2811 booting problem
salvador.menor
help me please. ;(
Upgrade ROMMON initialized
program load complete, entry point: 0x8000f000, size: 0xcb80
program load complete, entry point: 0x8000f000, size: 0x1866558
Self decompressing the image : ############################################################################################################################################### [OK]
Error : uncompressed image checksum is incorrect 0x24776BF8
        Expected a checksum of 0x247A0D18
*** System received a Software forced crash ***
signal= 0x17, code= 0x9, context= 0x80014da0
PC = 0x8000f0d4, Cause = 0x20, Status Reg = 0x3040a803
c2811 platform with 262144 Kbytes of main memory
Main memory is configured to 64 bit mode with ECC enabled
thank you
Julio E. Moisa
It could be originated by a corrupted image:
Corrupt software image At the time of bootup, a router can detect that a Cisco IOS software image is corrupt, return the compressed image checksum is incorrect message, and attempt to reload. In this case, the event is reported as a software-forced crash.
Error : compressed image checksum is incorrect 0x54B2C70A
        Expected a checksum of 0x04B2C70A
signal= 0x17, code= 0x5, context= 0x0
PC = 0x800080d4, Cause = 0x20, Status Reg = 0x3041f003
This can be caused by a Cisco IOS software image that has actually been corrupted during transfer to the router. In this case, you can load a new image onto the router to resolve the issue. [For a ROMMON recovery method for your platform, refer to ROMmon Recovery Procedure for the Cisco 7200, 7300, 7400, 7500, RSP7000, Catalyst 5500 RSM, uBR7100, uBR7200, uBR10000, and 12000 Series Routers.] It can also be caused by faulty memory hardware or by a software bug.
Reference: http://www.cisco.com/c/en/us/support/docs/routers/7500-series-routers/26145-crashes-swforced-troubleshoot.html
You can load a new image from Rommon (to enter to rommon, turn off the router, turn on again and press control + break or control + pause):
https://dataplumber.wordpress.com/2007/03/16/loading-ios-image-via-tftp-in-rommon/
I remember it select the F0/0 or G0/0 interface by default, so you could connect your computer (where tftp is installed) there, PC must has an IP address on the same network that router's IP.
If you are going to upgrade the device you should verify first the hardware requirements in order to avoid any issues.
Please rate the comment if it is useful
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Yashas Bhadoria
Download a new Router IOS image from cisco Website and then transfer it to your router and then boot.
