06-22-2009 10:02 AM - edited 03-06-2019 06:23 AM
all,
I have a small shop. we are thinking of add another internet service here. Our current one is no longer trusted. My question is Can I use a 3560 with IPS image to connect the two ISP. Can i run load balance on the 3560 switch
06-22-2009 10:19 AM
It depends. Believe at L3, 3560 supports most "standard" routing features, includes those that support multi-path routing, but there's often more involved when moving from one ISP to multiple ISPs. So, a 3560 may, or may not, be suitable in your instance.
06-22-2009 10:37 AM
Obi,
IP services image? Are you connecting 2 routers/ISPs with cisco 3560 switch? The easy way is to add 2 default routes on it. Then you do NAT on the routers.
C3560 can't do NAT. Does it still meet your requirements? If so,you can use it.
HTH,
Toshi
06-24-2009 08:10 AM
The ISPs are Ethernet handoff. My plan was to connect them both to the 3560 switch and create a small network between the switch and my ASA firewall.
06-24-2009 08:16 AM
Obi,
Like I mentioned, Cisco 3560 switch can't do NAT. So you can use ASA to do so. ASA can't do PBR. You may think of creating 2 interfaces or subinterfaces on ASA to separate 2 ISPs then do 2 default routes.
HTH,
Toshi
