Join Customer Connection to register!
2554
alabedekenny
Beginner
3560G L3 Routing Issues
Hi everyone,
I need help on what seems to be simple but driving me crazy.
I have a new 3560G to set up a small network for a remote site. I configured the vlan and an SVI as the gateway. The switch is also the DHCP server for the LAN. I configured Gi0/2 as L3 port, connecting to the nearest neighbor. My network runs EIGRP so i advertised the routes into the EIGRP process. The switch forms EIGRP neighbors and learns all routes in the enterprise network. The problems I'm having now are:
1. The switch learns all routes in my enterprise LAN and can ping devices in the enterprise LAN, but I can’t ping any interface on the switch from the enterprise LAN.
2. I noticed that despite the fact that users can get IP address automatically from the switch, they cannot connect to the enterprise network. They can ping only the IP addresses local on the switch, but not any other IP address beyond the switch, although my laptop (ONLY MMY LAPTOP) could connect normally and ping remote IPs.
Could this be a CEF issue? Since CEF is enabled by default???
Please see the “debug ip packet details” and relevant configs attached
The IOS version (Cisco IOS Software, C3560 Software (C3560-IPSERVICES-M), Version 12.2(50)SE5, RELEASE SOFTWARE (fc1)
DEBUG OUTPUT
IP: s=172.27.100.21 (Vlan27), d=172.41.201.2, len 60, stop process pak for forus packet
ICMP type=8, code=0
IP: s=172.41.201.2 (local), d=172.27.100.21, len 60, local feature
ICMP type=0, code=0, RCLI(7), rtype 0, forus FALSE, sendself FALSE, mtu 0
ICMP type=0, code=0, Local Clustering(8), rtype 0, forus FALSE, sendself FALSE, mtu 0
FIBipv4-packet-proc: route packet from (local) src 172.41.201.2 dst 172.27.100.21
FIBipv4-packet-proc: packet routing succeeded
IP: tableid=0, s=172.41.201.2 (local), d=172.27.100.21 (Vlan27), routed via FIB
IP: s=172.41.201.2 (local), d=172.27.100.21 (Vlan27), len 60, sending
ICMP type=0, code=0
IP: s=172.41.201.2 (local), d=172.27.100.21 (Vlan27), len 60, output feature
ICMP type=0, code=0, Check hwidb(68), rtype 1, forus FALSE, sendself FALSE, mtu 0
IP: s=172.41.201.2 (local), d=172.27.100.21 (Vlan27), len 60, sending full packet
ICMP type=0, code=0
IP: s=172.27.100.21 (Vlan27), d=172.41.201.2, len 60, input feature
ICMP type=8, code=0, MCI Check(62), rtype 0, forus FALSE, sendself FALSE, mtu 0
FIBipv4-p
FMN_ROM_OIL_IB(config)#acket-proc: route packet from Vlan27 src 172.27.100.21 dst 172.41.201.2
FIBfwd-proc: Default:172.41.201.2/32 receive entry
FIBipv4-packet-proc: packet routing failed
IP: s=172.27.100.21 (Vlan27), d=172.41.201.2, len 60, rcvd 2
ICMP type=8, code=0
ICMP type=8, code=0
ICMP type=0, code=0
ICMP type=0, code=0
IP: s=172.20.200.35 (local), d=224.0.0.10 (Loopback0), len 60, local feature, proto=88, RCLI(7), rtype 0, forus FALSE, sendself FALSE, mtu 0
IP: s=172.20.200.35 (local), d=224.0.0.10 (Loopback0), len 60, local feature, proto=88, Local Clustering(8), rtype 0, forus FALSE, sendself FALSE, mtu 0
IP: s=172.20.200.35 (local), d=224.0.0.10 (Loopback0), len 60, sending broad/multicast, proto=88
IP: s=172.20.200.35 (local), d=224.0.0.10 (Loopback0), len 60, sending full packet, proto=88
IP: s=172.20.200.35 (Loopback0), d=224.0.0.10, len 60, input feature, proto=88, MCI Check(62), rtype 0, forus FALSE, sendself FALSE, mtu 0
FIBipv4-packet-proc: route packet from Loopback0 src 172.20.200.35 dst 224.0.0.10
FIBfwd-proc: Default:224.0.0.0/24 receive entry
IP: s=172.20.200.35 (Loopback0), d=224.0.0.10, len 60, rcvd 2, proto=88
IP: s=172.20.200.35 (Loopback0), d=224.0.0.10, len 60, stop process pak for forus packet, proto=88
FIBipv4-packet-proc: route packet from Vlan27 src 172.27.100.21 dst 172.41.201.2
FMN_ROM_OIL_IB(config)#g failed
ICMP type=8, code=0
ICMP type=8, code=0
ICMP type=0, code=0
FMN_ROM_OIL_IB(config)#.27.100.21 (Vlan27), len 60, sending full packet
ICMP type=0, code=0
ICMP type=8, code=0
ICMP type=8, code=0
ICMP type=0, code=0
ICMP type=0, code=0
CONFIGS
ip routing
ip dhcp pool ROM
network 172.27.100.0 255.255.255.0
default-router 172.27.100.254
dns-server 172.20.180.9 172.20.180.10
! interface Loopback0
ip address 172.20.200.35 255.255.255.255
interface GigabitEthernet0/1
description ***LINK TO MAJI, NOT CONNECTED YET ***
interface GigabitEthernet0/2
description ***LINK TO IBADA***
no switchport
ip address 172.41.201.2 255.255.255.0
spanning-tree portfast
interface GigabitEthernet0/3
interface GigabitEthernet0/4
interface GigabitEthernet0/5
switchport access vlan 27
switchport mode access
interface GigabitEthernet0/6
interface GigabitEthernet0/25
interface GigabitEthernet0/26
interface GigabitEthernet0/27
interface GigabitEthernet0/28
interface Vlan1
no ip address
shutdown
interface Vlan27
ip address 172.27.100.254 255.255.255.0
router eigrp 55
no auto-summary
network 172.20.200.35 0.0.0.0
network 172.27.100.254 0.0.0.0
network 172.41.201.0 0.0.0.255
ip classless
ip http server
5 REPLIES 5
Peter Paluch
Hall of Fame Cisco Employee
I am afraid that the detail of the debug is actually obscuring the real cause of the issue. Can you just run the debug ip packet 111 where 111 is an ACL defined as follows?
access-list 111 permit icmp any any
Also, can you enclose the output of the show ip route command?
Best regards,
Peter
dslice
Beginner
Are the addresses assigned by dhcp from the /24 listed under the dhcp command (172.27.100.0)? If so, you don't have them in a network statement so EIGRP won't advertise them. Could this be your issue?
Peter Paluch
Hi Don,
I believe this is not the case here: the OP uses the network 172.27.100.254 0.0.0.0 in his EIGRP configuration, with the 172.27.100.254/24 being the IP address of his Vlan27 SVI, so the network should be advertised properly.
Best regards,
Peter
glen.grant
Advisor
Try changing this " network 172.27.100.254 0.0.0.0  to this network 172.27.100.0 0.0.0.255  .
Yep, thanks.  I missed the SVI config and focused on the dhcp config.  The fact that the SVI has a /24 should cause that block to be advertised correctly.  I need to read for completeness.
