2960 T/SFP port
roshanverg
I have a 2960 L2 switch   WS-2960  -48TC-L  WITH 2 T/SFP UPLINKS. Do i need any connectors to connect these uplinks to switch/server through cat 5 cable?
Hitesh Vinzoda
Level 4
Level 4
The Uplink ports are combo ports i.e. you can use sfp and fiber LC patch cord for fiber connecitivity or you can use cat 5 cable to connect. you cant use both of them at the same time. It should be one at a time fiber or copper.
Hitesh Vinzoda
Pls rate useful posts
