2960-X show power command
djmarkey
I have several stacks of 2960-X switches running various versions of IOS 15.2 code.  I've been asked by our Telecom group to see if I can find out the power draw of the stacks in each data closet.  I can pull some info via the "show power" command:
System Power Total (AC) 1031 Watts
System Power Used (AC) 233 Watts
I've tried to find a definition of this command in the docs with no luck.  Is any familiar with this command and can answer these questions.
1.  Is the "System Power Used" for the stack master switch or the stack as a whole.
2.  I'd like to be able to pull this information via SNMP if possible.  Would anyone know which MIB would give me this info.
Thanks....
It is for the master switch. If you want to see the power usage on all switches in the stack, run "sh power inline".
 This might help you:-  https://www.cisco.com/c/en/us/support/docs/switches/catalyst-2960-series-switches/200371-Mismatching-consumed-power-inline-valu.html
HTH,
Meheretab
HTH,
Meheretab
This oid give status of Power Supply .1.3.6.1.4.1.9.9.13.1.5.1.3
