3650 upgrade help
Will Pettit
I've just installed a stack of 3650 switches. I upgraded them to the stable version (16.3.5b). Now, I may not have done this correctly, but they have booted up ok.
I copied the bin file to flash on all switches, and then set the boot command to use the bin file. (boot system flash:xxxxx).
I still don't understand the difference between bundle and install mode, but the switches are in bundle mode:
Switch Ports Model SW Version SW Image Mode
* 1 52 WS-C3650-48PD 16.3.5b CAT3K_CAA-UNIVERSALK9 BUNDLE
2 52 WS-C3650-48PD 16.3.5b CAT3K_CAA-UNIVERSALK9 BUNDLE
3 52 WS-C3650-48PD 16.3.5b CAT3K_CAA-UNIVERSALK9 BUNDLE
4 52 WS-C3650-48PD 16.3.5b CAT3K_CAA-UNIVERSALK9 BUNDLE
5 52 WS-C3650-48PD 16.3.5b CAT3K_CAA-UNIVERSALK9 BUNDLE
Now I believe I should be using a command to install/expand the bin file, but can't get it it work.
If I use the request platform software package command I get this (when specifying the flash:filename):
--- Starting install local lock acquisition on switch 1 ---
Finished install local lock acquisition on switch 1
FAILED: switch local is not booted with provisioning file
Or this (when just specifying flash:)
nvram_config: No such file or directory
nvram_config_bkup: No such file or directory
FAILED: File /usr/binos/conf/memleak.tcl is corrupt or is not a valid package.
The "software expand"command doesn't even exist.
So, what do I need to do, or will the switches be quite happy just booting off the bin file?
Here's the dir flash:
Directory of flash:/
54216 -rw- 4737 Jul 11 2017 12:06:50 +01:00 packages.conf
54217 -rw- 481 Jan 19 2018 08:49:58 +00:00 bootloader_evt_handle.log
85185 drwx 4096 Jul 11 2017 12:13:30 +01:00 core
11 drwx 4096 Jul 11 2017 12:08:48 +01:00 .prst_sync
15489 drwx 4096 Jul 11 2017 12:08:51 +01:00 .rollback_timer
23233 drwx 4096 Jan 19 2018 08:50:11 +00:00 dc_profile_dir
23235 drwx 4096 Jul 11 2017 12:09:00 +01:00 gs_script
54218 -rw- 65301 Jan 19 2018 08:50:29 +00:00 memleak.tcl
30978 drwx 4096 Jul 11 2017 12:09:31 +01:00 .installer
54219 -rw- 2097152 Jan 22 2018 21:22:51 +00:00 nvram_config
54220 -rw- 35 Nov 30 2017 13:00:49 +00:00 pnp-tech-time
54221 -rw- 20857 Nov 30 2017 13:00:59 +00:00 pnp-tech-discovery-summary
54222 -rw- 8204 Dec 4 2017 14:31:54 +00:00 vlan.dat
54223 -rw- 539622403 Jan 18 2018 11:02:26 +00:00 cat3k_caa-universalk9.16.03.05b.SPA.bin
54224 -rw- 2097152 Jan 22 2018 21:22:51 +00:00 nvram_config_bkup
1621966848 bytes total (992219136 bytes free)
johnd2310
Level 8
Level 8
Have you tried cleaning up flash with "request platform software package clean switch all, copy the .bin file to flash and then expand using "request platform software package expand"?
John
**Please rate posts you find helpful**
5 Replies 5
johnd2310
Level 8
Level 8
John
Hi Johnd2310,
Could you please kindly explain to me what will be the issues, I'm facing with the IOS upgrading from  cat3k_caa-universalk9.16.09.05.SPA to cat3k_caa-universalk9.16.12.08.SPA.bin.
I just upgrade to the stable version (16.12.08) because of my current version is bug issues in Power Supply module status.
mm-stg-dmz-sw>show version
Cisco IOS XE Software, Version 16.09.05
mm-stg-dmz-sw>show environment power
SW PID Serial# Status Sys Pwr PoE Pwr Watts
1A PWR-C2-250WAC LIT19200406 OK Good n/a 250
1B PWR-C2-250WAC LIT22362AL2 Supply Failure Bad n/a 250
So, I decide to upgrade 16.12.08 and start the process Now, I may not have upgrade done this correctly, but they have booted up ok but version is the still old one.
