3500XL v 12.0(5)
Joli Martinez
I have a POE switch running 12.0(5).  I have port 24 connected as a trunk connected to the main switch.  I need to add an ip address on vlan 21 which is where the network vlan is.  I created it but I can not seem to enable it.  I have issued the no shut command several times, but doing "sh ip int brief" it keeps showing up as administively down.
[code]
poeswitch#sh run
Building configuration...
Current configuration:
version 12.0
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname poeswitch
spanning-tree uplinkfast
ip subnet-zero
no ip domain-lookup
interface FastEthernet0/1
switchport access vlan 21
switchport voice vlan 10
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
switchport mode trunk
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface VLAN1
no ip directed-broadcast
no ip route-cache
interface VLAN10
no ip route-cache
shutdown
interface VLAN21
ip address 10.105.21.250 255.255.255.0
no ip route-cache
shutdown
line con 0
logging synchronous
transport input none
stopbits 1
line vty 0 4
logging synchronous
login local
transport input telnet
line vty 5 15
login
end
[/code]
  Does it let you shutdown the vlan 1 SVI and then do a no shut on the vlan 21 SVI ?  You won't be ablle to ping it unless the vlan 21 is in  a admin up state.
13 Replies 13
Reza Sharifi
Did you also create layer-2 vlan?
vlan 21
name test
also you need to add this vlan to the trunk port
this way all vlan are part of the trunk
yup all that is done.  I have posted the sh run as well.
Is anything connected to interface interface FastEthernet0/1?
can you post "sh ip int bri fa0/1"?
true... The VLAN interface wont come up until you have something connected to some port in that VLAN. atleast 1 port in that vlan has to be up.
Pawan Sharma
http://www.ebrahma.com
Pawan Sharma
https://itgears.io
   The SVI  should be up if the layer 2 vlan was actually created seeing that you have all vlans allowed across the trunk . Please post a show vlan  and a show ip int brief . Also do a shutdown on the vlan 1 SVI and a no shut on the Vlan 21 SVI .  You can only have a single SVI active on a Layer 2 only switch , this address is to manage the switch only and has no function in any routing , I assume there is another device doing the routing for vlan 21. If you have a device on F0/1 it should be able to get outside if the trunk is up and active , you just won't be able to manage the switch as long as the SVI for  for vlan 21 is in a shutdown state.
there is a device plugged into fa0/1 but it can not connect anywhere.  also that port is part of vlan21 and vlan 21 is still down. even after issuing no shut
[code]
poeswitch#sh vlan
VLAN Name                             Status    Ports
1    default                          active    Fa0/2, Fa0/3, Fa0/4, Fa0/5,
                                                Fa0/6, Fa0/7, Fa0/8, Fa0/9,
                                                Fa0/10, Fa0/11, Fa0/12, Fa0/13,
                                                Fa0/14, Fa0/15, Fa0/16, Fa0/17,
                                                Fa0/18, Fa0/19, Fa0/20, Fa0/21,
                                                Fa0/22, Fa0/23, Gi0/1, Gi0/2
10   VOICE                            active
21   NETWORK/SERVERS                  active    Fa0/1
30   WORKSTATIONS                     active
40   QA                               active
[/code]
What is the pc default gateway set as ?  It should be the address of whatever device is doing the routing for vlan 21 .  Has all the configuration for the routing for vlan 21 been completed on the device that is doing the routing? If you do a show int trunk does it show vlan 21 as being allowed acros the trunk ?
the switch does not have sh int trunk command.  yes the pc has the default gw set on it, but it wont matter if vlan21 is administratively down.
  Your assumption is not correct that SVI can be down and it still should be able to get out if the trunk is working ok . That has nothing to do with routing on the 3500 , it is being routed elsewhere , it is for switch management only so you can telnet to the switch.  Your pc gateway should not be pointed at the address on the 3500 ..  What happens if you do a shutdown on vlan 1 and then a no shutdown on vlan 21 ?  Vlan1 has to be shutdown first before doinmg a no shut on vlan 21.   That is a very old switch and one of the first that cisco ever created and they work a little different than current IOS switches.   It's possible that being so old that vlan 1 can only be used to manage the switch but that should not keep you from having a device in vlan 21 trunked out to the  L3 or router that is doing the routing for vlan 21.
Joli Martinez
all vlans are down down except for vlan1 which i dont want to use
[code]
poeswitch#sh ip int brief
Any interface listed with OK? value "NO" does not have a valid configuration
Interface                  IP-Address      OK? Method Status                Protocol
VLAN1                      unassigned      NO  unset  up                    up
VLAN10                     unassigned      YES unset  administratively down down
VLAN21                     10.105.21.250   YES manual administratively down down
VLAN30                     unassigned      YES unset  administratively down down
FastEthernet0/1            unassigned      YES unset  up                    up
FastEthernet0/2            unassigned      YES unset  up                    up
FastEthernet0/3            unassigned      YES unset  up                    up
[/code]
Joli Martinez
Now I can get out to the internet on fa0/1 but i can not ping the 21.250 ip which is need in order to telnet/ssh into the switch.
Joli Martinez
Yes that worked,  I was able to shut down vlan1 and turn vlan 21 up.
