2960X High CPU Usage
southardd
We have a 2960X that has been giving us issues for a while. It started with the switch losing connectivity frequently which we identified to be a bad SFP. We swapped it out and everything was stable for a while. More recently it has begun giving us high CPU utilization warnings and spiking to 99%. This seems to happen a few times a day for about half an hour then returns to normal. It happens at all hours, even in the early morning when nobody is in the building.
I ran show processes cpu sorted and it shows the highest two processes are Hulc LED Process and CDP Protocol. From what I have read it is normal for the Hulc LED process to around 20-30% on the 2960X so that seems normal, but the CDP Protocol process is running close to 30% as well. I've compared that to other switches in our building and none of them have that issue. I'm hoping someone can help identify what is going. Here is the full output of the command. Please let me know if I can provide anything that would be more helpful.
HS-IDF-A127-2960X-1#show processes cpu sorted
CPU utilization for five seconds: 99%/19%; one minute: 99%; five minutes: 99%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
163 305846168 27629968 11069 31.48% 31.45% 31.48% 0 Hulc LED Process
195 20517146 3021685 6789 29.02% 27.85% 27.70% 0 CDP Protocol
70 826573 1960113 421 1.01% 1.02% 1.11% 0 EEM ED ND
266 983802 1452978 677 1.01% 1.43% 1.43% 0 Cluster Base
93 365866 48558760 7 0.65% 0.36% 0.31% 0 RedEarth Rx Mana
174 4783457 220260 21717 0.41% 0.41% 0.41% 0 HQM Stack Proces
92 434323 48446799 8 0.35% 0.28% 0.27% 0 RedEarth Tx Mana
132 4108451 1106354 3713 0.29% 0.47% 0.47% 0 hpm counter proc
128 360346 9504175 37 0.23% 0.34% 0.35% 0 hpm main process
357 2136063 1575778 1355 0.23% 0.09% 0.07% 0 SNMP ENGINE
122 166448 27581934 6 0.23% 0.13% 0.12% 0 HLFM address lea
175 1787950 1314189 1360 0.17% 0.15% 0.12% 0 HRPC qos request
221 835266 3430012 243 0.17% 0.14% 0.17% 0 Spanning Tree
294 127128 2434917 52 0.11% 0.11% 0.11% 0 Marvell wk-a Pow
238 207964 11063522 18 0.11% 0.18% 0.17% 0 UDLD
155 76769 5450718 14 0.11% 0.07% 0.06% 0 Hulc Storm Contr
2 7370 221272 33 0.05% 0.00% 0.00% 0 Load Meter
133 499057 2845510 175 0.05% 0.05% 0.05% 0 HRPC pm-counters
63 247063 1106518 223 0.05% 0.12% 0.11% 0 Per-Second Jobs
84 82353 36504434 2 0.05% 0.05% 0.05% 0 Draught link sta
142 1908 1832 1041 0.05% 0.01% 0.01% 1 SSH Process
254 131448 282017 466 0.05% 0.00% 0.00% 0 XDR mcast rcv
73 40943 20581220 1 0.05% 0.03% 0.00% 0 DownWhenLooped
23 8208 220159 37 0.00% 0.00% 0.00% 0 IPC Event Notifi
22 0 1 0 0.00% 0.00% 0.00% 0 IFS Agent Manage
24 1903 1076702 1 0.00% 0.00% 0.00% 0 IPC Mcast Pendin
21 25 7 3571 0.00% 0.00% 0.00% 0 Entity MIB API
28 1739 1076702 1 0.00% 0.00% 0.00% 0 IPC Deferred Por
25 0 1 0 0.00% 0.00% 0.00% 0 IPC Session Serv
20 0 1 0 0.00% 0.00% 0.00% 0 Policy Manager
31 91 63220 1 0.00% 0.00% 0.00% 0 IPC Check Queue
19 0 1 0 0.00% 0.00% 0.00% 0 AAA_SERVER_DEADT
26 0 1 0 0.00% 0.00% 0.00% 0 IPC Zone Manager
27 2492 1076701 2 0.00% 0.00% 0.00% 0 IPC Periodic Tim
29 0 1 0 0.00% 0.00% 0.00% 0 IPC Process leve
36 101 5 20200 0.00% 0.00% 0.00% 0 PrstVbl
37 0 1 0 0.00% 0.00% 0.00% 0 Crash writer
38 0 1 0 0.00% 0.00% 0.00% 0 Exception contro
30 4 9 444 0.00% 0.00% 0.00% 0 IPC Seat Manager
40 0 5 0 0.00% 0.00% 0.00% 0 License IPC stat
32 18 47 382 0.00% 0.00% 0.00% 0 IPC Seat RX Cont
42 3277 1106354 2 0.00% 0.00% 0.00% 0 GraphIt
43 0 1 0 0.00% 0.00% 0.00% 0 client_entity_se
44 0 2 0 0.00% 0.00% 0.00% 0 SMART
45 0 2 0 0.00% 0.00% 0.00% 0 XML Proxy Client
33 0 1 0 0.00% 0.00% 0.00% 0 IPC Seat TX Cont
34 224 110651 2 0.00% 0.00% 0.00% 0 IPC Keep Alive M
48 0 1 0 0.00% 0.00% 0.00% 0 Critical Bkgnd
35 4845 221158 21 0.00% 0.00% 0.00% 0 IPC Loadometer
50 0 1 0 0.00% 0.00% 0.00% 0 IDB Work
39 753 290 2596 0.00% 0.00% 0.00% 0 crypto sw pk pro
52 7918 1100320 7 0.00% 0.00% 0.00% 0 TTY Background
53 0 18 0 0.00% 0.00% 0.00% 0 SXP CORE
54 0 1 0 0.00% 0.00% 0.00% 0 Cat6k NTI ICC pr
55 8 5 1600 0.00% 0.00% 0.00% 0 IF-MGR control p
56 0 100 0 0.00% 0.00% 0.00% 0 IF-MGR event pro
57 0 1 0 0.00% 0.00% 0.00% 0 ICC Nego
58 0 1 0 0.00% 0.00% 0.00% 0 Inode Table Dest
59 0 5 0 0.00% 0.00% 0.00% 0 IP Admission HA
41 0 1 0 0.00% 0.00% 0.00% 0 License IPC serv
61 51864 221274 234 0.00% 0.03% 0.00% 0 Compute load avg
62 198822 18601 10688 0.00% 0.00% 0.00% 0 Per-minute Jobs
46 0 1 0 0.00% 0.00% 0.00% 0 ARP Snoop
64 0 1 0 0.00% 0.00% 0.00% 0 AggMgr Process
65 0 240 0 0.00% 0.00% 0.00% 0 Transport Port A
66 33736 328558 102 0.00% 0.00% 0.00% 0 HC Counter Timer
67 1135 11027 102 0.00% 0.00% 0.00% 0 SFF8472
68 0 240 0 0.00% 0.00% 0.00% 0 EEM ED Identity
69 0 130 0 0.00% 0.00% 0.00% 0 EEM ED MAT
18 5022 1149157 4 0.00% 0.00% 0.00% 0 ARP Background
71 1143 11 103909 0.00% 0.00% 0.00% 0 USB Startup
72 0 2 0 0.00% 0.00% 0.00% 0 APM 86392 RTC
47 7675 1100455 6 0.00% 0.00% 0.00% 0 Dynamic ARP Insp
74 0 1 0 0.00% 0.00% 0.00% 0 HRPC power_mgmt
75 0 2 0 0.00% 0.00% 0.00% 0 Porter Power Man
49 175386 233413 751 0.00% 0.02% 0.05% 0 Net Background
77 0 1 0 0.00% 0.00% 0.00% 0 Hulc EEM Process
78 0 1 0 0.00% 0.00% 0.00% 0 HRPC lpip reques
79 0 2 0 0.00% 0.00% 0.00% 0 HLPIP Sync Proce
51 428 7721 55 0.00% 0.00% 0.00% 0 Logger
81 0 1 0 0.00% 0.00% 0.00% 0 HRPC EnergyWise
82 0 1 0 0.00% 0.00% 0.00% 0 HRPC actual powe
83 0 1 0 0.00% 0.00% 0.00% 0 HRPC ipadm reque
60 923 35677 25 0.00% 0.00% 0.00% 0 Net Input
85 609 36860 16 0.00% 0.00% 0.00% 0 PSP Timer
86 0 1 0 0.00% 0.00% 0.00% 0 HULC QM Tcam Mem
87 0 1 0 0.00% 0.00% 0.00% 0 HRPC asic-stats
