2600 Routing/NAT/DHCP Problem
aducey01
I really need to get this working soon, need to test a site to site vpn for work.
I'm connecting this to a home broadband connection and it's just not working right.  It looks to be natting, jusdging from the debugging, but the internal subnets are not able to ping out to the internet.
It's not a dns issue 'cause I can't ping the numeric ip's to google or yahoo either.
The routes are in the routing table.
I can ping www.yahoo from the router cli and ping the inside hosts.
boot system flash:c2600-adventerprisek9-mz.124-25d.bin
ip dhcp pool internal-client
   network 10.22.22.0 255.255.255.0
   dns-server 66.60.130.158
   default-router 10.33.33.1
   domain-name collabrotech
interface FastEthernet0/0
ip address dhcp
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
no clns route-cache
interface FastEthernet1/15
description LAN Subnet
switchport access vlan 22
spanning-tree portfast
interface Vlan1
no ip address
shutdown
no clns route-cache
interface Vlan22
ip address 10.22.22.1 255.255.255.0
no clns route-cache
ip route 0.0.0.0 0.0.0.0 dhcp
ip http server
no ip http secure-server
ip nat inside source list 1 interface FastEthernet0/0 overload
access-list 1 permit 10.33.33.0 0.0.0.255 log
access-list 1 permit 10.22.22.0 0.0.0.255 log
17 Replies 17
I see switch and router config here. so is there a router and a switch?
In any case Is ip routing enabled on the switch?
res
Paul
Kind Regards
Paul
you're on the right track.  It's a router with a switch module.  Once I enabled RIP on the 2600 and rebooted the little isp router, it came right up.  Apparently the little generic isp router is running rip and needed the same from my router to do dynamic nat.
This was quite the nose bleed.
Excellent,
Would you please rate if any of the assistance was useful.
res
Paul
Kind Regards
Paul
