3560-X PoE stuck in loop on startup
hartsellda
I have a Catalyst 3560-X PoE that suddenly stopped working.  I plugged in via console and below is the output I received.  It scrolls constantly and I am unable to enter ROMMON mode or stop it from scrolling.  Has anyone experienced this before or might you know what the problem is?  I've read of a possible problem with the IOS version but I'm unable to verify due to not being able to stop the scrolling.  Any help would be appreciated.
Switch uptime is 4 minutes, 4 seconds
cisco WS-C3560X-24P (PowerPC405) processor (revision A0) with 262144K bytes of m
emory.
Processor board ID FDO1522R2AY
00:00:45 UTC Mon Mar 1 1993: Unexpected exception to CPUvector 700, PC = FFFFFF
2C
-Traceback= FFFFFF2C
Cisco IOS Software, C3560E Software (C3560E-UNIVERSALK9-M), Version 12.2(55)SE3,
RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Thu 05-May-11 15:57 by prod_rel_team
Debug Exception (Could be NULL pointer dereference) Exception (0x2000)!
SRR0 = 0x01371580  SRR1 = 0x00029230  SRR2 = 0x01E234E8  SRR3 = 0x00029230
ESR = 0x00000000  DEAR = 0x00000000  TSR = 0x84000000  DBSR = 0x01000000
CPU Register Context:
Vector = 0x00002000  PC = 0x01E234E8  MSR = 0x00029230  CR = 0x50000033
LR = 0x01E23EAC  CTR = 0x01DDF064  XER = 0xA0000010
R0 = 0x00000000  R1 = 0x041A7308  R2 = 0x00000000  R3 = 0x00000001
R4 = 0x00000035  R5 = 0x00000001  R6 = 0x041A73B0  R7 = 0x00000000
R8 = 0x00000000  R9 = 0x00000000  R10 = 0x00000008  R11 = 0x03880000
R12 = 0x50000003  R13 = 0x0B98279C   R14 = 0x0174A7FC  R15 = 0x00000000
R16 = 0x00000000  R17 = 0x00000000  R18 = 0x00000000  R19 = 0x00000000
R20 = 0x00000000  R21 = 0x00000000  R22 = 0x00000000  R23 = 0x041A73B0
R24 = 0x00000000  R25 = 0x041A73B0  R26 = 0x00000000  R27 = 0x00000001
R28 = 0x00000000  R29 = 0x00000035  R30 = 0x03B30414  R31 = 0x00000000
Stack trace:
PC = 0x01E234E8, SP = 0x041A7308
Frame 00: SP = 0x041A7348    PC = 0x01358D9C
Frame 01: SP = 0x041A7370    PC = 0x01E23EAC
Frame 02: SP = 0x041A73D0    PC = 0x01DDF0FC
Frame 03: SP = 0x041A73F0    PC = 0x017F9160
Frame 04: SP = 0x041A7408    PC = 0x0174AE80
Frame 05: SP = 0x041A7438    PC = 0x0172337C
Frame 06: SP = 0x041A7440    PC = 0x0174A814
Frame 07: SP = 0x041A7448    PC = 0x01EFBC68
Frame 08: SP = 0x00000000    PC = 0x01EF26E0
7 Replies 7
Leo Laohoo
Try downloading 12.2(55)SE6.
You can use a USB flash drive (not a portable USB-HDD) to boot the IOS from the USB stick.
Thank you for the suggestion leolaohoo.  Unfortunately, I am unable to stop the scrolling so I can enter ROMMON mode. Without entering ROMMON mode, I cannot boot from the USB stick.  Upon startup, the boot process hangs for about 30 seconds and then immediately jumps into the startup process before settling into the scrolling portion I have posted above.  I cannot break or pause the process.  Any other suggestions would be appreciated.  Thanks again!
Power off the appliance.
Hold down the Mode button.
Still holding the mode button, power up the appliance.
When you see the prompt, enter the command flash_init.
To boot from USB, use the command boot usbflash0:iOS.bin
Thanks leolaohoo.  I was able to get to ROMMON mode by doing what you suggested and I was able to load the new iOS but upon completion of the load, the scrolling restarted.  I verified that the new iOS was the version loaded.  I believe it to be a possible hardware issue since it doesn't matter which iOS is loaded.  This one may be headed for the junk heap.  Thanks again for all of you help leolaohoo.
If you have a valid Service Contract, you can contact your vendor and get the appliance RMA-ed.
I am having the same issue... Is there any work around other than RMA?
Create a new thread and post entire boot-up process.