88 0 3 0 0.00% 0.00% 0.00% 0 Stack DI Update
89 405 3702 109 0.00% 0.00% 0.00% 0 OBFL TEMP obfl0
90 775 57983 13 0.00% 0.00% 0.00% 0 Adjust Regions
91 5399 2212707 2 0.00% 0.00% 0.00% 0 FlexStack Hotswa
17 322337 802390 401 0.00% 0.01% 0.04% 0 ARP Input
16 588041 18428 31910 0.00% 0.04% 0.02% 0 Licensing Auto U
94 1709 221272 7 0.00% 0.00% 0.00% 0 HULC Thermal Pro
95 0 1 0 0.00% 0.00% 0.00% 0 HRPC hsm request
96 115 91 1263 0.00% 0.00% 0.00% 0 Stack Mgr
15 0 1 0 0.00% 0.00% 0.00% 0 Image License br
98 15541 552398 28 0.00% 0.01% 0.00% 0 hrpc -> response
99 56952 2654504 21 0.00% 0.00% 0.00% 0 hrpc -> request
100 465995 3069720 151 0.00% 0.04% 0.05% 0 hrpc <- response
76 0 1 0 0.00% 0.00% 0.00% 0 HULC ACL Tcam Me
102 11301 5531740 2 0.00% 0.00% 0.00% 0 apm86xxx_enet_pr
103 0 9 0 0.00% 0.00% 0.00% 0 HULC Device Mana
104 4337 28720 151 0.00% 0.00% 0.00% 0 HRPC hdm non blo
105 0 4 0 0.00% 0.00% 0.00% 0 HRPC hdm blockin
106 15065 220132 68 0.00% 0.00% 0.00% 0 HIPC bkgrd proce
107 0 1 0 0.00% 0.00% 0.00% 0 RTTYS Process
108 23 80 287 0.00% 0.00% 0.00% 0 Hulc Port-Securi
109 16 182 87 0.00% 0.00% 0.00% 0 HRPC hpsecure re
14 223 18431 12 0.00% 0.00% 0.00% 0 IPC Dynamic Cach
111 0 29 0 0.00% 0.00% 0.00% 0 HRPC emac reques
112 2885 25216 114 0.00% 0.00% 0.00% 0 HRPC hulc misc r
113 1103 368284 2 0.00% 0.00% 0.00% 0 HVLAN main bkgrd
114 0 2 0 0.00% 0.00% 0.00% 0 HVLAN Mapped Vla
115 0 2 0 0.00% 0.00% 0.00% 0 Vlan shutdown Pr
116 4 60 66 0.00% 0.00% 0.00% 0 HRPC vlan reques
117 0 1 0 0.00% 0.00% 0.00% 0 HULC VLAN REF Ba
118 87261 1208602 72 0.00% 0.01% 0.00% 0 HRPC ilp request
13 0 1 0 0.00% 0.00% 0.00% 0 License Client N
120 37729 73708 511 0.00% 0.00% 0.00% 0 Strider Tcam Mem
121 14764 118696 124 0.00% 0.00% 0.00% 0 HRPC hlfm reques
12 11524 4425432 2 0.00% 0.00% 0.00% 0 HUSB Console
123 10962 1100323 9 0.00% 0.00% 0.00% 0 HLFM aging proce
124 1022 305809 3 0.00% 0.00% 0.00% 0 HLFM address ret
125 0 1 0 0.00% 0.00% 0.00% 0 HULC PM Vector P
126 0 1 0 0.00% 0.00% 0.00% 0 HPM Msg Retry Pr
11 53 2945 17 0.00% 0.00% 0.00% 0 WATCH_AFS
10 0 2 0 0.00% 0.00% 0.00% 0 Timers
129 25 76 328 0.00% 0.00% 0.00% 0 HPM Stack Sync P
130 191 666 286 0.00% 0.00% 0.00% 0 HRPC pm request
131 0 6 0 0.00% 0.00% 0.00% 0 HPM if_num mappi
9 0 1 0 0.00% 0.00% 0.00% 0 DiscardQ Backgro
80 0 1 0 0.00% 0.00% 0.00% 0 HRPC hnetwpol re
134 0 1 0 0.00% 0.00% 0.00% 0 hpm vp events ca
135 0 1 0 0.00% 0.00% 0.00% 0 HRPC hcmp reques
136 139 527 263 0.00% 0.00% 0.00% 0 HCEF ADJ Refresh
137 0 1 0 0.00% 0.00% 0.00% 0 HACL Queue Proce
138 0 1 0 0.00% 0.00% 0.00% 0 HRPC acl request
139 4 39 102 0.00% 0.00% 0.00% 0 HACL Acl Manager
140 0 1 0 0.00% 0.00% 0.00% 0 HRPC aim request
141 0 1 0 0.00% 0.00% 0.00% 0 HRPC backup inte
101 0 5 0 0.00% 0.00% 0.00% 0 HRPC hcomp reque
143 0 1 0 0.00% 0.00% 0.00% 0 HRPC cdp request
144 0 3 0 0.00% 0.00% 0.00% 0 HULC CISP Proces
145 2796 51226 54 0.00% 0.00% 0.00% 0 HRPC dot1x reque
146 0 1 0 0.00% 0.00% 0.00% 0 Dot1X Msg Retry
8 296 293 1010 0.00% 0.00% 0.00% 0 Pool Manager
148 0 1 0 0.00% 0.00% 0.00% 0 HRPC lldp reques
149 0 5 0 0.00% 0.00% 0.00% 0 HRPC system mtu
150 0 8 0 0.00% 0.00% 0.00% 0 HRPC rep request
151 0 5 0 0.00% 0.00% 0.00% 0 REP Helper Proc
152 0 1 0 0.00% 0.00% 0.00% 0 HRPC sdm request
153 0 1 0 0.00% 0.00% 0.00% 0 SMI MSG Retry Pr
154 0 1 0 0.00% 0.00% 0.00% 0 HRPC Smart Insta
7 2918018 249165 11711 0.00% 0.25% 0.23% 0 Check heaps
156 0 2 0 0.00% 0.00% 0.00% 0 HSTP Sync Proces
157 0 1 0 0.00% 0.00% 0.00% 0 HRPC stp_cli req
158 10 37 270 0.00% 0.00% 0.00% 0 HRPC stp_state_s
159 0 2 0 0.00% 0.00% 0.00% 0 S/W Bridge Proce
160 0 29 0 0.00% 0.00% 0.00% 0 HRPC hudld reque
161 0 1 0 0.00% 0.00% 0.00% 0 HRPC vqpc reques
162 0 1 0 0.00% 0.00% 0.00% 0 HRPC hled reques
6 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Dispatc
164 13214 810391 16 0.00% 0.00% 0.00% 0 HL3U bkgrd proce
165 43928 884695 49 0.00% 0.00% 0.00% 0 HRPC hl3u reques
166 3832 252588 15 0.00% 0.00% 0.00% 0 HIPV6 bkgrd proc
167 44512 884666 50 0.00% 0.00% 0.00% 0 HRPC IPv6 Unicas
168 0 1 0 0.00% 0.00% 0.00% 0 HRPC obfl reques
170 0 1 0 0.00% 0.00% 0.00% 0 HRPC dtp request
171 0 1 0 0.00% 0.00% 0.00% 0 HRPC show_forwar
172 0 1 0 0.00% 0.00% 0.00% 0 HRPC snmp reques
173 0 1 0 0.00% 0.00% 0.00% 0 HULC SNMP Proces
5 0 1 0 0.00% 0.00% 0.00% 0 Retransmission o
4 40 9527 4 0.00% 0.00% 0.00% 0 DHCPD Timer
176 0 1 0 0.00% 0.00% 0.00% 0 HRPC span reques
177 17 19 894 0.00% 0.00% 0.00% 0 HRPC system post
178 0 17 0 0.00% 0.00% 0.00% 0 Hulc Reload Mana
3 59 402 146 0.00% 0.00% 0.00% 0 hulc_entropy_thr
180 730 3739 195 0.00% 0.00% 0.00% 0 HRPC hrcli-event
181 132 6147 21 0.00% 0.00% 0.00% 0 HCMP sync proces
182 0 2 0 0.00% 0.00% 0.00% 0 image mgr
183 0 1 0 0.00% 0.00% 0.00% 0 HRFS OIR Proc
97 473 53 8924 0.00% 0.00% 0.00% 0 Stack Mgr Notifi
185 61923 289200 214 0.00% 0.00% 0.00% 0 HL2MCM
186 7 9 777 0.00% 0.00% 0.00% 0 HL2MCM
187 10 240 41 0.00% 0.00% 0.00% 0 AAA Server
188 0 1 0 0.00% 0.00% 0.00% 0 AAA ACCT Proc
189 0 1 0 0.00% 0.00% 0.00% 0 ACCT Periodic Pr
190 0 1 0 0.00% 0.00% 0.00% 0 AAA System Acct
191 0 1 0 0.00% 0.00% 0.00% 0 AUTH POLICY Fram
192 10257 1107181 9 0.00% 0.00% 0.00% 0 Auth Manager
193 0 1 0 0.00% 0.00% 0.00% 0 Auth-proxy AAA B
194 11 3688 2 0.00% 0.00% 0.00% 0 IP Admin SM Proc
110 0 1 0 0.00% 0.00% 0.00% 0 HRPC hrcmd reque
196 0 1 0 0.00% 0.00% 0.00% 0 DiagCard3/-1
197 80461 1689508 47 0.00% 0.01% 0.00% 0 CEF: IPv4 proces
198 3 2 1500 0.00% 0.00% 0.00% 0 CMD HANDLER
199 0 2 0 0.00% 0.00% 0.00% 0 AAA Dictionary R
200 31 9220 3 0.00% 0.00% 0.00% 0 DHCP Snooping
201 0 1 0 0.00% 0.00% 0.00% 0 DHCP Snooping db
