3548 secondary ip on VLAN interface?
yakimus.voks
Why cannot I issue a secondary ip on VLAN interface?
swzg3_11#sh run int vlan 5
interface VLAN5
ip address 10.7.1.53 255.255.255.0
no ip directed-broadcast
no ip route-cache
end
swzg3_11#conf t
swzg3_11(config)#int vlan 5
swzg3_11(config-subif)#ip add 10.7.0.2 255.255.255.192 ?
  secondary  Make this IP address a secondary address
swzg3_11(config-subif)#ip add 10.7.0.2 255.255.255.192 secondary
swzg3_11(config-subif)#end
interface VLAN5
no ip route-cache
end
6 Replies 6
cadet alain
what does sh ip int vlan5 reports?
Regards.
Alain.
swzg3_11#sh ip int vlan 5
VLAN5 is up, line protocol is up
  Internet address is 10.7.1.53/24
  Broadcast address is 255.255.255.255
  Address determined by non-volatile memory
  MTU is 1500 bytes
  Helper address is not set
  Directed broadcast forwarding is disabled
  Outgoing access list is not set
  Inbound  access list is not set
  Proxy ARP is enabled
  Security level is default
  Split horizon is enabled
  ICMP redirects are always sent
  ICMP unreachables are always sent
  ICMP mask replies are never sent
  IP fast switching is disabled
  IP fast switching on the same interface is disabled
  IP Null turbo vector
  IP multicast fast switching is disabled
  IP multicast distributed fast switching is disabled
  Router Discovery is disabled
  IP output packet accounting is disabled
  IP access violation accounting is disabled
  TCP/IP header compression is disabled
  RTP/IP header compression is disabled
  Probe proxy name replies are disabled
  Policy routing is disabled
  Network address translation is disabled
  WCCP Redirect outbound is disabled
  WCCP Redirect exclude is disabled
  BGP Policy Mapping is disabled
glen.grant
   A 3548 is a layer 2 only ancient switch .  That SVI is used to manage the switch only  and  cannot do any routing so hence you would never have a secondary ip on the switch just to manage it  and why it is not taking that command .  Cisco had a habit of leaving commands in the IOS even though they did not work .
That's really weird
I got a 3COM 3900 - also an ancient layer2 only switch -  but it allows to create several interfaces in different vlans and/or several ip-s in one vlan. Cant believe that cisco does not allow same features on the same epoch of switches ))
You can create multiple VLANs with a 3500XL but you can only have one active VLAN management IP address at any one time.
  I think you are getting layer 2 and 3 mixed up .  The cisco box can have many vlans created (layer 2) but it is not a layer 3 routing switch so there is no reason to have more than a single address on the switch to manage it as all routing is done on a different layer 3 device  which where all routing configuration would take place whether its a single  subnet or a subnet with multiple secondary ip's.
