2960G Switch is not able to reload
md farook
Beginner
Beginner
Dear All,
Recently i have observed that one of my network Switch is not able to reload automatically. Whenever i try to fire RELOAD command it showing following error
Switch#reload
%ERROR: Not able to process Signature in flash:.
%ERROR: Aborting reload.
So kindly help me on this
7 REPLIES 7
Lucien Avramov
Advocate
Advocate
Try to disable file verity auto:
Switch(config)#no file verify auto
Its working.
thanks
now it able to reload automatically but once it accept reload command again it move in
Switch: mode and again i need to assign the path of the flash to reload.
What is the switch showing you with:
show boot
Do you have the boot path manually configured in the config file with boot system flash:path_to_image?
You can also verify what's in flash with:
show flash
I had same problem on 2960X stack of 2. I confirmed image was good with:
verify /md5 flash2:/IMAGE.bin
config:
no file verify auto
worked. Image loaded fine on second unit in stack
This worked for me on a 2960x
Leo Laohoo
VIP Community Legend VIP Community Legend
What IOS is this? I've never seen this behaviour before.