202 0 2 0 0.00% 0.00% 0.00% 0 Dot1x Mgr Proces
203 0 1 0 0.00% 0.00% 0.00% 0 EAP Framework
204 0 1 0 0.00% 0.00% 0.00% 0 EAP Test
205 0 2 0 0.00% 0.00% 0.00% 0 CEF switching ba
206 4 4 1000 0.00% 0.00% 0.00% 0 IP ARP Adjacency
207 72875 27582086 2 0.00% 0.01% 0.01% 0 IP ARP Retry Age
208 39421 304655 129 0.00% 0.00% 0.00% 0 IP Input
209 0 1 0 0.00% 0.00% 0.00% 0 ICMP event handl
210 5873 2126474 2 0.00% 0.00% 0.00% 0 IP ARP Track
211 0 1 0 0.00% 0.00% 0.00% 0 ADJ NSF process
212 0 1 0 0.00% 0.00% 0.00% 0 IPv6 ping proces
213 49 43 1139 0.00% 0.00% 0.00% 0 SpanTree Helper
214 0 2 0 0.00% 0.00% 0.00% 0 REP Topology cha
215 4 36 111 0.00% 0.00% 0.00% 0 SMI Director DB
216 863 19686 43 0.00% 0.00% 0.00% 0 SMI CDP Update H
217 0 1 0 0.00% 0.00% 0.00% 0 SMI Backup Proce
218 0 2 0 0.00% 0.00% 0.00% 0 SMI IBC server p
219 0 1 0 0.00% 0.00% 0.00% 0 SMI IBC client p
220 0 2 0 0.00% 0.00% 0.00% 0 SMI IBC Download
119 14435 1100335 13 0.00% 0.00% 0.00% 0 Hulc ILP Alchemy
222 32 18445 1 0.00% 0.00% 0.00% 0 Spanning Tree St
223 205 107 1915 0.00% 0.00% 0.00% 0 802.1x switch
224 0 1 0 0.00% 0.00% 0.00% 0 802.1x Webauth F
225 0 2 0 0.00% 0.00% 0.00% 0 DTP Protocol
226 0 5 0 0.00% 0.00% 0.00% 0 HRPC IPv6 Host r
227 0 1 0 0.00% 0.00% 0.00% 0 IPv6 Platform Ho
228 0 1 0 0.00% 0.00% 0.00% 0 HRPC dai request
229 0 1 0 0.00% 0.00% 0.00% 0 HULC DAI Process
230 0 1 0 0.00% 0.00% 0.00% 0 HRPC power down
231 0 1 0 0.00% 0.00% 0.00% 0 HRPC ip device t
232 0 1 0 0.00% 0.00% 0.00% 0 HRPC ip source g
233 0 1 0 0.00% 0.00% 0.00% 0 HULC IP Source g
234 0 1 0 0.00% 0.00% 0.00% 0 HRPC sisf reques
235 0 4 0 0.00% 0.00% 0.00% 0 HULC SISF Proces
236 0 1 0 0.00% 0.00% 0.00% 0 HULC SISF Source
237 85411 1100324 77 0.00% 0.02% 0.00% 0 PI MATM Aging Pr
127 199 18429 10 0.00% 0.00% 0.00% 0 DHCPD Database
239 43 36879 1 0.00% 0.00% 0.00% 0 Port-Security
240 0 2 0 0.00% 0.00% 0.00% 0 Switch Backup In
241 0 2 0 0.00% 0.00% 0.00% 0 IP Host Track Pr
242 0 1 0 0.00% 0.00% 0.00% 0 Link State Group
243 187 18429 10 0.00% 0.00% 0.00% 0 MMN bkgrd proces
244 310 110563 2 0.00% 0.00% 0.00% 0 Ethchnl
245 42 43 976 0.00% 0.00% 0.00% 0 VMATM Callback
246 2025 22163 91 0.00% 0.00% 0.00% 0 CEF background p
247 0 1 0 0.00% 0.00% 0.00% 0 fib_fib_bfd_sb e
248 0 1 0 0.00% 0.00% 0.00% 0 IP IRDP
249 0 1 0 0.00% 0.00% 0.00% 0 CEF RF HULC Conv
250 0 2 0 0.00% 0.00% 0.00% 0 XDR background p
251 8338 18870 441 0.00% 0.00% 0.00% 0 XDR mcast
252 550 110562 4 0.00% 0.00% 0.00% 0 IP ACL XDR LC Ba
253 0 3 0 0.00% 0.00% 0.00% 0 XDR RP Ping Back
1 87 2176 39 0.00% 0.00% 0.00% 0 Chunk Manager
255 622 18429 33 0.00% 0.00% 0.00% 0 XDR RP backgroun
256 10 7 1428 0.00% 0.00% 0.00% 0 IPC LC Message H
257 0 1 0 0.00% 0.00% 0.00% 0 XDR RP Test Back
258 4 3 1333 0.00% 0.00% 0.00% 0 ADJ background
259 0 1 0 0.00% 0.00% 0.00% 0 Critical Auth
260 21 534 39 0.00% 0.00% 0.00% 0 TCP Timer
261 51 232 219 0.00% 0.00% 0.00% 0 TCP Protocols
262 14063 1099035 12 0.00% 0.00% 0.00% 0 Socket Timers
263 6 3691 1 0.00% 0.00% 0.00% 0 HTTP CORE
264 14 13831 1 0.00% 0.00% 0.00% 0 Cluster L2
265 877 110563 7 0.00% 0.00% 0.00% 0 Cluster RARP
147 1892 26201 72 0.00% 0.00% 0.00% 0 HULC DOT1X Proce
267 66067 2198070 30 0.00% 0.01% 0.00% 0 DHCPD Receive
268 0 2 0 0.00% 0.00% 0.00% 0 Dot1x Supplicant
269 0 2 0 0.00% 0.00% 0.00% 0 Dot1x Supplicant
270 0 2 0 0.00% 0.00% 0.00% 0 Dot1x Supplicant
271 0 2 0 0.00% 0.00% 0.00% 0 Routing Topology
272 0 3 0 0.00% 0.00% 0.00% 0 Flow Exporter Ti
273 0 1 0 0.00% 0.00% 0.00% 0 RARP Input
274 0 2 0 0.00% 0.00% 0.00% 0 IP RIB Update
275 14 121 115 0.00% 0.00% 0.00% 0 HRPC hl2mcm igmp
276 4 82 48 0.00% 0.00% 0.00% 0 HRPC hl2mcm mlds
277 0 2 0 0.00% 0.00% 0.00% 0 static
278 0 2 0 0.00% 0.00% 0.00% 0 ADJ resolve proc
279 0 1 0 0.00% 0.00% 0.00% 0 IPv6 RIB Event H
280 0 1 0 0.00% 0.00% 0.00% 0 MAB Framework
281 395552 110569 3577 0.00% 0.04% 0.05% 0 QoS stats proces
282 0 1 0 0.00% 0.00% 0.00% 0 Connection Mgr
283 0 2 0 0.00% 0.00% 0.00% 0 REP LSL Proc
284 0 2 0 0.00% 0.00% 0.00% 0 REP BPA/EPA Proc
285 0 4 0 0.00% 0.00% 0.00% 0 SNMP Timers
286 0 1 0 0.00% 0.00% 0.00% 0 HRPC dhcp snoopi
287 3 6 500 0.00% 0.00% 0.00% 0 HULC DHCP Snoopi
288 30 74 405 0.00% 0.00% 0.00% 0 IGMPSN L2MCM
289 0 1 0 0.00% 0.00% 0.00% 0 IGMPSN MRD
290 31781 284772 111 0.00% 0.00% 0.00% 0 IGMPSN
291 0 1 0 0.00% 0.00% 0.00% 0 IGMPQR
292 0 3 0 0.00% 0.00% 0.00% 0 L2TRACE SERVER
293 131126 1652062 79 0.00% 0.03% 0.05% 0 Inline Power
179 0 1 0 0.00% 0.00% 0.00% 0 Hulc Blue Beacon
295 19 73 260 0.00% 0.00% 0.00% 0 MLDSN L2MCM
296 0 1 0 0.00% 0.00% 0.00% 0 MRD
297 0 1 0 0.00% 0.00% 0.00% 0 MLD_SNOOP
298 0 2 0 0.00% 0.00% 0.00% 0 AAA Cached Serve
299 0 3 0 0.00% 0.00% 0.00% 0 Collection proce
300 168 618 271 0.00% 0.00% 0.00% 0 NIST rng proc
301 0 2 0 0.00% 0.00% 0.00% 0 ENABLE AAA
302 0 3 0 0.00% 0.00% 0.00% 0 LDAP process
303 0 2 0 0.00% 0.00% 0.00% 0 LINE AAA
304 450 7737 58 0.00% 0.00% 0.00% 0 LOCAL AAA
305 0 2 0 0.00% 0.00% 0.00% 0 EPM MAIN PROCESS
306 0 7 0 0.00% 0.00% 0.00% 0 OBFL Cfg Dispatc
307 0 2 0 0.00% 0.00% 0.00% 0 TPLUS
308 0 1 0 0.00% 0.00% 0.00% 0 DiagCard2/-1
309 0 2 0 0.00% 0.00% 0.00% 0 crypto engine pr
310 0 1 0 0.00% 0.00% 0.00% 0 tHUB
311 0 5 0 0.00% 0.00% 0.00% 0 CEF RP IPC Backg
312 0 1 0 0.00% 0.00% 0.00% 0 encrypt proc
313 77 4 19250 0.00% 0.00% 0.00% 0 Crypto CA
314 0 1 0 0.00% 0.00% 0.00% 0 Crypto PKI-CRL
315 0 1 0 0.00% 0.00% 0.00% 0 HRPC x_setup req
316 0 2 0 0.00% 0.00% 0.00% 0 REP Switch Helpe
317 0 1 0 0.00% 0.00% 0.00% 0 Licensing MIB pr
318 0 16 0 0.00% 0.00% 0.00% 0 VTP Trap Process
319 4 330 12 0.00% 0.00% 0.00% 0 ASP Process Crea
