04-19-2018 08:32 AM - edited 03-08-2019 02:43 PM
I am trying to build a new network using a 3560G and a C3900, from the 3900 I can reach directly to the internet however after connecting the switch I cannot ping the router from the switch nor can I reach the internet..... I have posted both configs below. Please let me know what you think.
Router:
Building configuration...
Current configuration : 6724 bytes
! Last configuration change at 15:34:16 UTC Thu Apr 19 2018 by canadmin
version 15.5
hostname CR-B0007a-CS18
boot-start-marker
boot-end-marker
enable secret 5 $1$YtML$MNJnxH7HE0xkDkU2TlMfS.
aaa new-model
aaa authentication login default local
aaa session-id common
ethernet lmi ce
bsd-client server url https://cloudsso.cisco.com/as/token.oauth2
vlan ifdescr detail
ip dhcp excluded-address 172.16.0.3
ip dhcp excluded-address 172.16.0.2
ip dhcp excluded-address 172.16.3.255
ip dhcp excluded-address 172.16.0.1
ip dhcp excluded-address 172.16.0.1 172.16.0.3
ip dhcp pool ****
network 172.16.0.0 255.255.252.0
default-router 172.16.0.1
dns-server 208.67.222.222 208.67.220.220
domain-name CS18.mil
lease 30
no ip domain lookup
ip domain name ******
ip cef
no ipv6 cef
cts logging verbose
voice-card 0
license udi pid C3900-SPE150/K9 sn FOC16424LBF
license accept end user agreement
license boot module c3900 technology-package securityk9
license boot module c3900 technology-package datak9
hw-module pvdm 0/0
hw-module sm 1
hw-module sm 2
hw-module sm 3
hw-module sm 4
username ******** privilege 15 secret 5 $1$cS84$PmnbLUZ2j6IfGRmlSxA.n/
redundancy
interface Tunnel0
no ip address
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description connected to
ip address 192.24.111.2 255.255.255.240
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
interface GigabitEthernet0/1
description LAN
no ip address
ip nat inside
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/1.16
encapsulation dot1Q 16
ip address 172.16.0.3 255.255.252.0
ip nat inside
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
router ospf 10
network 172.16.0.0 0.0.3.255 area 0
router bgp 8888
bgp log-neighbor-changes
network 172.16.0.0 mask 255.255.252.0
ip default-gateway 172.16.0.1
ip forward-protocol nd
no ip http server
ip http authentication aaa
no ip http secure-server
ip nat inside source list 101 interface GigabitEthernet0/0 overload
ip default-network 172.16.0.0
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0
ip route 0.0.0.0 0.0.0.0 192.24.111.1
ip route 172.16.0.0 255.255.252.0 172.16.0.1
ip route 172.16.0.0 255.255.252.0 172.16.0.2
ip route 172.16.0.0 255.255.252.0 192.24.111.1
nls resp-timeout 1
cpd cr-id 1
access-list 101 permit ip 172.16.0.0 0.0.3.255 any
access-list 110 permit ip 172.16.0.0 0.0.3.255 any
access-list 111 deny udp any any eq domain
access-list 111 permit ip any any
access-list 111 permit udp any host 208.67.222.222 eq domain
access-list 111 permit udp any host 208.67.220.220 eq domain
control-plane
mgcp
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
gatekeeper
shutdown
line con 0
login authentication admins
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport output lat pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
session-timeout 15
access-class INSIDE_RANGE in
exec-timeout 15 0
transport input ssh
line vty 5 15
session-timeout 15
exec-timeout 15 0
transport input none
scheduler allocate 20000 1000
end
Switch:
CS-B007A-0003#sho run
Current configuration : 6012 bytes
version 12.2
no service pad
service password-encryption
service unsupported-transceiver
hostname CS-B007A-0003
boot-start-marker
boot-end-marker
enable secret 5 $1$xx.y$GfdfE.y/7SMvY3n6A4sm40
username ****** privilege 15 password 7 072C01626E0D144419
aaa new-model
system mtu routing 1500
vtp mode transparent
no ip subnet-zero
spanning-tree mode pvst
spanning-tree etherchannel guard misconfig
spanning-tree vlan 1-700 priority 8192
vlan internal allocation policy ascending
vlan 28
name MGMNT
vlan 99
name CS18
ip scp server enable
description AP2C31.24C2.3E20:GigabitEthernet0
switchport access vlan 99
switchport mode access
shutdown
spanning-tree portfast
spanning-tree bpduguard enable
interface GigabitEthernet0/3
interface GigabitEthernet0/4
interface GigabitEthernet0/5
interface GigabitEthernet0/6
interface GigabitEthernet0/7
interface GigabitEthernet0/8
interface GigabitEthernet0/9
interface GigabitEthernet0/10
interface GigabitEthernet0/11
interface GigabitEthernet0/12
interface GigabitEthernet0/13
interface GigabitEthernet0/14
interface GigabitEthernet0/15
interface GigabitEthernet0/16
interface GigabitEthernet0/17
interface GigabitEthernet0/18
interface GigabitEthernet0/19
interface GigabitEthernet0/20
interface GigabitEthernet0/21
interface GigabitEthernet0/22
interface GigabitEthernet0/23
interface GigabitEthernet0/24
description CR-B0007a-CS18:GigabitEthernet0/1
switchport trunk allowed vlan 1,28,99
switchport mode trunk
interface GigabitEthernet0/25
interface GigabitEthernet0/26
interface GigabitEthernet0/27
interface GigabitEthernet0/28
interface Vlan1
no ip address
no ip route-cache
shutdown
interface Vlan28
description MGMNT
ip address 10.10.10.2 255.255.255.252
no ip route-cache
interface Vlan99
description CS18
ip address 172.16.0.4 255.255.0.0
no ip route-cache
ip classless
no ip http server
ip sla enable reaction-alerts
snmp-server community CAN RO
snmp-server community CAIN RW
snmp-server location CAIN Building
alias exec sc show config
alias exec sis sho interfaces status
alias exec wm write mem
alias exec ct config term
line con 0
line vty 0 4
session-timeout 15
exec-timeout 15 0
transport input ssh
transport output ssh
line vty 5 15
session-timeout 15
exec-timeout 15 0
transport input ssh
ntp authenticate
event manager applet update-port-description
event neighbor-discovery interface regexp GigabitEthernet.* cdp add
action 1.0 cli command "enable"
action 2.0 cli command "config t"
action 3.0 cli command "interface $_nd_local_intf_name"
action 4.0 cli command "description $_nd_cdp_entry_name:$_nd_port_id"
end
Solved! Go to Solution.
04-19-2018 09:17 AM
ip nat inside
Your lan interface is configured with 172.16.0.3 but you are pointing the default gateway on the switch to 172.16.0.1
Also, the DHCP gateway is pointed to .1
04-19-2018 09:17 AM
ip nat inside
04-19-2018 09:54 AM
This worked! Also I had to change my dot1q to show the correct vlan id
04-19-2018 10:02 AM
Glad to know it is all working for you now.
