2960X-STACK WITHOU CABLES cisco
caemcaetano
Hello All!
Happy new year!
Is possible create a stack with two WS-C2960X-24TS-L with lanbase license active using sfp and fiber-optics instead the proprietary cisco cables for stack ?
Tks
Mark Malone
Hey you cant stack any switch like that you have to use the correct stacking cables regardless of the license as its a hardware thing not software
you would only be able to connect them via a trunk or access port that way
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages wha2tsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Just to add a bit to what Mark noted, the Cisco stack cables allow the stack to function as one logical unit, but you can interconnect them otherwise, as he also noted, and run them as logically standalone units.
(NB: if I remember correctly, 2960X stack cables run at 10 Gbps.)
