3560X 24P-S Power supplies Interchangeable?
gczyzewicz
Are the power supplies on these switches interchangeable?    I know the model numbers are the same with the exception of the /2 at the end if it. Customer wants it to have a dual power supply but not sure if I need to order a secondary powere supply or just another powere supplu from a spare switch.
Reza Sharifi
Yes, the 3560X series switches support redundant power supplies.  They are modular and interchangeable.
By default the switches come with one power supply, if you need a redundant one, you need to order it.
You can also have power supplies with different wattage in the same switch.
