2950 boot into switch: mode
sivaprakasam81
The output of dir flash shows unable to stat flash., may i know the reason?. The Stat LED is green in color.
Some of the outpu follows,
switch: dir flash
unable to stat flash/: permission denied
switch: copy xmodem: flash:c2950-i6q4l2-mz.121-22.EA7.bin
Begin the Xmodem or Xmodem-1K transfer now...
CCCCCCCCCCBB0BB0xmodem:: I/O error
switch: flash_init
Initializing Flash...
...The flash is already initialized.
switch: load_helper
Thank you,
2 Accepted Solutions
A long time, be patient.
Is the xmodem transfer working now?
The transfer will take a long while as pointed out, I wouldn't be surprised for 72 minutes to be correct.
14 Replies 14
Lucien Avramov
Level 10
Level 10
Make sure that your cabling and the MD5 checksum of the bin file you have matches the one on cisco website when you download it.
If cabling and IOS image MD5 are right, then it's most likely that it needs an RMA.
Thank you. I am not sure about the RMA(waranty) status of the device.
The switch displays the switch: prompt.
Switch: dir flash
unable to stat flash/: permission denied.
switch: flash_init
Could be a issue with hardware(flash)? Is that possible to replace that alone?
Thank you,
Can you load the helper (load_helper command) after the flash_init and try the dir after again
you will have this information in my first post. Yes, I tried with
switch: load_helper
Still have the same result.
Thank you,
Siva
Unfortunately that sounds to me like an RMA.
Thank you for your reply. Just to make sure, when i do
switch: flash_init
So the command flash_init was already entered and you said it says the same thing for load_helper.
How about if you power cycle the switch and try it again from the order mentioned previously?
1. flash_init
2. load_helper
After the power cycle and the above steps, gives same status.
switch: flash_init
switch: load_helper
switch: dir flash
switch: load_helper
switch: flash_init
switch: dir flash
switch: copy xmodem: flash:c2950-i6q4l2-mz.121-20.EA1.bin
The switch went defective, RMA will be the way to go.
in rommon, type i and enter
then type dir flash:
You will be prompted to Iinitialize flash simm, reply 'Y'
After that, you can xmodem.
__
Edison.
Thank you, May I know how long will it take to do Xmodem tranfer? It shows 72 minutes to complete.
Thanks ,
Had to do
copy Xmodem:image_name flash:new image _name
At the same time I ran send file from the hyper terminal with the new image_name.
and it's working, Thanks for everyones help....
