350 aironet bridge access issues
batesse
I have been given a configureded 350 seires bridge (static Ip address) that I am trying to install on my home network. But when using the device Mac address with the Cisco IPSU software to get the ip address assigned to the bridge, there is no reply. How can I reset this bridge to DHCP so I can install it on my home network?
thanks
desai.jaideep
Level 5
Level 5
(1)Are you using the bridge with PoE or AC adapter?
(2)There is a reset button on your bridge.Try inserting a pin into that and see.
(3)Third option is to connect through console and reset that.
Pls visit the following page for full troubleshooting doc.
http://www-tss.cisco.com/eservice/compass/common/activities/password_aironet.htm
JD
Hi, answers to your answers:
1. AC Adapter
2. doesn't work - there doesn't seem to be a button to push when I instert a paper clip???
3. I don't have a 9pin cable
