2821 with NME-X-23ES-1G-P
benherman77
I can not get this etherswitch module to work with...I've had several people view my config and read numerous articles online.  So I'm turning to the Cisco community for help.  Currently I use my 2821 as my home router (setup is functioning correctly and I'm online) I can ping from router to switch module and vice versa...but I'm not able to connect any device to the module and have it pull an IP or access the LAN.  Can someone please explain my mistakes
Router#sh conf
Using 2117 out of 245752 bytes
version 12.4
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
dot11 syslog
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.172.0.1
ip dhcp pool Network
network 192.172.0.0 255.255.255.224
default-router 192.172.0.1
dns-server 8.8.8.8 8.8.4.4
domain-name Herman
ip dhcp pool Vlan
network 10.0.50.0 255.255.255.0
default-router 10.0.0.1
domain-name Herman
vpdn enable
voice-card 0
no dspfarm
archive
log config
hidekeys
interface GigabitEthernet0/0
description WAN Interface
no ip address
duplex auto
speed auto
no cdp enable
interface GigabitEthernet0/0.1
encapsulation dot1Q 201
pppoe enable group global
pppoe-client dial-pool-number 1
interface GigabitEthernet0/1
description LAN Interface
ip address 192.172.0.1 255.255.255.224
ip nat inside
ip virtual-reassembly
duplex full
speed 1000
no cdp enable
interface GigabitEthernet1/0
ip address 10.0.0.1 255.255.255.0
interface Dialer1
description WAN Dialer
ip address negotiated
ip mtu 1492
ip nat outside
encapsulation ppp
ip tcp adjust-mss 1452
dialer pool 1
dialer-group 1
no cdp enable
ppp chap hostname hermanben847@qwest.net
ppp chap password 0 H5PaUqT6
ppp ipcp dns request accept
ppp ipcp address accept
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer1
ip route 10.0.50.0 255.255.255.0 10.0.0.2
ip http server
no ip http secure-server
ip nat inside source list 10 interface Dialer1 overload
access-list 10 permit 192.172.0.0 0.0.0.31
access-list 10 permit 10.0.50.0 0.0.0.255
control-plane
line con 0
line aux 0
line 66
no activation-character
no exec
transport preferred none
transport input all
transport output lat pad telnet rlogin lapb-ta mop udptn v120 ssh
line vty 0 4
login
scheduler allocate 20000 1000
end
Router#
Switch#sh conf
Using 3695 out of 524288 bytes
! Last configuration change at 18:43:07 UTC Thu Apr 20 1905
! NVRAM config last updated at 18:43:08 UTC Thu Apr 20 1905
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname Switch
no aaa new-model
switch 1 provision NME-X-23ES-1G-P
vtp domain lab
vtp mode transparent
ip subnet-zero
no file verify auto
spanning-tree mode pvst
spanning-tree vlan 100 priority 24576
vlan internal allocation policy ascending
vlan 10
vlan 50
name network
vlan 100
name RouterVLAN
interface FastEthernet1/0/2
switchport access vlan 100
switchport mode access
interface FastEthernet1/0/3
interface FastEthernet1/0/4
interface FastEthernet1/0/5
interface FastEthernet1/0/6
interface FastEthernet1/0/7
interface FastEthernet1/0/8
interface FastEthernet1/0/9
interface FastEthernet1/0/10
interface FastEthernet1/0/11
interface FastEthernet1/0/12
interface FastEthernet1/0/13
interface FastEthernet1/0/14
interface FastEthernet1/0/15
interface FastEthernet1/0/16
interface FastEthernet1/0/17
interface FastEthernet1/0/18
interface FastEthernet1/0/19
interface FastEthernet1/0/20
interface FastEthernet1/0/21
interface FastEthernet1/0/22
interface FastEthernet1/0/23
interface FastEthernet1/0/24
interface GigabitEthernet1/0/1
interface GigabitEthernet1/0/2
interface Vlan1
no ip address
interface Vlan100
ip address 10.1.1.2 255.255.255.0
ip helper-address 10.0.0.1
ip classless
ip http server
control-plane
line con 0
line vty 5 15
end
Switch#
Reza Sharifi
Few things:
1-vlan 100 is configured on all switch ports as access mode. So, you do't need this command:
You can remove it from all ports.
2-Vlan 100 has an inteface on the switch with ip 10.1.1.2/24 but there is no corresponding interface on the router with an IP address in this segment.
3-There is no pool for segment 10.1.1.0/24 on the router
4-Your pool for vlan (see below). The default router should be 10.0.50.1 and not 10.0.0.1
ip dhcp pool Vlan
