300Mpbs WAN speed. What hardware do I need?
xavierloza1
Hello all,
We've just acquired a 300Mpbs/20Mpbs cable line. Shortly after I realized my 2821 router is unable to handle this much bandwidth and it caps out at 150Mpbs download. Let me know which router/switch combination is able to handle 300Mpbs. Also, I'm running Cisco3750G switches as well. Would these switches be enough? Thank you.
(PC) <-->(C3750G)<-->(C2821)<-->(CableModem)
Hitesh Vinzoda
Level 4
Level 4
Have a look at Cisco 4000 series routers, Cisco 3750G should be fine.
Table 4.       Specifications of Cisco 4000 Family Integrated Services Routers
Technical Specifications
Cisco 4451
Cisco 4431
Cisco 4351
Cisco 4331
Cisco 4321
Aggregate Throughput
1 Gbps to
2 Gbps
500 Mbps to
1 Gbps
200 Mbps to
400 Mbps
100 Mbps to
300 Mbps
50 Mbps to
100 Mbps
Full details at http://www.cisco.com/c/en/us/products/collateral/routers/4000-series-integrated-services-routers-isr/datasheet-c78-732542.html
Hitesh
Please rate useful posts.
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
For 320 Mbps of aggregate bandwidth, Cisco recommends a 3945 for 150 Mbps (WAN, i.e. 300 Mbps).  (See attachment.)
Your 3750G has multi-gig capacity, so your 300 Mbps shouldn't be an issue for it, unless it's already highly loaded.
