Showing results forĀ
Search instead forĀ
Did you mean:Ā
2960x MGMT didnt respond but data ports are still work
allenblack0308
WS-C2960X-24TS-L
Version 15.2(2)E7
2 stack
Faced with a strange situation, the mgmt port of the device did not respond to the ping of my monitoring software, and netadmin could not ssh in. However, CDP of other devices could see it, and the network service was normal. It returned to normal after 15 minutes. There was no Log, and the CPU usage rate in the past 72 hours has only been 40%. I'm currently at a loss. Please help me. My supervisor is hunting me = =
OK,This gave me a new direction, the monitoring software did not report problems with my MGMT network so I ignored them
5 Replies 5
Mark Elsen
 - I have seen that in the past and think it is a bug ; try this release :
            https://software.cisco.com/download/home/284795737/type/280805680/release/15.2.7E10
  M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Thank you but my supervisor does not accept the upgrade without finding the bug ID. Currently, I use show tech support to TAC.
  - That's something that should be debated in favor of , it is an advisory release and not all fixes get documented as such ,
  M.
       Beauty and terror
      Just keep going
       No feeling is final
DanielP211
Hello!
I would suggest you look for issues at he management firewall/or wherever the L3 MGMT for switches is located.
BR
****Kindly rate all useful posts*****