320 86 474 181 0.00% 0.00% 0.00% 0 AAA SEND STOP EV
321 0 1 0 0.00% 0.00% 0.00% 0 Test AAA Client
322 0 2 0 0.00% 0.00% 0.00% 0 DHCP Security He
323 252 4245 59 0.00% 0.00% 0.00% 0 EEM ED Syslog
324 0 1 0 0.00% 0.00% 0.00% 0 Syslog Traps
325 73 3911 18 0.00% 0.00% 0.00% 0 FEX Logger Proce
326 0 1 0 0.00% 0.00% 0.00% 0 HCD Process
327 0 1 0 0.00% 0.00% 0.00% 0 HRPC cable diagn
328 4 23 173 0.00% 0.00% 0.00% 0 SpanTree Flush
329 0 2 0 0.00% 0.00% 0.00% 0 DiagCard1/-1
330 0 1 0 0.00% 0.00% 0.00% 0 Online Diag EEM
331 66280 11654094 5 0.00% 0.03% 0.05% 0 PM Callback
332 0 1 0 0.00% 0.00% 0.00% 0 HULC FNF
333 0 1 0 0.00% 0.00% 0.00% 0 LICENSE AGENT
334 256 88472 2 0.00% 0.00% 0.00% 0 dhcp snooping sw
335 49 3 16333 0.00% 0.00% 0.00% 0 OBFL MSG obfl0
336 0 25 0 0.00% 0.00% 0.00% 0 EEM Server
337 3 2 1500 0.00% 0.00% 0.00% 0 Call Home proces
338 0 2 0 0.00% 0.00% 0.00% 0 EEM Policy Direc
339 32 4 8000 0.00% 0.00% 0.00% 0 OBFL ENV obfl0
340 0 2 0 0.00% 0.00% 0.00% 0 EEM ED Config
341 0 3 0 0.00% 0.00% 0.00% 0 EEM ED Env
342 0 3 0 0.00% 0.00% 0.00% 0 EM ED GOLD
343 0 3 0 0.00% 0.00% 0.00% 0 EEM ED OIR
344 0 3 0 0.00% 0.00% 0.00% 0 EEM ED Test
345 123 29192 4 0.00% 0.00% 0.00% 0 EEM ED Timer
346 1220 3852 316 0.00% 0.00% 0.00% 0 Syslog
347 7 4 1750 0.00% 0.00% 0.00% 0 RBM CORE
348 523 18429 28 0.00% 0.00% 0.00% 0 Call Home Timer
349 0 1 0 0.00% 0.00% 0.00% 0 HRPC eee request
350 808 18429 43 0.00% 0.00% 0.00% 0 hulc_eee_monitor
351 0 2 0 0.00% 0.00% 0.00% 0 STP FAST TRANSIT
352 0 3 0 0.00% 0.00% 0.00% 0 CSRT RAPID TRANS
353 11 4 2750 0.00% 0.00% 0.00% 0 VLAN Manager
354 8 310 25 0.00% 0.00% 0.00% 0 SSH Event handle
355 145581 395723 367 0.00% 0.00% 0.00% 0 IP SNMP
356 30592 198413 154 0.00% 0.00% 0.00% 0 PDU DISPATCHER
184 1398 368786 3 0.00% 0.00% 0.00% 0 Power RPS Proces
358 0 2 0 0.00% 0.00% 0.00% 0 IP SNMPV6
359 0 1 0 0.00% 0.00% 0.00% 0 SNMP ConfCopyPro
360 6 6 1000 0.00% 0.00% 0.00% 0 SNMP Traps
361 9568 1106355 8 0.00% 0.00% 0.00% 0 NTP
362 14 3 4666 0.00% 0.00% 0.00% 0 hulc cfg mgr mas
363 0 1 0 0.00% 0.00% 0.00% 0 hulc running con
364 2689 18454 145 0.00% 0.00% 0.00% 0 OBFL VOLT obfl0
366 1997 73659 27 0.00% 0.00% 0.00% 0 OBFL I/O Buffer
***EDIT***
The CPU utilization just returned to normal. Here is the new output for show processes cpu sorted.
CPU utilization for five seconds: 39%/0%; one minute: 39%; five minutes: 43%
163 306384328 27667183 11073 23.27% 23.17% 23.69% 0 Hulc LED Process
174 4791426 220556 21724 0.35% 0.35% 0.35% 0 HQM Stack Proces
132 4116366 1107847 3715 0.35% 0.33% 0.35% 0 hpm counter proc
63 249552 1108011 225 0.11% 0.16% 0.15% 0 Per-Second Jobs
175 1790741 1315933 1360 0.11% 0.12% 0.12% 0 HRPC qos request
281 396201 110719 3578 0.05% 0.03% 0.05% 0 QoS stats proces
195 20803319 3042542 6837 0.05% 0.15% 1.90% 0 CDP Protocol
17 323001 803577 401 0.05% 0.01% 0.01% 0 ARP Input
133 499808 2848335 175 0.05% 0.02% 0.02% 0 HRPC pm-counters
93 369280 48611972 7 0.05% 0.02% 0.03% 0 RedEarth Rx Mana
12 11629 4431405 2 0.00% 0.00% 0.00% 0 HUSB Console
14 223 18456 12 0.00% 0.00% 0.00% 0 IPC Dynamic Cach
16 588985 18453 31918 0.00% 0.03% 0.00% 0 Licensing Auto U
23 8220 220455 37 0.00% 0.00% 0.00% 0 IPC Event Notifi
18 5074 1150701 4 0.00% 0.00% 0.00% 0 ARP Background
28 1756 1078147 1 0.00% 0.00% 0.00% 0 IPC Deferred Por
31 91 63305 1 0.00% 0.00% 0.00% 0 IPC Check Queue
24 1934 1078147 1 0.00% 0.00% 0.00% 0 IPC Mcast Pendin
34 228 110800 2 0.00% 0.00% 0.00% 0 IPC Keep Alive M
4 40 9539 4 0.00% 0.00% 0.00% 0 DHCPD Timer
7 2922742 249530 11712 0.00% 0.18% 0.20% 0 Check heaps
27 2507 1078146 2 0.00% 0.00% 0.00% 0 IPC Periodic Tim
49 175838 234466 749 0.00% 0.00% 0.00% 0 Net Background
51 434 7733 56 0.00% 0.00% 0.00% 0 Logger
52 7962 1101799 7 0.00% 0.00% 0.00% 0 TTY Background
60 923 35706 25 0.00% 0.00% 0.00% 0 Net Input
61 52122 221573 235 0.00% 0.00% 0.00% 0 Compute load avg
62 199153 18626 10692 0.00% 0.00% 0.00% 0 Per-minute Jobs
3 59 403 146 0.00% 0.00% 0.00% 0 hulc_entropy_thr
66 33801 329002 102 0.00% 0.00% 0.00% 0 HC Counter Timer
35 4881 221456 22 0.00% 0.00% 0.00% 0 IPC Loadometer
42 3318 1107847 2 0.00% 0.00% 0.00% 0 GraphIt
73 41368 20607438 2 0.00% 0.00% 0.00% 0 DownWhenLooped
47 7705 1101933 6 0.00% 0.00% 0.00% 0 Dynamic ARP Insp
84 83037 36548179 2 0.00% 0.00% 0.00% 0 Draught link sta
85 615 36910 16 0.00% 0.00% 0.00% 0 PSP Timer
67 1139 11045 103 0.00% 0.00% 0.00% 0 SFF8472
89 405 3707 109 0.00% 0.00% 0.00% 0 OBFL TEMP obfl0
90 779 58069 13 0.00% 0.00% 0.00% 0 Adjust Regions
91 5456 2215693 2 0.00% 0.00% 0.00% 0 FlexStack Hotswa
94 1722 221571 7 0.00% 0.00% 0.00% 0 HULC Thermal Pro
2 7422 221571 33 0.00% 0.00% 0.00% 0 Load Meter
98 15709 553141 28 0.00% 0.00% 0.00% 0 hrpc -> response
99 57061 2659474 21 0.00% 0.00% 0.00% 0 hrpc -> request
100 467057 3074881 151 0.00% 0.01% 0.03% 0 hrpc <- response
102 11450 5539207 2 0.00% 0.00% 0.00% 0 apm86xxx_enet_pr
104 4344 28758 151 0.00% 0.00% 0.00% 0 HRPC hdm non blo
106 15082 220428 68 0.00% 0.00% 0.00% 0 HIPC bkgrd proce
112 2885 25224 114 0.00% 0.00% 0.00% 0 HRPC hulc misc r
113 1109 368780 3 0.00% 0.00% 0.00% 0 HVLAN main bkgrd
118 87428 1210043 72 0.00% 0.00% 0.00% 0 HRPC ilp request
119 14505 1101813 13 0.00% 0.00% 0.00% 0 Hulc ILP Alchemy
120 37800 73808 512 0.00% 0.00% 0.00% 0 Strider Tcam Mem
121 14787 118842 124 0.00% 0.00% 0.00% 0 HRPC hlfm reques
122 167823 27618697 6 0.00% 0.00% 0.00% 0 HLFM address lea
123 10988 1101802 9 0.00% 0.00% 0.00% 0 HLFM aging proce
124 1029 306224 3 0.00% 0.00% 0.00% 0 HLFM address ret
127 199 18454 10 0.00% 0.00% 0.00% 0 DHCPD Database