Please kindly see the following step:
Method 1
(Step1.1)
#request platform software package clean switch all
mm-stg-dmz-sw#request platform software package clean switch all
This operation may take several minutes...
Running command on switch 1
Cleaning up unnecessary package files
No path specified, will use booted path consolidated:packages.conf
Cleaning sw/isos
Scanning boot directory for packages ... done.
Preparing packages list to delete ...
done.
The following files will be deleted:
[switch 1]:
/tmp/sw/isos/cat3k_caa-guestshell.16.09.05.SPA.pkg
/tmp/sw/isos/cat3k_caa-rpbase.16.09.05.SPA.pkg
/tmp/sw/isos/cat3k_caa-rpcore.16.09.05.SPA.pkg
/tmp/sw/isos/cat3k_caa-srdriver.16.09.05.SPA.pkg
/tmp/sw/isos/cat3k_caa-webui.16.09.05.SPA.pkg
/tmp/sw/isos/packages.conf
Do you want to proceed? [y/n]y
[switch 1]:
Deleting file consolidated:cat3k_caa-guestshell.16.09.05.SPA.pkg ... done.
Deleting file consolidated:cat3k_caa-rpbase.16.09.05.SPA.pkg ... done.
Deleting file consolidated:cat3k_caa-rpcore.16.09.05.SPA.pkg ... done.
Deleting file consolidated:cat3k_caa-srdriver.16.09.05.SPA.pkg ... done.
Deleting file consolidated:cat3k_caa-webui.16.09.05.SPA.pkg ... done.
Deleting file consolidated:packages.conf ... done.
SUCCESS: Files deleted.
mm-stg-dmz-sw#
(Step1.2)
#copy tftp: flash:cat3k_caa-universalk9.16.12.08.SPA.bin
mm-stg-dmz-sw#copy tftp: flash:
Address or name of remote host []? 192.168.255.2
Source filename []? cat3k_caa-universalk9.16.12.08.SPA.bin
Destination filename [cat3k_caa-universalk9.16.12.08.SPA.bin]?
Accessing tftp://192.168.255.2/cat3k_caa-universalk9.16.12.08.SPA.bin...
Loading cat3k_caa-universalk9.16.12.08.SPA.bin from 192.168.255.2 (via Vlan1): !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!OOO!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
[OK - 480570202 bytes]
480570202 bytes copied in 140.854 secs (3411832 bytes/sec)
mm-stg-dmz-sw#
(Step1.3)
#verify /md5 flash:cat3k_caa-universalk9.16.12.08.SPA.bin
mm-stg-dmz-sw#verify /md5 flash:cat3k_caa-universalk9.16.12.08.SPA.bin
.....................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................Done!
verify /md5 (flash:cat3k_caa-universalk9.16.12.08.SPA.bin) = 84af76eeb90008ab67aa27416cc652fb
(Checksum is the same vlaue of original .bin file)
mm-stg-dmz-sw#
(Step1.4)
#request platform software package install switch all file flash:cat3k_caa-universalk9.16.12.08.SPA.bin
mm-stg-dmz-sw#request platform software package install switch all file flash:cat3k_caa-universalk9.16.12.08.SPA.bin
mm-stg-dmz-sw#
mm-stg-dmz-sw#dir flash:
7746 -rw- 2097152 Jan 6 2023 15:10:17 +06:30 nvram_config
7747 -rw- 2097152 Jan 6 2023 15:10:17 +06:30 nvram_config_bkup
7751 -rw- 4774 Jan 6 2023 14:55:48 +06:30 packages.conf
7762 -rw- 4 Jan 6 2023 15:32:06 +06:30 .issu_loc_lock
7752 -rw- 19860092 Jan 6 2023 14:54:04 +06:30 cat3k_caa-guestshell.16.09.05.SPA.pkg
7793 -rw- 30896047 Jan 6 2023 14:54:33 +06:30 cat3k_caa-rpbase.16.09.05.SPA.pkg
7753 -rw- 373586548 Jan 6 2023 14:54:28 +06:30 cat3k_caa-rpcore.16.09.05.SPA.pkg
7791 -rw- 3136124 Jan 6 2023 14:54:31 +06:30 cat3k_caa-srdriver.16.09.05.SPA.pkg
7754 drwx 4096 Jan 6 2023 15:07:57 +06:30 .installer
