3560X C3KX-NM-10G (SFP Link is not working)
ashraf1891
Dears
I am trying to connect tow 3560X using a fiber cable (MM)
I have C3KX-NM-10G in both switches (4 ports module)
I have GLC-SX-MM in both switches (connected to G1/1)
both switches are able to see & recognize the NM as well as the SFP
Fiber Cable is tested
Fiber Patch Cord also tested
both ports configured as a trunks
but also the switches are not able to see each other (even when I removed the trunks configuration from both of them)
CDP neibour is showing nothing
no links & no LED blink in any switch
both switches are running c3560e-universalk9-mz.122-55.SE3 IOS
NOTE: there is no any other configuration in both switches
your fast feed back is highly required & appreciated
Since it is easier to reverse SC type connectors try reversing one of them from the patch panel and test again.
You maybe connecting RX on one site to a TX on the other side.
5 Replies 5
Reza Sharifi
Can you try reversing your LC patch cord strand on one side of the cable and try again.  This module comes with 2 10Gig SFP+ and 2 regular SFP for 1Gig.  Can you make sure that both sides are connected to the proper 1Gig ports?
Dear Raza
Thanks for your prompts response
yes both sides are connected to the 1Gb Ports
for the cable reversing the switches are located in two differnt cabinets
where a fiber cable is terminated in a fiber patch panel (SC Connector) (both Cabinets)
& I am connecting both switches to the FPP using LC-SC fiber patch cord
NOTE: all fiber is very well tested
Thanks Raza
appreciated man
that was the problem
Glad to help Ashraf.
Thanks for the rating!
Reza
