3560 switch, trunk issue
scott.bridges
3560 connected to 4550 via SFP trunk
3560
Gi0/3     connectedto G6/1   connected    trunk      a-full a-1000 1000BaseSX SFP
interface GigabitEthernet0/3
description connectedto G6/1
switchport trunk native vlan 500
switchport trunk allowed vlan 100,200,300,400,500,800
switchport mode trunk
no ip address
The link light on the 4550 Gi6/4 is solid green, but
The link light on the 3560 Gi0/3 goes from amber to green about once a second.
I haven't tried on all ports, but on a couple of the access-ports the connection to the rest of the network (through the trunk) is slow or non-existent (times out).
I originally had it on 3560 port Gi0/2 and the console was logging "Gi0/2 LinkDown | Gi0/2 Link Up" messages (i'm guessing once every 15 seconds, but more random).  Since I moved the trunk to Gi0/3, the console messages do not show up, but the link light still goes from green to amber.
Any ideas?  I've taken out the fiber, doesn't look dirty.  Canned Air cleaned.
-Scott
5 Replies 5
Jerry Ye
Have you tried swapping SFP?
jerry
Leo Laohoo
What's the distance between both appliance.  Sounds like the distance is further than the SFP can support.
Swapping SPF?
I'm sorry, I'm not that familiar with SPF.  What do you mean?  Crossing the pairs?
The 4500 is in the basement, the 3560 is on the 2nd floor.  It has worked fine this way for about four years now.
Think it could have gone "bad"?
Maybe I should rephrase it. Have you change your fiber transceiver (SFP - small form pluggable).
jerry
krishnakumarr
Pl closely monitor the speed mismatch or spanning tree flapping or foword/blocking this port
show interface gi0/3
show spanning-tree vlan
regards
krishna kumar
