2960 X 48LPD L not switching, license issue?
I've 3 Switches WS-2960X-48LPD-L PoE . All of them have amber light on system after boot,
Vlan 1 is getting IP from DHCP but other ports once connected to host doesn't communicate over to dhcp.
I tried static IP also but its not working, there's some serious issue with these switches,
I checked about license, but Cisco says no license is needed?
Here're details,
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : AC:7E:8A:6D:41:00
Motherboard assembly number : 73-16687-04
Power supply part number : 341-0528-01
Motherboard serial number : FOC1830HJ5R
Power supply serial number : LIT1830T01T
Model revision number : G0
Motherboard revision number : B0
Model number : WS-C2960X-48LPD-L
Daughterboard assembly number : 73-14200-03
Daughterboard serial number : FOC1830306K
System serial number : FCW1810A33W
Top Assembly Part Number : 68-100465-01
Top Assembly Revision Number : C0
Version ID : V04
CLEI Code Number : CMMLK00ARD
Daughterboard revision number : A0
Hardware Board Revision Number : 0x12
Switch Ports Model SW Version SW Image
* 1 52 WS-C2960X-48LPD-L 15.2(2)E6 C2960X-UNIVERSALK9-M
cisco WS-C2960X-48LPD-L (APM86XXX) processor (revision A0) with 524288K bytes of memory.
Processor board ID FCW1836A32L
Last reset from power-on
1 Virtual Ethernet interface
1 FastEthernet interface
50 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
Base ethernet MAC Address : 00:8E:73:24:85:00
Motherboard assembly number : 73-14187-04
Power supply part number : 341-0527-01
Motherboard serial number : FOC1820G87N
Power supply serial number : DCB1822A54R
Model revision number : A0
Motherboard revision number : A0
Daughterboard serial number : FOC1826G87K
System serial number : FCW1836A32L
Top Assembly Part Number : 800-38002-01
Top Assembly Revision Number : A0
Version ID : V01
CLEI Code Number : CMMLK00ARA
Base ethernet MAC Address : 00:56:2B:90:22:00
Motherboard serial number : FOC1827M78H
Power supply serial number : DCB1830K67F
Daughterboard serial number : FOC1831D23A
System serial number : FCW1836A36M
Version ID : V01
* 1 52 WS-C2960X-48LPD-L 15.2(4)E6 C2960X-UNIVERSALK9-M
when you reload/reboot the switch, what is the output on the console ? Can you post that ?
Leo Laohoo
Post the complete output to the following command:
sh post
balaji.bandi
3 Switches WS-2960X-48LPD-L PoE   - is this working before - any power Loss ?
Did AMBER  LED  on all interface ports - if you get a chance connect one of the switch console port reboots and post complete output.
BB