7755 -rw- 888 Jan 6 2023 15:08:00 +06:30 bootloader_evt_handle.log
7756 drwx 4096 Dec 20 2019 11:51:19 +06:30 core
38721 drwx 4096 Dec 20 2019 11:56:57 +06:30 .prst_sync
54209 drwx 4096 Dec 20 2019 11:46:15 +06:30 .rollback_timer
61953 drwx 4096 Dec 20 2019 11:46:24 +06:30 gs_script
69697 drwx 4096 Jan 6 2023 15:08:11 +06:30 dc_profile_dir
7757 -rw- 123888 Jan 6 2023 15:08:35 +06:30 memleak.tcl
7758 -rw- 34 Jun 3 2020 13:28:10 +06:30 pnp-tech-time
7760 -rw- 77135 Jun 3 2020 13:28:13 +06:30 pnp-tech-discovery-summary
7761 -rw- 976 Jan 6 2023 15:10:10 +06:30 vlan.dat
7763 -rw- 22798968 Jan 6 2023 14:54:31 +06:30 cat3k_caa-webui.16.09.05.SPA.pkg
7749 -rw- 450283034 Jan 6 2023 15:03:44 +06:30 cat3k_caa-universalk9.16.09.05.SPA.bin
7764 drwx 4096 Jun 16 2020 16:23:59 +06:30 tech_support
7785 drwx 4096 Jun 16 2020 16:53:51 +06:30 .dbpersist
7786 -rw- 0 Jan 6 2023 15:10:07 +06:30 rdope_out.txt
7787 drwx 4096 Jun 16 2020 16:25:57 +06:30 onep
7788 -rw- 68 Jan 6 2023 15:10:20 +06:30 rdope.log
7750 -rw- 480570202 Jan 6 2023 15:29:23 +06:30 cat3k_caa-universalk9.16.12.08.SPA.bin
1621966848 bytes total (146157568 bytes free)
________________________________________________________________________________
Checking with show command
Technology-package Technology-package
Current Type Next reboot
lanbasek9 Smart License lanbasek9
None Subscription Smart License None
Smart Licensing Status: UNREGISTERED/EVAL EXPIRED
cisco WS-C3650-48TS (MIPS) processor (revision W0) with 832395K/6147K bytes of memory.
Processor board ID FDO2351M22S
1 Virtual Ethernet interface
52 Gigabit Ethernet interfaces
2048K bytes of non-volatile configuration memory.
4194304K bytes of physical memory.
250456K bytes of Crash Files at crashinfo:.
1609272K bytes of Flash at flash:.
0K bytes of WebUI ODM Files at webui:.
Base Ethernet MAC Address : 7c:31:0e:a9:8b:00
Motherboard Assembly Number : 73-15900-05
Motherboard Serial Number : FDO2351020D
Model Revision Number : W0
Motherboard Revision Number : A0
Model Number : WS-C3650-48TS
System Serial Number : FDO2351M22S
* 1 52 WS-C3650-48TS 16.9.5 CAT3K_CAA-UNIVERSALK9 BUNDLE
Configuration register is 0x102
mm-stg-dmz-sw#show boot
Switch 1
Current Boot Variables:
BOOT variable = flash:cat3k_caa-universalk9.16.09.05.SPA.bin;flash:packages.conf;flash:flash:cat3k_caa-universalk9.16.12.08.SPA.bin;flash:cat3k_caa-universalk9.16.12.08.SPA.bin;flash:packages.config;
Boot Variables on next reload:
Manual Boot = no
Enable Break = no
Boot Mode = DEVICE
iPXE Timeout = 0
mm-stg-dmz-sw#
_______________________________________________________________________________________________________________________________________
Method 2
Step1.1
#request platform software package expand switch all file flash:cat3k_caa-universalk9.16.12.08.SPA.bin
mm-stg-dmz-sw#request platform software package expand switch all file flash:cat3k_caa-universalk9.16.12.08.SPA.bin
[1]: Expanding file
[1]: Verifying parameters
[1]: Expanding superpackage flash:cat3k_caa-universalk9.16.12.08.SPA.bin
[1]: Validating package type
[1]: Note: Source file /flash/cat3k_caa-universalk9.16.12.08.SPA.bin will be removed automatically after completion.
