3560 doesn't allow me to configure 802.1X
guibarati
Level 4
Level 4
Hi, I have an Catalyst 3560 with IP Services IOS and it doesn't allow me to configure 802.1x port-control.
it doesn't accept the commands.
I've already checked in feature navigator and the version i'm using support it, i tried 2 more versions too to be sure it was not a version problem.
Is there samething i'm missing?
nterface FastEthernet0/15
switchport access vlan 10
switchport mode access
Switch(config)#int fa 0/15
Switch(config-if)#dot1x ?
  credentials     Credentials profile configuration
  default         Configure Dot1x with default values for this port
  max-reauth-req  Max No.of Reauthentication Attempts
  max-req         Max No.of Retries
  max-start       Max No. of EAPOL-Start requests
  pae             Set 802.1x interface pae type
  supplicant      Configure supplicant parameters
  timeout         Various Timeouts
As you can see it doesn't shows me the "dot1x port-control" option
The feature navigator show for my hardware and software version:
IEEE 802.1x - Auth Fail Open IEEE 802.1x - Auth Fail VLAN IEEE 802.1X - Flexible Authentication IEEE 802.1x - VLAN Assignment IEEE 802.1x Authenticator IEEE 802.1x Fallback support IEEE 802.1x Multi-Domain Auth with Voice VLAN Assignment IEEE 802.1X Multi-Domain Authentication IEEE 802.1x RADIUS Accounting IEEE 802.1x Readiness Check IEEE 802.1x Supplicant Support for EAP-FAST IEEE 802.1x Supplicant Support for MD5 IEEE 802.1X Voice Aware Security Violations IEEE 802.1x with Port Security
guibarati
Level 4
Level 4
Just realized the commands i'm trying to use are hide/oculted.
I've tried it as hide commands before updating the IOS, didnt work then i figured it was not hide, after upgrading didn't try as hide but it is!