128 364249 9518464 38 0.00% 0.00% 0.00% 0 hpm main process
70 838423 1979839 423 0.00% 0.00% 0.04% 0 EEM ED ND
142 2232 2208 1010 0.00% 0.00% 0.00% 1 SSH Process
145 2800 51278 54 0.00% 0.00% 0.00% 0 HRPC dot1x reque
147 1896 26227 72 0.00% 0.00% 0.00% 0 HULC DOT1X Proce
155 77723 5457842 14 0.00% 0.00% 0.00% 0 Hulc Storm Contr
1 87 2178 39 0.00% 0.00% 0.00% 0 Chunk Manager
164 13359 811480 16 0.00% 0.00% 0.00% 0 HL3U bkgrd proce
165 44017 885889 49 0.00% 0.00% 0.00% 0 HRPC hl3u reques
166 3875 252928 15 0.00% 0.00% 0.00% 0 HIPV6 bkgrd proc
167 44615 885862 50 0.00% 0.00% 0.00% 0 HRPC IPv6 Unicas
92 437770 48499617 9 0.00% 0.00% 0.01% 0 RedEarth Tx Mana
180 730 3745 194 0.00% 0.00% 0.00% 0 HRPC hrcli-event
181 136 6155 22 0.00% 0.00% 0.00% 0 HCMP sync proces
185 62023 289571 214 0.00% 0.00% 0.00% 0 HL2MCM
192 10317 1108716 9 0.00% 0.00% 0.00% 0 Auth Manager
194 11 3693 2 0.00% 0.00% 0.00% 0 IP Admin SM Proc
197 80690 1691667 47 0.00% 0.00% 0.00% 0 CEF: IPv4 proces
200 31 9233 3 0.00% 0.00% 0.00% 0 DHCP Snooping
207 73362 27618848 2 0.00% 0.00% 0.00% 0 IP ARP Retry Age
208 39587 305370 129 0.00% 0.00% 0.00% 0 IP Input
210 5912 2129332 2 0.00% 0.00% 0.00% 0 IP ARP Track
215 4 38 105 0.00% 0.00% 0.00% 0 SMI Director DB
216 863 19700 43 0.00% 0.00% 0.00% 0 SMI CDP Update H
221 837563 3433842 243 0.00% 0.05% 0.05% 0 Spanning Tree
222 32 18469 1 0.00% 0.00% 0.00% 0 Spanning Tree St
237 85709 1101802 77 0.00% 0.00% 0.00% 0 PI MATM Aging Pr
238 210256 11078455 18 0.00% 0.00% 0.00% 0 UDLD
239 47 36929 1 0.00% 0.00% 0.00% 0 Port-Security
243 187 18454 10 0.00% 0.00% 0.00% 0 MMN bkgrd proces
244 314 110713 2 0.00% 0.00% 0.00% 0 Ethchnl
246 2028 22193 91 0.00% 0.00% 0.00% 0 CEF background p
251 8345 18895 441 0.00% 0.00% 0.00% 0 XDR mcast
252 557 110712 5 0.00% 0.00% 0.00% 0 IP ACL XDR LC Ba
254 131684 282350 466 0.00% 0.00% 0.00% 0 XDR mcast rcv
255 625 18454 33 0.00% 0.00% 0.00% 0 XDR RP backgroun
260 33 556 59 0.00% 0.00% 0.00% 0 TCP Timer
262 14089 1100494 12 0.00% 0.00% 0.00% 0 Socket Timers
263 6 3696 1 0.00% 0.00% 0.00% 0 HTTP CORE
264 14 13850 1 0.00% 0.00% 0.00% 0 Cluster L2
265 884 110713 7 0.00% 0.00% 0.00% 0 Cluster RARP
266 998280 1472324 678 0.00% 0.00% 0.06% 0 Cluster Base
267 66310 2200988 30 0.00% 0.00% 0.00% 0 DHCPD Receive
184 1411 369283 3 0.00% 0.00% 0.00% 0 Power RPS Proces
290 31839 285228 111 0.00% 0.00% 0.00% 0 IGMPSN
293 131545 1654070 79 0.00% 0.00% 0.00% 0 Inline Power
294 128432 2438152 52 0.00% 0.00% 0.00% 0 Marvell wk-a Pow
323 252 4251 59 0.00% 0.00% 0.00% 0 EEM ED Syslog
325 73 3917 18 0.00% 0.00% 0.00% 0 FEX Logger Proce
331 66815 11668014 5 0.00% 0.00% 0.00% 0 PM Callback
334 260 88591 2 0.00% 0.00% 0.00% 0 dhcp snooping sw
345 129 29231 4 0.00% 0.00% 0.00% 0 EEM ED Timer
346 1224 3858 317 0.00% 0.00% 0.00% 0 Syslog
348 523 18454 28 0.00% 0.00% 0.00% 0 Call Home Timer
350 811 18454 43 0.00% 0.00% 0.00% 0 hulc_eee_monitor
355 145917 396500 368 0.00% 0.00% 0.00% 0 IP SNMP
356 30632 198808 154 0.00% 0.00% 0.00% 0 PDU DISPATCHER
357 2138884 1579740 1353 0.00% 0.00% 0.08% 0 SNMP ENGINE
361 9628 1107848 8 0.00% 0.00% 0.00% 0 NTP
364 2693 18479 145 0.00% 0.00% 0.00% 0 OBFL VOLT obfl0
366 1997 73757 27 0.00% 0.00% 0.00% 0 OBFL I/O Buffer
6 Replies 6
Reza Sharifi
Have a look at this troubleshooting document. It maybe helpful to go through it.
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3750/software/troubleshooting/cpu_util.html
Also, it appears that Hulc LED Process issue is a known bug.
https://quickview.cloudapps.cisco.com/quickview/bug/CSCtg86211
Reza,
Thanks for the reply. I went through that document and ran through the commands but nothing really stuck out to me although I must admit I am by no means a Cisco expert. I did run a show log command and this is what it showed. I'm not sure if this is related or not, but every little bit of info helps. We are using Te2/0/1 as our uplink port to the MDF. If I remember correctly, when we had the issue before with the switch dropping we were getting UDLD errors so we swapped the SFP at both ends, used a different fiber strand to the MDF, and replaced the fiber uplink at both ends, but what ended up fixing it permanently was changing the uplink port from Te1/0/1 to Te 2/0/1.
Jul 10 05:08:25.938 edt: %SFF8472-5-THRESHOLD_VIOLATION: Te2/0/1: Rx power high alarm; Operating value: 2.9 dBm, Threshold value: 2.5 dBm.
Jul 10 05:08:45.973 edt: %SFF8472-5-THRESHOLD_VIOLATION: Te2/0/1: Rx power high alarm; Operating value: 2.9 dBm, Threshold value: 2.5 dBm. (HS-IDF-A127-2960X-1-2)
Jul 10 05:18:28.313 edt: %SFF8472-5-THRESHOLD_VIOLATION: Te2/0/1: Rx power high alarm; Operating value: 2.9 dBm, Threshold value: 2.5 dBm.
Jul 10 05:18:48.247 edt: %SFF8472-5-THRESHOLD_VIOLATION: Te2/0/1: Rx power high alarm; Operating value: 2.9 dBm, Threshold value: 2.5 dBm. (HS-IDF-A127-2960X-1-2)
Jul 10 05:28:30.664 edt: %SFF8472-5-THRESHOLD_VIOLATION: Te2/0/1: Rx power high alarm; Operating value: 2.9 dBm, Threshold value: 2.5 dBm.
Jul 10 05:28:50.601 edt: %SFF8472-5-THRESHOLD_VIOLATION: Te2/0/1: Rx power high alarm; Operating value: 2.9 dBm, Threshold value: 2.5 dBm. (HS-IDF-A127-2960X-1-2)
Jul 10 05:38:32.715 edt: %SFF8472-5-THRESHOLD_VIOLATION: Te2/0/1: Rx power high alarm; Operating value: 2.9 dBm, Threshold value: 2.5 dBm.
Jul 10 05:38:52.655 edt: %SFF8472-5-THRESHOLD_VIOLATION: Te2/0/1: Rx power high alarm; Operating value: 2.8 dBm, Threshold value: 2.5 dBm. (HS-IDF-A127-2960X-1-2)
Jul 10 05:48:34.765 edt: %SFF8472-5-THRESHOLD_VIOLATION: Te2/0/1: Rx power high alarm; Operating value: 2.8 dBm, Threshold value: 2.5 dBm.