[1]: Verifying package signatures
[1]: Signature verified on package cat3k_caa-guestshell.16.12.08.SPA.pkg
[1]: Signature verified on package cat3k_caa-webui.16.12.08.SPA.pkg
[1]: Signature verified on package cat3k_caa-rpcore.16.12.08.SPA.pkg
[1]: Signature verified on package cat3k_caa-srdriver.16.12.08.SPA.pkg
[1]: Signature verified on package cat3k_caa-rpbase.16.12.08.SPA.pkg
[1]: Copying package files
[1]: WARNING: A different version of provisioning file packages.conf already exists in flash:
[1]: WARNING: The provisioning file from the expanded bundle will be saved as
[1]: WARNING: flash:cat3k_caa-universalk9.16.12.08.SPA.conf
[1]: SUCCESS: Finished expanding all-in-one software package.
[1]: Finished expanding all-in-one software package in switch 1
mm-stg-dmz-sw#
Step1.2
(config)#boot system flash:cat3k_caa-universalk9.16.12.08.SPA.bin
(config)#boot system flash:packages.config
(config)#do wr
Building configuration...
[OK]
(config)#
Checking with the command
Switch 1
Manual Boot = no
Enable Break = no
Boot Mode = DEVICE
iPXE Timeout = 0
mm-stg-dmz-sw#
7797 -rw- 20097668 Jan 6 2023 15:36:52 +06:30 cat3k_caa-guestshell.16.12.08.SPA.pkg
7801 -rw- 32791733 Jan 6 2023 15:37:47 +06:30 cat3k_caa-rpbase.16.12.08.SPA.pkg
7799 -rw- 401236604 Jan 6 2023 15:37:43 +06:30 cat3k_caa-rpcore.16.12.08.SPA.pkg
7800 -rw- 3418756 Jan 6 2023 15:37:46 +06:30 cat3k_caa-srdriver.16.12.08.SPA.pkg
7796 -rw- 4780 Jan 6 2023 15:38:44 +06:30 cat3k_caa-universalk9.16.12.08.SPA.conf
7798 -rw- 23020160 Jan 6 2023 15:37:46 +06:30 cat3k_caa-webui.16.12.08.SPA.pkg
1621966848 bytes total (146128896 bytes free)
mm-stg-dmz-sw#
mm-stg-dmz-sw#
Thank in advance,
Pyie Phyo
Waiting for your replay thank you.
Leo Laohoo
The biggest difference between Install mode and Bundle mode is the amount of time it takes to boot up a switch or a stack.
So this is how it works:
1. In Bundle mode, when a switch boots up it will read the BIN file.
2. The switch or stack will then UNPACK (this bit is important) the BIN files into the temporary memory. (Emphasis on "temporary memory" because if the switch or stack reboots, the unpacked files go *poof!*.)
3. Once the files are unpacked, the switch or stack then finds correct file and boots the package files in the order they were meant to be done.
Now that's Bundle mode. In Install mode, the switch or stack boots up and loads the package file. That's it.
In Install mode, the switch or stack completely omits or bypass step 2.
So this is why it's highly recommended for the switch or stack to be loaded in Install mode.
Someone might want to ask this: What happens if the stack is mixed with Install & Bundle mode?
My answer is this: The Install mode will finish the boot-up first and the Bundle mode will be there when the cows come home.
Someone might also want to be "nasty" and as this: What happens if my switch master is in Bundle mode and the rest of the stack is in Install mode?
My answer to this is this: The switch master will never become "master".
I hope this makes sense.
Thanks guys. Ok, the "request platform software package expand ...." command worked.
My only remaining question is the boot command. It's currently set to boot system flash:xxxx.bin (which doesn't exist now). So is it a case of changing that to boot system flash:packages.conf and giving it a reload?
Yes, after expanding set the boot variable using boot system flash:packages.conf
John
