The Cisco 3702 or 3602 Aironet AP has four antennas. I was wondering if I can set one antenna as transmitter and the other one as receiver?
As far as I know, this should be doable and is called infrastructure mode(?). But my question is that how this can be done. Is it a way to do it through the Cisco GUI, or it has to be the Command-Line Interface? And if it has to be wiith CLI, what are the commands to do it?
I found something in here, but not sure if it works in my case, cause I have 4 antennas at the corners.
http://www.cisco.com/c/en/us/td/docs/wireless/access_point/12-4_10b_JA/command/reference/cr2410b/cr12410b-chap2.html#wp3103507
Thanks for your help.
