08-25-2013 02:03 AM - edited 03-07-2019 03:06 PM
I Have WS-C2960S-48TS-S with version 12.2(55)SE5 and image C2960S-UNIVERSALK9-M.
I'm having problems adding more the 64 vlans.
show vtp status shows:
Feature VLAN:
VTP Operating Mode : Transparent
Maximum VLANs supported locally : 64
Number of existing VLANs : 64
Configuration Revision : 0
MD5 digest : 0x7B 0xC2 0xDD 0x12 0xF4 0x5D 0x71 0x94
0x9F 0x44 0x6A 0x4D 0xCC 0x2C 0x86 0x6E
Is it a image limitation or VTP problem ?
Thanks!
08-25-2013 02:20 AM
Hi Daniel,
it's a license limitation for that platform, see:
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps6406/qa_c67-577519.html
The last letter in the product ID. If the last letter is "-L," it's LAN Base. If it's "-S," it's LAN Lite.
Q. Can a Cisco Catalyst 2960-S Series LAN Lite switch be upgraded to LAN Base?
A. No. The feature set is bound to the hardware model. To get the features and capabilities of LAN Base, you must purchase a LAN Base switch.
Hope that helps
Rolf
08-26-2013 05:39 AM
I have to ask why would you need more than 64 on a 2960 platform ,thats way more than you should need on a platform like that.
08-26-2013 05:44 AM
It's on my QA network, we have a lot of pepole testing on the network and each one has is own stack of vlans.
so we have about 200 vlans
