3560-X ROMMON Mode
girish.patni
Beginner
Beginner
I have a 3560 in a remote lab.I needed to bring the ROMMON mode.
But the switch doesn't accept the break sequence and boots normally.
Is there any way to bring this switch to ROMMON mode apart from using the MODE button physically in the lab .
Girish
2 Accepted Solutions
amikat
Rising star
Rising star
If you are trying to get into the boot loader (ie. "switch:" prompt) you can achieve this via the "boot manual" global configuration command (then save the config and reload). Please note that you can access the boot loader through the switch console only so be careful as you are dealing with the remote lab box.
Best regards,
Antonin
Leo Laohoo
VIP Community Legend VIP Community Legend
Since this is a REMOTE site, rename the IOS and remove the BIN file extension.   So when the exercise is finish, instruct someone to put the BIN file extension back and reload the switch.
5 Replies 5
nkarpysh
Try changin config register to 0x2120 - this should instruct switch to boot int ROMMON directly. Or delete your current IOS file (as alst resort option) to fall into rommon.
Conf reg is change in conf t:
conf t
config-reg 0x2120
end
wr mem
Nik
HTH,
Niko
