2960-X Vlans
abernathy
Hello Cisco Community.
I need to purchase three stack-able switches for our new remote office.  I am looking at the 2960-X LAN Base models (WS-C2960X-48FPS-L).  The distributor that I am using told me that I can only have one default gateway and 16 VLANs????
This is a remove branch that connects to our DC via an iPSec tunnel provided by my FortiGates.  I do not need any type of routing protocols (OSPF, BGP).  I know it does not do dynamic routing and am okay with having to do static routing for everything.
I think the re-seller is just trying to up sale me.
balaji.bandi
As long as this stack is L2 and static routing this model ok with Lanbase.
you can view reference here :
http://nhprice.com/comparison-of-cisco-ios-image.html
BB
abernathy
Thank you for the reply.
So there should be no limit on the number of VLANs I can have correct?
1K VLAN for 2960-X
below FAQ help further clarification :
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-2960-x-series-switches/qa_c67-728348.html
BB
Your distributor mixed up two different things. I assume he was thinking about the number of static routes when routing is activated on these devices. There you can only have 16 static routes on the 2960-X which should also be not a relevant limit in your scenario.
