2821 NAT Issue
AndrewHaskell
Hello, I'm setting up a 2821 to act as the primary Router for a network of just over 100 devices. Upstream of this router is a Motorola Canopy serving as the gateway to the ISP's network. I don't have access to the Canopy, but I do know that is is operating simply as a modem and is not performing any routing functions. I have set up the 2821 with the following configuration file and can successfully ping botht the WAN and the LAN from it. However from any of the downstream devices I can only ping within the LAN, all WAN packets timeout. I've looked through many different config files on the internet and can't see what is causing my own to not function properly.
The settings from the ISP are as follows:
Public IP: 64.25.148.144
Subnet: 255.255.255.0
Next Hop: 64.25.148.1
DNS Server 1: 64.25.145.12
DNS Server 2: 64.25.146.12
Ouput of 'show ip route' :
Gateway of last resort is 64.25.148.1 to network 0.0.0.0
     64.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
S       64.0.0.0/8 [1/0] via 64.25.148.0
C       64.25.148.0/24 is directly connected, GigabitEthernet0/0
S*   0.0.0.0/0 [1/0] via 64.25.148.1
And here is my config file:
version 12.3
hostname CISCO-2821
boot-start-marker
boot-end-marker
enable secret 5 removed
enable password removed
no aaa new-model
resource policy
voice-card 0
no dspfarm
voice-card 1
no dspfarm
ip subnet-zero
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 10.1.10.1 10.1.10.150
ip dhcp excluded-address 10.1.10.251 10.1.10.254
ip dhcp pool main
   network 10.1.10.0 255.255.255.0
   default-router 10.1.10.1
   dns-server 64.25.145.12 64.25.146.12
   domain-name coth-intranet.local
   netbios-node-type b-node
ip dhcp pool default
ip name-server 64.25.145.12
ip name-server 64.25.146.12
no ip ips deny-action ips-interface
no ftp-server write-enable
no crypto isakmp ccm
interface GigabitEthernet0/0
ip address 64.25.148.144 255.255.255.0
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
no mop enabled
interface GigabitEthernet0/1
ip address 10.1.10.1 255.255.255.0
ip broadcast-address 10.1.10.255
ip nat inside
duplex auto
speed auto
interface Serial0/0/0
no ip address
shutdown
ip classless
ip route 0.0.0.0 0.0.0.0 64.25.148.1
ip route 64.0.0.0 255.0.0.0 64.25.148.0                    ----On a side note why can't I negate this line with 'no ip route 64.0.0.0 255.0.0.0 64.25.148.0' ?----
ip http server
no ip http secure-server
ip nat inside source list 7 interface GigabitEthernet0/0 overload
access-list 7 permit 10.1.10.0 0.0.0.254
control-plane
voice-port 1/0/0
voice-port 1/0/1
voice-port 1/0/2
voice-port 1/0/3
voice-port 1/0/4
voice-port 1/0/5
voice-port 1/0/6
voice-port 1/0/7
line con 0
line aux 0
line vty 0 4
password removed
login
scheduler allocate 20000 1000
end
AndrewHaskell
Well, I got this figured out from other sources, Cisco wildcard masks in the lone ACL should have been 0.0.0.255 instead of 0.0.0.254. Typo on my end that I failed to catch.
