2960X switches are now L3 starting from this release :15.2(6)E
routed physical ports , eigrp, ospf ....etc
hamza.
The 2960x series switches are mainly layer-2 with some limited layer-3 functionality pending the model and the license.
I would not rely on just the output of "sh ip route" Try enabling these features and see if they actually work since you have a LAN Base switch.
I understand that but I would actually test it to verify the document is correct or not.