Jul 10 05:48:54.713 edt: %SFF8472-5-THRESHOLD_VIOLATION: Te2/0/1: Rx power high alarm; Operating value: 2.8 dBm, Threshold value: 2.5 dBm. (HS-IDF-A127-2960X-1-2)
Jul 10 05:58:36.802 edt: %SFF8472-5-THRESHOLD_VIOLATION: Te2/0/1: Rx power high alarm; Operating value: 2.9 dBm, Threshold value: 2.5 dBm.
Jul 10 05:58:56.784 edt: %SFF8472-5-THRESHOLD_VIOLATION: Te2/0/1: Rx power high alarm; Operating value: 2.9 dBm, Threshold value: 2.5 dBm. (HS-IDF-A127-2960X-1-2)
Leo Laohoo
What firmware is the stack running on?
Is interface logging disabled?
Post the COMPLETE output to the command "sh logs".
The current software version for the switch is Cisco IOS Software, C2960X Software (C2960X-UNIVERSALK9-M), Version 15.0(2a)EX5, RELEASE SOFTWARE (fc3)
Also it should be noted after I disabled CDP on the stack the issue has gone away so I believe that was my problem, but I'm curious as to why CDP would cause such problems.
Here is the complete output from show log:
HS-IDF-A127-2960X-1#sho log
Syslog logging: enabled (0 messages dropped, 1 messages rate-limited, 0 flushes, 0 overruns, xml disabled, filtering disabled)
No Active Message Discriminator.
No Inactive Message Discriminator.
Console logging: disabled
Monitor logging: disabled
Buffer logging: level informational, 4629 messages logged, xml disabled,
filtering disabled
Exception Logging: size (4096 bytes)
Count and timestamp logging messages: disabled
File logging: disabled
Persistent logging: disabled
No active filter modules.
Trap logging: level notifications, 4618 message lines logged
Logging to 10.1.1.126 (udp port 514, audit disabled,
link up),
4506 message lines logged,
0 message lines rate-limited,
0 message lines dropped-by-MD,
xml disabled, sequence number disabled
filtering disabled
Logging Source-Interface: VRF Name:
Vlan1
Log Buffer (16384 bytes):
Jul 10 22:31:59.697 edt: %SFF8472-5-THRESHOLD_VIOLATION: Te2/0/1: Rx power high alarm; Operating value: 2.9 dBm, Threshold value: 2.5 dBm.
Jul 10 22:32:20.665 edt: %SFF8472-5-THRESHOLD_VIOLATION: Te2/0/1: Rx power high alarm; Operating value: 2.9 dBm, Threshold value: 2.5 dBm. (HS-IDF-A127-2960 X-1-2)
Jul 10 22:42:01.740 edt: %SFF8472-5-THRESHOLD_VIOLATION: Te2/0/1: Rx power high alarm; Operating value: 2.9 dBm, Threshold value: 2.5 dBm.
Jul 10 22:42:22.729 edt: %SFF8472-5-THRESHOLD_VIOLATION: Te2/0/1: Rx power high alarm; Operating value: 2.9 dBm, Threshold value: 2.5 dBm. (HS-IDF-A127-2960 X-1-2)
Jul 10 22:52:03.787 edt: %SFF8472-5-THRESHOLD_VIOLATION: Te2/0/1: Rx power high alarm; Operating value: 2.9 dBm, Threshold value: 2.5 dBm.
Jul 10 22:52:24.783 edt: %SFF8472-5-THRESHOLD_VIOLATION: Te2/0/1: Rx power high alarm; Operating value: 2.9 dBm, Threshold value: 2.5 dBm. (HS-IDF-A127-2960 X-1-2)
Jul 10 23:02:05.830 edt: %SFF8472-5-THRESHOLD_VIOLATION: Te2/0/1: Rx power high alarm; Operating value: 2.9 dBm, Threshold value: 2.5 dBm.
Jul 10 23:02:26.854 edt: %SFF8472-5-THRESHOLD_VIOLATION: Te2/0/1: Rx power high alarm; Operating value: 2.9 dBm, Threshold value: 2.5 dBm. (HS-IDF-A127-2960 X-1-2)
Jul 10 23:12:07.867 edt: %SFF8472-5-THRESHOLD_VIOLATION: Te2/0/1: Rx power high alarm; Operating value: 2.9 dBm, Threshold value: 2.5 dBm.
Jul 10 23:12:28.908 edt: %SFF8472-5-THRESHOLD_VIOLATION: Te2/0/1: Rx power high alarm; Operating value: 2.9 dBm, Threshold value: 2.5 dBm. (HS-IDF-A127-2960 X-1-2)
Jul 10 23:22:09.907 edt: %SFF8472-5-THRESHOLD_VIOLATION: Te2/0/1: Rx power high alarm; Operating value: 2.9 dBm, Threshold value: 2.5 dBm.
Jul 10 23:22:30.952 edt: %SFF8472-5-THRESHOLD_VIOLATION: Te2/0/1: Rx power high alarm; Operating value: 2.9 dBm, Threshold value: 2.5 dBm. (HS-IDF-A127-2960 X-1-2)
Jul 10 23:32:11.947 edt: %SFF8472-5-THRESHOLD_VIOLATION: Te2/0/1: Rx power high alarm; Operating value: 2.9 dBm, Threshold value: 2.5 dBm.
Jul 10 23:32:33.026 edt: %SFF8472-5-THRESHOLD_VIOLATION: Te2/0/1: Rx power high alarm; Operating value: 2.9 dBm, Threshold value: 2.5 dBm. (HS-IDF-A127-2960 X-1-2)
Jul 10 23:42:13.993 edt: %SFF8472-5-THRESHOLD_VIOLATION: Te2/0/1: Rx power high alarm; Operating value: 2.9 dBm, Threshold value: 2.5 dBm.
Jul 10 23:42:35.077 edt: %SFF8472-5-THRESHOLD_VIOLATION: Te2/0/1: Rx power high alarm; Operating value: 2.9 dBm, Threshold value: 2.5 dBm. (HS-IDF-A127-2960 X-1-2)
Jul 10 23:43:29.411 edt: %SSH-5-SSH2_SESSION: SSH2 Session request from 172.27.7 7.10 (tty = 0) using crypto cipher 'aes128-cbc', hmac 'hmac-sha1-96' Succeeded
Jul 10 23:43:29.418 edt: %SSH-5-SSH2_USERAUTH: User 'fcscadmin' authentication f or SSH2 Session from 172.27.77.10 (tty = 0) using crypto cipher 'aes128-cbc', hm ac 'hmac-sha1-96' Succeeded
Jul 10 23:45:31.419 edt: %SSH-5-SSH2_CLOSE: SSH2 Session from 172.27.77.10 (tty = 0) for user 'fcscadmin' using crypto cipher 'aes128-cbc', hmac 'hmac-sha1-96' closed
Jul 10 23:52:16.072 edt: %SFF8472-5-THRESHOLD_VIOLATION: Te2/0/1: Rx power high alarm; Operating value: 2.9 dBm, Threshold value: 2.5 dBm.
Jul 10 23:52:37.138 edt: %SFF8472-5-THRESHOLD_VIOLATION: Te2/0/1: Rx power high alarm; Operating value: 2.9 dBm, Threshold value: 2.5 dBm. (HS-IDF-A127-2960 X-1-2)
Jul 11 00:02:18.112 edt: %SFF8472-5-THRESHOLD_VIOLATION: Te2/0/1: Rx power high alarm; Operating value: 2.9 dBm, Threshold value: 2.5 dBm.
Jul 11 00:02:39.202 edt: %SFF8472-5-THRESHOLD_VIOLATION: Te2/0/1: Rx power high alarm; Operating value: 2.9 dBm, Threshold value: 2.5 dBm. (HS-IDF-A127-2960 X-1-2)
Jul 11 00:12:20.162 edt: %SFF8472-5-THRESHOLD_VIOLATION: Te2/0/1: Rx power high alarm; Operating value: 2.9 dBm, Threshold value: 2.5 dBm.
Jul 11 00:12:41.270 edt: %SFF8472-5-THRESHOLD_VIOLATION: Te2/0/1: Rx power high alarm; Operating value: 2.9 dBm, Threshold value: 2.5 dBm. (HS-IDF-A127-2960 X-1-2)
Jul 11 00:22:22.198 edt: %SFF8472-5-THRESHOLD_VIOLATION: Te2/0/1: Rx power high alarm; Operating value: 2.9 dBm, Threshold value: 2.5 dBm.
Jul 11 00:22:43.313 edt: %SFF8472-5-THRESHOLD_VIOLATION: Te2/0/1: Rx power high alarm; Operating value: 2.9 dBm, Threshold value: 2.5 dBm. (HS-IDF-A127-2960 X-1-2)
Jul 11 00:32:24.249 edt: %SFF8472-5-THRESHOLD_VIOLATION: Te2/0/1: Rx power high alarm; Operating value: 2.9 dBm, Threshold value: 2.5 dBm.
Jul 11 00:32:45.385 edt: %SFF8472-5-THRESHOLD_VIOLATION: Te2/0/1: Rx power high alarm; Operating value: 2.9 dBm, Threshold value: 2.5 dBm. (HS-IDF-A127-2960 X-1-2)
Jul 11 00:42:26.289 edt: %SFF8472-5-THRESHOLD_VIOLATION: Te2/0/1: Rx power high alarm; Operating value: 2.9 dBm, Threshold value: 2.5 dBm.
