03-14-2012 01:50 PM - edited 03-07-2019 05:34 AM
Can anyn one help how to solve this problem.This switch has been stucked.
Traceback= 482608 4C00E8 758DA8 752FEC
%SYS-3-CPUHOG: Task is running for (1895265)msecs, more than (2000)msecs (90/1),
process = Hulc Storm Control.
-Traceback= 482610 4C00E8 758DA8 752FEC
%SYS-3-CPUHOG: Task is running for (1897547)msecs, more than (2000)msecs (90/1),
-Traceback= 4C00F0 758DA8 752FEC
Base ethernet MAC Address: 00:13:80:4f:af:00
Xmodem file system is available.
The password-recovery mechanism is enabled.
Initializing Flash...
flashfs[0]: 353 files, 5 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 32514048
flashfs[0]: Bytes used: 7026176
flashfs[0]: Bytes available: 25487872
flashfs[0]: flashfs fsck took 12 seconds.
...done Initializing Flash.
Boot Sector Filesystem (bs) installed, fsid: 3
done.
Loading "flash:c3560-ipbase-mz.122-25.SEB4/c3560-ipbase-mz.122-25.SEB4.bin"...@@
File "flash:c3560-ipbase-mz.122-25.SEB4/c3560-ipbase-mz.122-25.SEB4.bin" uncompr
essed and installed, entry point: 0x3000
executing...
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco IOS Software, C3560 Software (C3560-IPBASE-M), Version 12.2(25)SEB4, RELEA
SE SOFTWARE (fc1)
Copyright (c) 1986-2005 by Cisco Systems, Inc.
Compiled Tue 30-Aug-05 14:19 by yenanh
Image text-base: 0x00003000, data-base: 0x00C71990
Initializing flashfs...
flashfs[1]: 353 files, 5 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 32514048
flashfs[1]: Bytes used: 7026176
flashfs[1]: Bytes available: 25487872
flashfs[1]: flashfs fsck took 1 seconds.
flashfs[1]: Initialization complete....done Initializing flashfs.
POST: CPU MIC register Tests : Begin
POST: CPU MIC register Tests : End, Status Passed
POST: PortASIC Memory Tests : Begin
POST: PortASIC Memory Tests : End, Status Passed
POST: CPU MIC PortASIC interface Loopback Tests : Begin
POST: CPU MIC PortASIC interface Loopback Tests : End, Status Passed
POST: PortASIC RingLoopback Tests : Begin
POST: PortASIC RingLoopback Tests : End, Status Passed
POST: PortASIC CAM Subsystem Tests : Begin
POST: PortASIC CAM Subsystem Tests : End, Status Passed
POST: PortASIC Port Loopback Tests : Begin
POST: PortASIC Port Loopback Tests : End, Status Passed
Waiting for Port download...Complete
cisco WS-C3560-48TS (PowerPC405) processor (revision D0) with 118784K/12280K byt
es of memory.
Processor board ID FHK1016Y035
Last reset from power-on
1 Virtual Ethernet interface
48 FastEthernet interfaces
4 Gigabit Ethernet interfaces
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 00:13:80:4F:AF:00
Motherboard assembly number : 73-9898-05
Power supply part number : 341-0097-01
Motherboard serial number : CAT09110S18
Power supply serial number : DCA090302MK
Model revision number : D0
Motherboard revision number : A0
Model number : WS-C3560-48TS-S
System serial number : FHK1016Y035
SFP Module assembly part number : 73-7757-02
SFP Module revision Number : A0
SFP Module serial number : CAT09080E80
Top Assembly Part Number : 800-26162-02
Top Assembly Revision Number : C0
Version ID : V02
CLEI Code Number : COMMJ00ARB
Hardware Board Revision Number : 0x01
Switch Ports Model SW Version SW Image
* 1 52 WS-C3560-48TS 12.2(25)SEB4 C3560-IPBASE-M
03-19-2012 02:44 PM
Are you referring to the CPUHOG messages? They seem to be being caused by the storm control process. CPUHOG is an indication that a process has taken over the CPU for more than 2 milliseconds, which is a no-no.
Type "show processes" to determine the status of that process when the IOS is booted.
03-19-2012 02:54 PM
You got Traceback errors.
Did the switch reboot due to the Traceback or did you reboot the switch?
If this is so, I noticed that you are using a very, very ancient IOS. Can I ask if you upgrade to, say, 12.2(55)SE4 or 12.2(55)SE5?
