3550 IOS
drnteam
I am planning to do an IOS update on 3550 switch which is currently under EMI version. Is it possible to put the SMI version IOS on this.
Istvan_Rabai
Level 7
Level 7
Yes, it is possible to put the SMI version on the 3550 switch, but actually you will downgrade it.
The EMI version has the advanced routing protocols like EIGRP, OSPF and BGP in it.
The SMI version has only RIP, and if I know well, some versions support EIGRP stub routing.
Cheers:
Istvan
glen.grant
Really makes no sense to do this , any function SMi has EMI has that as well as advanced routing protocols.
I have a 3550 switch with EMI /SMI versions, can i replace it with 12.2(25)SEE versions IOS.
Yes, you can.
You can check it on the Cisco Feature navigator:
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
Cheers:
Istvan
