Join Customer Connection to register!
650
Neil Stewart
Beginner
3605X Ip Base Routed Ports
Hello
On a 3560X with IP Base are routed ports support ??
Cisco IOS Software, C3560E Software (C3560E-IPBASEK9-M), Version 12.2(55)SE4, RE
2 REPLIES 2
smehrnia
Rising star
it depends on your License Level if it is LAN Base routed ports are NOT supported, otherwise should be fine.
issue the show license detail / show ver and verify ur license level.
plz Rate if it helped.
Soroush.
Hope it Helps!
Soroush.
hobbe
Rising star
Yes routed ports are supported.
routing using physical ports is supported on IP Base.
also routing using SVI is also supported.
