2960x serial console problem
kipbenard
Hi Team
I have an issue with 2960x switch, i can console with cisco usb console but  i can console with serial, i wanted
to transfer ios using xmodem,,what could be the issue with the serial console? will appreciate assistance
thanks
Bernard
5 Replies 5
johnd2310
Level 8
Level 8
What is the issue when you try to use the serial console port?
John
**Please rate posts you find helpful**
Hi Johnd
when i connect with serial port i just get a blank screen, but when i use the usb cable it works fine,, dont what the issue is, i have also tried the serial cable with other switches it works fine,but on this one it doesnt work, only the cisco usb consoles works
Bernard
Hi Kipbenard,
Try to take the access of the device using USB and then run the command show run and check whether the line con 0 is enabled or not, if enabled check is there any policy or something running that is not allowing to take the access.
Since you are saying you are able to take the access of other devices with the same cable and same parameters. It might be possible that the console port is faulty.
Shivam Saxena
kipbenard
any asssitance? am stuck and i need to reinstall the ios, is it possible to use the usb console cable to transfer??
shiran.wang
try to reboot your switch and enter MINI IOS model to check if you have a right setting  Baud rate
the current rate should be 9600 N 8 1