Jul 11 00:42:47.466 edt: %SFF8472-5-THRESHOLD_VIOLATION: Te2/0/1: Rx power high alarm; Operating value: 2.9 dBm, Threshold value: 2.5 dBm. (HS-IDF-A127-2960 X-1-2)
Jul 11 00:52:28.329 edt: %SFF8472-5-THRESHOLD_VIOLATION: Te2/0/1: Rx power high alarm; Operating value: 2.9 dBm, Threshold value: 2.5 dBm.
Jul 11 00:52:49.517 edt: %SFF8472-5-THRESHOLD_VIOLATION: Te2/0/1: Rx power high alarm; Operating value: 2.9 dBm, Threshold value: 2.5 dBm. (HS-IDF-A127-2960 X-1-2)
Jul 11 01:02:30.368 edt: %SFF8472-5-THRESHOLD_VIOLATION: Te2/0/1: Rx power high alarm; Operating value: 2.9 dBm, Threshold value: 2.5 dBm.
Jul 11 01:02:51.560 edt: %SFF8472-5-THRESHOLD_VIOLATION: Te2/0/1: Rx power high alarm; Operating value: 2.9 dBm, Threshold value: 2.5 dBm. (HS-IDF-A127-2960 X-1-2)
Jul 11 01:12:32.408 edt: %SFF8472-5-THRESHOLD_VIOLATION: Te2/0/1: Rx power high alarm; Operating value: 2.8 dBm, Threshold value: 2.5 dBm.
Jul 11 01:12:53.635 edt: %SFF8472-5-THRESHOLD_VIOLATION: Te2/0/1: Rx power high alarm; Operating value: 2.9 dBm, Threshold value: 2.5 dBm. (HS-IDF-A127-2960 X-1-2)
Jul 11 01:22:34.448 edt: %SFF8472-5-THRESHOLD_VIOLATION: Te2/0/1: Rx power high alarm; Operating value: 2.9 dBm, Threshold value: 2.5 dBm.
Jul 11 01:22:55.671 edt: %SFF8472-5-THRESHOLD_VIOLATION: Te2/0/1: Rx power high alarm; Operating value: 2.9 dBm, Threshold value: 2.5 dBm. (HS-IDF-A127-2960 X-1-2)
Jul 11 01:32:36.488 edt: %SFF8472-5-THRESHOLD_VIOLATION: Te2/0/1: Rx power high alarm; Operating value: 2.9 dBm, Threshold value: 2.5 dBm.
Jul 11 01:32:57.711 edt: %SFF8472-5-THRESHOLD_VIOLATION: Te2/0/1: Rx power high alarm; Operating value: 2.9 dBm, Threshold value: 2.5 dBm. (HS-IDF-A127-2960 X-1-2)
Jul 11 01:42:38.531 edt: %SFF8472-5-THRESHOLD_VIOLATION: Te2/0/1: Rx power high alarm; Operating value: 2.9 dBm, Threshold value: 2.5 dBm.
Jul 11 01:42:59.832 edt: %SFF8472-5-THRESHOLD_VIOLATION: Te2/0/1: Rx power high alarm; Operating value: 2.9 dBm, Threshold value: 2.5 dBm. (HS-IDF-A127-2960 X-1-2)
Jul 11 01:52:40.571 edt: %SFF8472-5-THRESHOLD_VIOLATION: Te2/0/1: Rx power high alarm; Operating value: 2.8 dBm, Threshold value: 2.5 dBm.
Jul 11 01:53:01.941 edt: %SFF8472-5-THRESHOLD_VIOLATION: Te2/0/1: Rx power high alarm; Operating value: 2.8 dBm, Threshold value: 2.5 dBm. (HS-IDF-A127-2960 X-1-2)
Jul 11 02:02:42.615 edt: %SFF8472-5-THRESHOLD_VIOLATION: Te2/0/1: Rx power high alarm; Operating value: 2.9 dBm, Threshold value: 2.5 dBm.
Jul 11 02:03:03.995 edt: %SFF8472-5-THRESHOLD_VIOLATION: Te2/0/1: Rx power high alarm; Operating value: 2.9 dBm, Threshold value: 2.5 dBm. (HS-IDF-A127-2960 X-1-2)
Jul 11 02:12:44.658 edt: %SFF8472-5-THRESHOLD_VIOLATION: Te2/0/1: Rx power high alarm; Operating value: 2.9 dBm, Threshold value: 2.5 dBm.
Jul 11 02:13:06.042 edt: %SFF8472-5-THRESHOLD_VIOLATION: Te2/0/1: Rx power high alarm; Operating value: 2.9 dBm, Threshold value: 2.5 dBm. (HS-IDF-A127-2960 X-1-2)
Jul 11 02:22:46.698 edt: %SFF8472-5-THRESHOLD_VIOLATION: Te2/0/1: Rx power high alarm; Operating value: 2.9 dBm, Threshold value: 2.5 dBm.
Jul 11 02:23:08.120 edt: %SFF8472-5-THRESHOLD_VIOLATION: Te2/0/1: Rx power high alarm; Operating value: 2.9 dBm, Threshold value: 2.5 dBm. (HS-IDF-A127-2960 X-1-2)
Jul 11 02:32:48.741 edt: %SFF8472-5-THRESHOLD_VIOLATION: Te2/0/1: Rx power high alarm; Operating value: 2.9 dBm, Threshold value: 2.5 dBm.
Jul 11 02:33:10.160 edt: %SFF8472-5-THRESHOLD_VIOLATION: Te2/0/1: Rx power high alarm; Operating value: 2.9 dBm, Threshold value: 2.5 dBm. (HS-IDF-A127-2960 X-1-2)
Jul 11 02:42:50.778 edt: %SFF8472-5-THRESHOLD_VIOLATION: Te2/0/1: Rx power high alarm; Operating value: 2.9 dBm, Threshold value: 2.5 dBm.
Jul 11 02:43:12.060 edt: %SFF8472-5-THRESHOLD_VIOLATION: Te2/0/1: Rx power high alarm; Operating value: 2.9 dBm, Threshold value: 2.5 dBm. (HS-IDF-A127-2960 X-1-2)
Jul 11 02:52:52.818 edt: %SFF8472-5-THRESHOLD_VIOLATION: Te2/0/1: Rx power high alarm; Operating value: 2.9 dBm, Threshold value: 2.5 dBm.
Jul 11 02:53:14.261 edt: %SFF8472-5-THRESHOLD_VIOLATION: Te2/0/1: Rx power high alarm; Operating value: 2.9 dBm, Threshold value: 2.5 dBm. (HS-IDF-A127-2960 X-1-2)
Jul 11 03:02:54.864 edt: %SFF8472-5-THRESHOLD_VIOLATION: Te2/0/1: Rx power high alarm; Operating value: 2.9 dBm, Threshold value: 2.5 dBm.
Jul 11 03:03:16.332 edt: %SFF8472-5-THRESHOLD_VIOLATION: Te2/0/1: Rx power high alarm; Operating value: 2.9 dBm, Threshold value: 2.5 dBm. (HS-IDF-A127-2960 X-1-2)
Jul 11 03:12:56.908 edt: %SFF8472-5-THRESHOLD_VIOLATION: Te2/0/1: Rx power high alarm; Operating value: 2.9 dBm, Threshold value: 2.5 dBm.
Jul 11 03:13:18.383 edt: %SFF8472-5-THRESHOLD_VIOLATION: Te2/0/1: Rx power high alarm; Operating value: 2.9 dBm, Threshold value: 2.5 dBm. (HS-IDF-A127-2960 X-1-2)
Jul 11 03:22:58.944 edt: %SFF8472-5-THRESHOLD_VIOLATION: Te2/0/1: Rx power high alarm; Operating value: 2.9 dBm, Threshold value: 2.5 dBm.
Jul 11 03:23:20.426 edt: %SFF8472-5-THRESHOLD_VIOLATION: Te2/0/1: Rx power high alarm; Operating value: 2.9 dBm, Threshold value: 2.5 dBm. (HS-IDF-A127-2960 X-1-2)
Jul 11 03:33:00.988 edt: %SFF8472-5-THRESHOLD_VIOLATION: Te2/0/1: Rx power high alarm; Operating value: 2.9 dBm, Threshold value: 2.5 dBm.
Jul 11 03:33:22.476 edt: %SFF8472-5-THRESHOLD_VIOLATION: Te2/0/1: Rx power high alarm; Operating value: 2.9 dBm, Threshold value: 2.5 dBm. (HS-IDF-A127-2960 X-1-2)
Jul 11 03:43:03.027 edt: %SFF8472-5-THRESHOLD_VIOLATION: Te2/0/1: Rx power high alarm; Operating value: 2.9 dBm, Threshold value: 2.5 dBm.
