3560x SFP issues
dayo1
I have 2 Cisco switch WS-C3560X-24P-S and WS-C3560X-48P-S connected via fibre( multimode of 440Meters) and working perfectly well currently with using 1G MM SR SFP.
My client has insisted on changing the PID on the switches from 1 G to 10G (C3KX-NM-10G).
My constrain is the fibre cable, its multimode (440meters) and we can’t change it.
So which 10G SFP+ would work with the 10G PID module.
I have attached the cable details.
thanks
Mak
3 Accepted Solutions
Marvin Rhoads
The Cisco SFP-10G-SR transceiver will work with that network module in a 3560X ( see compatibility matrix).
However it will probably not work reliably over a 440m multimode pair. The data sheet specifies 400m best case over the top quality (OM4-rated) multimode. It's not just optical power loss (the test results you shared look pretty good) but also characteristics such as modal bandwidth that govern this recommendation.
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
Just to add to Marvin's info, if your cable really is (according to your cable test report) 62.5 micron, 160 Mhz, 10g would only be spec good for 160 m.
Confirm what kind of cable you have, and using Marvin's reference link, you can determine spec distance for the optics.
Disclaimer
Posting
For under 500m, I would believe almost any SM would be fine.
Marvin Rhoads
Disclaimer
Posting
Thanks Mavrvin and Joseph.
I would ask for the cable to be changed to singlemode>
any suggestion on the best type of cable spec is welcomed.
hanks again
Disclaimer
Posting
