systems
2500 processor with 14336 Kbytes of main memory
%SYS-4-CONFIG_NEWER: Configurations from version 12.2 may not be correctly understood.
F3: 15535804+889700+1236752 at 0x3000060
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
IOS (tm) 2500 Software (C2500-IS-L), Version 12.2(15)T17, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2005 by cisco Systems, Inc.
Compiled Sat 13-Aug-05 15:26 by kehsiao
Image text-base: 0x0308038C, data-base: 0x00001000
cisco 2511 (68030) processor (revision M) with 14336K/2048K bytes of memory.
Processor board ID 12023833, with hardware revision 00000000
Bridging software.
X.25 software, Version 3.0.0.
1 Ethernet/IEEE 802.3 interface(s)
2 Serial network interface(s)
16 terminal line(s)
32K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read ONLY)
*Mar  1 00:00:10.983: %LINK-3-UPDOWN: Interface Ethernet0, changed state to up
*Mar  1 00:00:10.987: %LINK-3-UPDOWN: Interface Serial0, changed state to down
*Mar  1 00:00:11.355: %LINK-3-UPDOWN: Interface Serial1, changed state to down
*Mar  1 00:00:30.911: %LINEPROTO-5-UPDOWN: Line protocol on Interface Ethernet0, changed state to down
*Mar  1 00:00:34.775: %LINK-5-CHANGED: Interface Ethernet0, changed state to administratively down
*Mar  1 00:00:35.599: %LINK-5-CHANGED: Interface Serial0, changed state to administratively down
*Mar  1 00:00:35.807: %LINK-5-CHANGED: Interface Serial1, changed state to administratively down
*Mar  1 00:00:36.151: %SYS-5-CONFIG_I: Configured from memory by console
*Mar  1 00:00:36.691: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0, changed state to down
*Mar  1 00:00:39.383: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial1, changed state to down
*Mar  1 00:01:19.859: %SYS-5-RESTART: System restarted --
*Mar  1 00:01:19.867: %SNMP-5-COLDSTART: SNMP agent on host Router is undergoing a cold start
*Mar  1 00:01:19.995: %LINK-3-UPDOWN: Interface Virtual-Access1, changed state to up
*Mar  1 00:01:20.995: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access1, changed state to up
johnlloyd_13
Level 9
Level 9
2500s have already reached its EOL/EOS. Did you buy this on Ebay? Have you tried other IOS's?
It could be a hardware issue and it needs to be replaced.
Hello John,
I solved issue by clearing startup config.
-DP
