3550 switch
gurkamal01
I am preparing for CCNP and my aim CCIE later sometime probably i will prepare for BSCI and BCMSN first
I have two questions
I already have 3 2620 routers and 2 2950 switches and one 2520 frame relay router
DO i need to buy A 3550 switch
i have an option of buying one but i dont know if it is of right configuration
here is its sh version command
SW1>sh version
IOS (tm) C3550 Software (C3550-I5Q3L2-M), Version 12.1(19)EA1a, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2003 by cisco Systems, Inc.
Compiled Tue 09-Dec-03 03:21 by yenanh
Image text-base: 0x00003000, data-base: 0x0080DDAC
ROM: Bootstrap program is C3550 boot loader
SW1 uptime is 4 minutes
System image file is "flash:c3550-i5q3l2-mz.121-19.EA1a/c3550-i5q3l2-mz.121-19.EA1a.bin"
cisco WS-C3550-24 (PowerPC) processor (revision E0) with 65526K/8192K bytes of memory.
Processor board ID CAT0636Y0EK
Last reset from warm-reset
Bridging software.
Running Layer2/3 Switching Image
Ethernet-controller 1 has 12 Fast Ethernet/IEEE 802.3 interfaces
Ethernet-controller 2 has 12 Fast Ethernet/IEEE 802.3 interfaces
Ethernet-controller 3 has 1 Gigabit Ethernet/IEEE 802.3 interface
Ethernet-controller 4 has 1 Gigabit Ethernet/IEEE 802.3 interface
24 FastEthernet/IEEE 802.3 interface(s)
2 Gigabit Ethernet/IEEE 802.3 interface(s)
The password-recovery mechanism is enabled.
384K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:0A:B7:D2:15:00
Motherboard assembly number: 73-5700-08
Power supply part number: 34-0966-02
Motherboard serial number: CAT063403UN
Power supply serial number: DCA06310J34
Model revision number: E0
Motherboard revision number: D0
Model number: WS-C3550-24-SMI
System serial number: CAT0636Y0EK
Configuration register is 0x10F
Q.1 Is the 3550 switch of good configuration Should i buy the 3550 switch
I buyed the lab companion book of BCMSN and tells me to have a couple of 3560 and and a couple of 2960 switches and a bunch of WLAP
setting up this lab is lot of mmoney
Q.2 can i buy 2 3550 instaed of 2 3560
and use 2950 instead of 2 2960
or renting the rack would be a better option
Hi There
AS I said, I would recommend that you copy the IOS image that is currently on the router to your PC/laptop, so that you have a backup copy before you start upgrading the Flash memory.
Then if your router has both SIMM slots filled with small SIMMS, it is possible that these are configured as 1 larger "Virtual" Flash area, on which the IOS is installed.
In this case you will replace 1 or both SIMMS with larger SIMMS. So if your IOS is split across 2 SIMMS and you remove 1 of them or replace both of then, you will render your router useless as it will no longer have a valid IOS image.
You would then have to copy the IOS image that you stored on your PC/Laptop back onto the router.
HTH & again thanks for the rating.
Best Regards,
Michael
9 Replies 9
keeleym
Level 5
Level 5
Hi There
This is an SMI model with a SMI IOS. It is layer 3, but will only run static routing and RIP. No EIGRP, OSPF or BGP.
I would say that you could probably get by without a layer 3 switch for your studies, or rent some reack time to get some hands on practice.
However if you are going to buy a 3550 for your home lab, then I would advise picking up at least an SMI model with EMI IOS or a full EMI model.
The IOS loaded here is c3550-i5q3l2-mz.121-19.EA1a/c3550-i5q3l2-mz.121-19.EA1a.bin
The "i5" in the name after the c3500 denotes SMI code.
EMI code will have "i9".
Also you can see whether the switch is an SMI or EMI model at the bottom of the "show version" output.
Look for "Model number: WS-C3550-24-SMI" four lines from the bottom.
Best Regards,
Michael
hi
thanks for your advice
i just accidently bought a 2620 router from ebay without knowing the config
if it has low flash and dram can i upgrade them without changing the IOS
How does that part work
please advice
Hi There
Yes you can. Inside the 2600 there is 1 space for the DRAM and 2 spaces for the Flash memory.
What memory (DRAM & Flash) has the router got at present? Also open the router up and look inside. Is there 1 Flash SIMM or two?
I would start by saving the current IOS off to a PC/Laptop, so if anything goes wrong you have a backup copy.
Then, if the router only has 1 Flash SIMM, this means that the IOS is on that 1 SIMM so you should be able to add the second Flash SIMM without any trouble.
If the router has two Flash SIMMS, then it possible (depending on the size of the IOS image) that your IOS is using both SIMMS. This would entail upgrading the Flash and then restoring you backed up IOS image back on to the router.
Upgrading the DRAM will not affect the IOS.
You will need to have a TFTP server application on your PC/Laptop. You can download the Cisco recommended application here http://tftpd32.jounin.net/tftpd32.html
P.S. Thanks for the Rating, much appreciated.
Best Regards,
Michael
Thanks for your expert advice which you do always
I am sorry i didnot uderstand by mentioned above "This would entail upgrading the Flash and then restoring you backed up IOS image back on to the router"
Hi There
Best Regards,
Michael
i highly appreciate your response michael
i have never worked in a production enviroment i wanted to know what are the benchmark routers and switches used in most of the companies
how are they connected to the wan links
do they have CSU/DSU, NT1's connected to the serial interfaces or they are inbiult in the router
what are the WAN hardwars used in the production environment
appreciate any response
thanx!
Hi, michale
just a minor correction for 2600:
2600 non-xm router has one simm slot for system flash and two dimm slots for DRAMs.
Please refer the following page:
http://www.cisco.com/univercd/cc/td/doc/product/access/acs_mod/cis2600/cnfgnote/2600mem.htm#34451
Cheers
SSLIN
Hi SSLIN
Yep, you are correct. My mistake. Thank you for pointing this out. Much appreciated.
Gursaran: I am afraid all my networking experience is on LAN's. I have never worked with/on a WAN, unless my home ADSL connection counts :) Any WAN knowledge I may have is purely from my studies. So I would not the best to advise as to what equipment is used in the real world and how it connects to the WAN. The only thing that I can offer is that I know that the company I work for uses Cisco 6509's as their Core switches/routers.
Best Regards,
Michael
hi
i apreciate your response
i wanted to know that i have cable internet at home how can i access my router from office
my router is a 2620 which has 1-wicT and isdn briU in its slots
where do i connect the internet connector which is coming from a modem
what is Isdn BRI U module used for?
and what is the AUX port on the
router used for?
Please help me out
