1004
Explorer
2921 interface remains down
An interface on 2921 router is not coming up. When I shut/no shut the interface, I see this:
Router#sh log | i 0/2
Oct 17 08:55:06: %IP_VFR-7-FEATURE_DISABLE_IN: VFR(in) is manually disabled through CLI; VFR support for features that have internally enabled, will be made available only when VFR is enabled manually on interface GigabitEthernet0/2
Oct 17 09:00:35: %LINK-3-UPDOWN: Interface GigabitEthernet0/2, changed state to down
Router#sh int gi0/2
GigabitEthernet0/2 is down, line protocol is down
  Hardware is CN Gigabit Ethernet, address is e8b7.48ad.92d2 (bia e8b7.48ad.92d2)
  Description: Centurylink Circuit ID:ETH100-16332784
  Internet address is <>
  MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
  Keepalive set (10 sec)
  Auto Duplex, Auto Speed, media type is RJ45
  output flow-control is unsupported, input flow-control is unsupported
  Last input never, output never, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicasts)
3 REPLIES 3
Advisor
Kashish,
See if "ip virtual-reassembly" on the interface resolves the issue. Then do your shut/no shut.
HTH,
John
HTH, John *** Please rate all useful posts ***
Explorer
I tried that as well, but it remains down, down.
ip address <>
no ip redirects
no ip proxy-arp
ip nat outside
ip virtual-reassembly in
shutdown
duplex auto
speed auto
end
Router# sh int gi0/2
Have you checked for physical layer issues? I see the link itself is getting down : %LINK-3-UPDOWN
Kind Regards,
Ivan Shirshin
**Please grade this post if you find it useful.
Kind Regards, Ivan Shirshin **Please grade this post if you find it useful.
Content for Community-Ad
July's Community Spotlight Awards
