12-22-2009 10:33 PM - edited 03-06-2019 09:03 AM
We have 32-Bit AS no. , which is not supporting on any of our router/L3 switches cisco devices.
Kindly Suggest ..
Solved! Go to Solution.
12-22-2009 11:01 PM
What is your router/switch model?
You need BGP Support for 4-byte ASN feature.
Update:
You beat me. Not only on these models, but also on:
1941, 2900, 3900, 12000, 7600.
Please reate if this helps.
Eugene.
12-22-2009 10:47 PM
Dear Sudhir,
You hv 32 ASN so that is 4 byte BGP ASN ok
so you need 12.4(24)T IOS for this, it is sopport 1800 , 2800 , 3800 Series Router only and 6500 switch.
which router/Switch are you using at present ??
Vaib...
12-22-2009 11:01 PM
Update:
Eugene.
12-22-2009 11:18 PM
Hii Freindx,
I was trying on cisco 7613 router / Cisco L3 Switches 4500 series & 4900 series , also tried on cisco 7200 series router.
12-22-2009 11:36 PM
What is you sup/rsp for 7600?
For example, you can use this ios'es for rsp720:
| 12.2(33)SRE | ADVANCED ENTERPRISE SERVICES SSH | c7600rsp72043-adventerprisek9-mz.122-33.SRE.bin | 1024 | 256 |
| 12.2(33)SRE | ADVANCED IP SERVICES | c7600rsp72043-advipservices-mz.122-33.SRE.bin | 1024 | 256 |
| 12.2(33)SRE | ADVANCED IP SERVICES SSH | c7600rsp72043-advipservicesk9-mz.122-33.SRE.bin | 1024 | 256 |
| 12.2(33)SRE | IP SERVICES | c7600rsp72043-ipservices-mz.122-33.SRE.bin | 1024 | 256 |
| 12.2(33)SRE | IP SERVICES SSH | c7600rsp72043-ipservicesk9-mz.122-33.SRE.bin | 1024 | 256 |
For 7200 you can use this ios'es:
| 12.2(33)SRE | ADVANCED ENT SERVICES W/SNA SWITCH | c7200-adventerprisek9_sna-mz.122-33.SRE.bin | 512 | 64 |
| 12.2(33)SRE | ADVANCED ENTERPRISE SERVICES | c7200-adventerprisek9-mz.122-33.SRE.bin | 512 | 64 |
| 12.2(33)SRE | ADVANCED IP SERV W/LAWFUL INTERCEPT | c7200-advipservicesk9_li-mz.122-33.SRE.bin | 512 | 64 |
| 12.2(33)SRE | ADVANCED IP SERVICES | c7200-advipservicesk9-mz.122-33.SRE.bin | 512 | 64 |
| 12.2(33)SRE | SP SERVICES | c7200-spservicesk9-mz.122-33.SRE.bin | 512 | 64 |
Please rate if this helps, Eugene.