Jul 11 03:43:24.562 edt: %SFF8472-5-THRESHOLD_VIOLATION: Te2/0/1: Rx power high alarm; Operating value: 2.9 dBm, Threshold value: 2.5 dBm. (HS-IDF-A127-2960 X-1-2)
Jul 11 03:43:33.153 edt: %SSH-5-SSH2_SESSION: SSH2 Session request from 172.27.7 7.10 (tty = 0) using crypto cipher 'aes128-cbc', hmac 'hmac-sha1-96' Succeeded
Jul 11 03:43:33.160 edt: %SSH-5-SSH2_USERAUTH: User 'fcscadmin' authentication f or SSH2 Session from 172.27.77.10 (tty = 0) using crypto cipher 'aes128-cbc', hm ac 'hmac-sha1-96' Succeeded
Jul 11 03:45:35.270 edt: %SSH-5-SSH2_CLOSE: SSH2 Session from 172.27.77.10 (tty = 0) for user 'fcscadmin' using crypto cipher 'aes128-cbc', hmac 'hmac-sha1-96' closed
Jul 11 03:53:05.067 edt: %SFF8472-5-THRESHOLD_VIOLATION: Te2/0/1: Rx power high alarm; Operating value: 2.9 dBm, Threshold value: 2.5 dBm.
Jul 11 03:53:26.623 edt: %SFF8472-5-THRESHOLD_VIOLATION: Te2/0/1: Rx power high alarm; Operating value: 2.9 dBm, Threshold value: 2.5 dBm. (HS-IDF-A127-2960 X-1-2)
Jul 11 04:03:07.111 edt: %SFF8472-5-THRESHOLD_VIOLATION: Te2/0/1: Rx power high alarm; Operating value: 2.9 dBm, Threshold value: 2.5 dBm.
Jul 11 04:03:28.676 edt: %SFF8472-5-THRESHOLD_VIOLATION: Te2/0/1: Rx power high alarm; Operating value: 2.9 dBm, Threshold value: 2.5 dBm. (HS-IDF-A127-2960 X-1-2)
Jul 11 04:13:09.151 edt: %SFF8472-5-THRESHOLD_VIOLATION: Te2/0/1: Rx power high alarm; Operating value: 2.9 dBm, Threshold value: 2.5 dBm.
Jul 11 04:13:30.723 edt: %SFF8472-5-THRESHOLD_VIOLATION: Te2/0/1: Rx power high alarm; Operating value: 2.9 dBm, Threshold value: 2.5 dBm. (HS-IDF-A127-2960 X-1-2)
Jul 11 04:23:11.191 edt: %SFF8472-5-THRESHOLD_VIOLATION: Te2/0/1: Rx power high alarm; Operating value: 2.8 dBm, Threshold value: 2.5 dBm.
Jul 11 04:23:32.809 edt: %SFF8472-5-THRESHOLD_VIOLATION: Te2/0/1: Rx power high alarm; Operating value: 2.8 dBm, Threshold value: 2.5 dBm. (HS-IDF-A127-2960 X-1-2)
Jul 11 04:33:13.248 edt: %SFF8472-5-THRESHOLD_VIOLATION: Te2/0/1: Rx power high alarm; Operating value: 2.8 dBm, Threshold value: 2.5 dBm.
Jul 11 04:33:34.856 edt: %SFF8472-5-THRESHOLD_VIOLATION: Te2/0/1: Rx power high alarm; Operating value: 2.8 dBm, Threshold value: 2.5 dBm. (HS-IDF-A127-2960 X-1-2)
Jul 11 04:43:15.288 edt: %SFF8472-5-THRESHOLD_VIOLATION: Te2/0/1: Rx power high alarm; Operating value: 2.8 dBm, Threshold value: 2.5 dBm.
Jul 11 04:43:36.920 edt: %SFF8472-5-THRESHOLD_VIOLATION: Te2/0/1: Rx power high alarm; Operating value: 2.8 dBm, Threshold value: 2.5 dBm. (HS-IDF-A127-2960 X-1-2)
Jul 11 04:53:17.328 edt: %SFF8472-5-THRESHOLD_VIOLATION: Te2/0/1: Rx power high alarm; Operating value: 2.8 dBm, Threshold value: 2.5 dBm.
Jul 11 04:53:38.974 edt: %SFF8472-5-THRESHOLD_VIOLATION: Te2/0/1: Rx power high alarm; Operating value: 2.8 dBm, Threshold value: 2.5 dBm. (HS-IDF-A127-2960 X-1-2)
Jul 11 05:03:19.368 edt: %SFF8472-5-THRESHOLD_VIOLATION: Te2/0/1: Rx power high alarm; Operating value: 2.9 dBm, Threshold value: 2.5 dBm.
Jul 11 05:03:41.059 edt: %SFF8472-5-THRESHOLD_VIOLATION: Te2/0/1: Rx power high alarm; Operating value: 2.9 dBm, Threshold value: 2.5 dBm. (HS-IDF-A127-2960 X-1-2)
Jul 11 05:13:21.414 edt: %SFF8472-5-THRESHOLD_VIOLATION: Te2/0/1: Rx power high alarm; Operating value: 2.8 dBm, Threshold value: 2.5 dBm.
Jul 11 05:13:43.106 edt: %SFF8472-5-THRESHOLD_VIOLATION: Te2/0/1: Rx power high alarm; Operating value: 2.8 dBm, Threshold value: 2.5 dBm. (HS-IDF-A127-2960 X-1-2)
Jul 11 05:23:23.454 edt: %SFF8472-5-THRESHOLD_VIOLATION: Te2/0/1: Rx power high alarm; Operating value: 2.8 dBm, Threshold value: 2.5 dBm.
Jul 11 05:23:45.160 edt: %SFF8472-5-THRESHOLD_VIOLATION: Te2/0/1: Rx power high alarm; Operating value: 2.8 dBm, Threshold value: 2.5 dBm. (HS-IDF-A127-2960 X-1-2)
Jul 11 05:33:25.519 edt: %SFF8472-5-THRESHOLD_VIOLATION: Te2/0/1: Rx power high alarm; Operating value: 2.9 dBm, Threshold value: 2.5 dBm.
Jul 11 05:33:47.210 edt: %SFF8472-5-THRESHOLD_VIOLATION: Te2/0/1: Rx power high alarm; Operating value: 2.9 dBm, Threshold value: 2.5 dBm. (HS-IDF-A127-2960 X-1-2)
Jul 11 05:43:27.572 edt: %SFF8472-5-THRESHOLD_VIOLATION: Te2/0/1: Rx power high alarm; Operating value: 2.9 dBm, Threshold value: 2.5 dBm.
Jul 11 05:43:49.299 edt: %SFF8472-5-THRESHOLD_VIOLATION: Te2/0/1: Rx power high alarm; Operating value: 2.9 dBm, Threshold value: 2.5 dBm. (HS-IDF-A127-2960 X-1-2)
Jul 11 05:53:29.616 edt: %SFF8472-5-THRESHOLD_VIOLATION: Te2/0/1: Rx power high alarm; Operating value: 2.9 dBm, Threshold value: 2.5 dBm.
Jul 11 05:53:51.342 edt: %SFF8472-5-THRESHOLD_VIOLATION: Te2/0/1: Rx power high alarm; Operating value: 2.9 dBm, Threshold value: 2.5 dBm. (HS-IDF-A127-2960 X-1-2)
Jul 11 06:03:31.656 edt: %SFF8472-5-THRESHOLD_VIOLATION: Te2/0/1: Rx power high alarm; Operating value: 2.9 dBm, Threshold value: 2.5 dBm.
Jul 11 06:03:53.407 edt: %SFF8472-5-THRESHOLD_VIOLATION: Te2/0/1: Rx power high alarm; Operating value: 2.9 dBm, Threshold value: 2.5 dBm. (HS-IDF-A127-2960 X-1-2)
Jul 11 06:13:33.696 edt: %SFF8472-5-THRESHOLD_VIOLATION: Te2/0/1: Rx power high alarm; Operating value: 2.9 dBm, Threshold value: 2.5 dBm.
Jul 11 06:13:55.478 edt: %SFF8472-5-THRESHOLD_VIOLATION: Te2/0/1: Rx power high alarm; Operating value: 2.8 dBm, Threshold value: 2.5 dBm. (HS-IDF-A127-2960 X-1-2)
Jul 11 06:23:35.735 edt: %SFF8472-5-THRESHOLD_VIOLATION: Te2/0/1: Rx power high alarm; Operating value: 2.9 dBm, Threshold value: 2.5 dBm.
Jul 11 06:23:57.514 edt: %SFF8472-5-THRESHOLD_VIOLATION: Te2/0/1: Rx power high alarm; Operating value: 2.8 dBm, Threshold value: 2.5 dBm. (HS-IDF-A127-2960 X-1-2)
Jul 11 06:32:37.849 edt: %SSH-5-SSH2_SESSION: SSH2 Session request from 10.4.1.4 2 (tty = 0) using crypto cipher 'aes256-cbc', hmac 'hmac-sha1' Succeeded
Jul 11 06:32:52.124 edt: %SSH-5-SSH2_USERAUTH: User 'fcscadmin' authentication f or SSH2 Session from 10.4.1.42 (tty = 0) using crypto cipher 'aes256-cbc', hmac 'hmac-sha1' Succeeded
Above log is from a cosmetic bug and it is usually harmless.
See below log. Can you redo your SSH key and see of there is change in the "hmac" CPU usage?
Also, for testing you can delete the SSH completely and use telnet for a period of time and see if you see a difference.
I'd upgrade the firmware first and see if it has any improvements.
