Bob Van Haute
Beginner
2960s upgrade to 15.0(2) fails
We have a bunch of 2960s switches of which some of them can't be upgraded to IOS 15.0(2). It compared the show version commands and the ones that can be upgraded have
Model revision number           : H0
While the ones that can't be upgraded have:
Model revision number           : D0
The D0 switches can be upgraded to 15.0(1) without problems, but upgrade to 15.0(2) fails silently. It unpacks the image and than just fails over to the old image without error message.
Has anyone else experienced this behaviour en more importantly, does anyone have a fix for this?
Thanks in advance
Bob
17 REPLIES 17
Reza Sharifi
Hall of Fame Expert
Not sure what is the part number for your switches, but see table-4 for all supported 2960s that can be upgraded to 15.
http://www.cisco.com/c/en/us/products/collateral/switches/catalyst-3750-x-series-switches/product_bulletin_c25_682542.html
Thanks for the link, but this is for 15.0(1) and I don't have issues with that release. The upgrade only fails when I try to upgrade to 15.0(2) and above.
Bob
Did ypu find a solution to your problem? I have exactly the same problem with some switches. I think it has something to do with bootloader upgrading not working or not done with some older model revision numbers of the 2960S switches. See also my blog under
https://supportforums.cisco.com/discussion/12279616/ios-1502se1-higher-not-loadable-ws-c2960s-fps-l-bootloader-12253rse
Peter
Leo Laohoo
VIP Community Legend
All of my 2960/G/S are running 15.0(2)SE4.  I have no trouble upgrading them.
Can you post the upgrade process?  I want to see where the process is failing.
Hi Leo,
Sorry for the late reply. I haven't been working for the customer the last 2 weeks. I've attached the output of the attempted upgrade.
Bob
Your output shows me the switch is booting IOS version 12.2(58)SE1.  I don't see any attempts to upgrade the IOS nor the error message(s) pertaining to the failure to upgrade the IOS.
Correct, but it does start with uncompressing the 15.0(2) image, but after uncompressing it, it just goes to the next image. I also tried to use the tar image instead of the bin image, but that doesn't help either. I've already verified md5 checksums and they all match.
Ok, the output you've posted shows the switch attempting to load the IOS but it is failing because the IOS could potentially be corrupt.
Go to the Cisco website and search for the TAR file.  Download the TAR file.  [IMPORTANT] You need to compare the MD5 hash value of the TAR file you've just downloaded to the MD5 hash value found in the Cisco website.  They need to match.
Once you've passed this stage, upgrade the IOS of the switch using this method:  archive download-sw tftp://<TFTP IP address>/IOS.tar
I already tried to use the tar method, including the comparison of the md5 checksums and it's the same problem. I even tried copying over the image from a working switch, but to no avail.
Post the output to the command "sh version".
Here you go:
Cisco IOS Software, C2960S Software (C2960S-UNIVERSALK9-M), Version 12.2(58)SE1,        RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Thu 05-May-11 03:03 by prod_rel_team
ROM: Bootstrap program is Alpha board boot loader
BOOTLDR: C2960S Boot Loader (C2960S-HBOOT-M) Version 12.2(53r)SE, RELEASE SOFTWA        RE (fc3)
73_ACC_SW_702_007 uptime is 1 year, 38 weeks, 5 days, 5 hours, 37 minutes
System restarted at 08:02:33 CET Thu Sep 13 2012
System image file is "flash:c2960s-universalk9-mz.122-58.SE1.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C2960S-24TS-L (PowerPC) processor (revision D0) with 131072K bytes of m        emory.
Processor board ID FOC1528W8UV
Last reset from power-on
2 Virtual Ethernet interfaces
1 FastEthernet interface
28 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : 08:D0:9F:F6:88:00
Motherboard assembly number     : 73-11910-06
Power supply part number        : 341-0328-02
Motherboard serial number       : FOC154637MQ
Power supply serial number      : DCA1542M4F7
Motherboard revision number     : A0
Model number                    : WS-C2960S-24TS-L
Daughterboard assembly number   : 73-11933-04
Daughterboard serial number     : FOC15461NMB
System serial number            : FOC1528W8UV
Top Assembly Part Number        : 800-30954-02
Top Assembly Revision Number    : C0
Version ID                      : V02
CLEI Code Number                : COMGG00ARB
Daughterboard revision number   : A0
Hardware Board Revision Number  : 0x01
Switch Ports Model              SW Version            SW Image
*    1 28    WS-C2960S-24TS-L   12.2(58)SE1           C2960S-UNIVERSALK9-M
Configuration register is 0xF
Provide helpful information would certain help.  You're going to tell me that the switch that is having trouble booting the specified IOS has an uptime of more than one year?  Are you serious?  cheeky
Sorry, honest mistake, we have quite a few of them around. This is the one from the switch I've been experimenting with. You'll see that it's running 15.0(1) at the moment which boots fine, but 15.0(2) does not. I did some tests with an offline switch as well, but as I'm not at the customer at the moment, I can't give you that output. This switch however has exactly the same issue.
Cisco IOS Software, C2960S Software (C2960S-UNIVERSALK9-M), Version 15.0(1)SE3, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Wed 30-May-12 14:35 by prod_rel_team
BOOTLDR: C2960S Boot Loader (C2960S-HBOOT-M) Version 12.2(53r)SE, RELEASE SOFTWARE (fc3)
73_ACC_SW_702_014 uptime is 4 weeks, 5 days, 18 hours, 54 minutes
System restarted at 15:27:19 CET Fri May 9 2014
System image file is "flash:/c2960s-universalk9-mz.150-1.SE3.bin"
export@cisco.com.
cisco WS-C2960S-24TS-L (PowerPC) processor (revision D0) with 131072K bytes of memory.
Processor board ID FOC1519X1JE
Base ethernet MAC Address       : 0C:85:25:24:BA:80
Motherboard serial number       : FOC15460DSC
Power supply serial number      : DCA1542M4J7
Daughterboard serial number     : FOC15461NM7
System serial number            : FOC1519X1JE
Version ID                      : V02
*    1 28    WS-C2960S-24TS-L   15.0(1)SE3            C2960S-UNIVERSALK9-M
Ok, now post the output to the command "dir".
