3745 & NM-ESW-16 Issues
3745 Running 12.3(14)T7. I have a NM-ESW-16 (16-Port FE Network Module w/ Inline Power). I created a VLAN interface, DHCP Scope. Connected clients show up in the DHCP lease table, but clients do not get an address, the client ARP table shows an all-zeros MAC address for the routers VLAN interface. I do not want to enable the 3745 FE0/1 or 0/0 interface as this will be a stand-alone network. Anyhow, I had this working on a previos IOS release with another config. I must be missing something as the connected clients cannot ping the VLAN interface - even with a static address. Here's a snippet of the config ... the Unity Express NM interface config is related as it's tied to the VLAN interface:
ip dhcp excluded-address 10.1.10.1 10.1.10.10
ip dhcp pool VOICE
network 10.1.10.0 255.255.255.0
default-router 10.1.10.1
option 150 ip 10.1.10.1
interface FastEthernet3/0 (0 through 15 all the same)
switchport access vlan 100
spanning-tree portfast
interface Vlan1
no ip address
interface Vlan100
ip address 10.1.10.1 255.255.255.0
interface Service-Engine2/0
ip unnumbered Vlan100
service-module ip address 10.1.10.2 255.255.255.0
service-module ip default-gateway 10.1.10.1
ip classless
ip route 10.1.10.2 255.255.255.255 Service-Engine2/0
8 Replies 8
glen.grant
Did you actually create vlan 100 in the vlan database ? Won't work unless you do .
conf t
vlan database
vlan 100
exit
Sorry - yes, I did.
VLAN ISL Id: 100
Media Type: Ethernet
VLAN 802.10 Id: 100100
State: Operational
MTU: 1500
amit-singh
Level 8
Level 8
What does " show interface vlan 100 " tells you.
Also " show vlan "
-amit singh
Router#show interface vlan 100
Vlan100 is up, line protocol is up
Hardware is EtherSVI, address is 000d.ede3.d670 (bia 000d.ede3.d670)
Internet address is 10.1.10.1/24
MTU 1500 bytes, BW 100000 Kbit, DLY 1000000 usec,
Last input 00:00:19, output never, output hang never
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 306
Queueing strategy: fifo
Output queue: 0/40 (size/max)
324 packets input, 112710 bytes, 0 no buffer
Received 324 broadcasts, 0 runts, 0 giants, 0 throttles
0 packets output, 0 bytes, 0 underruns
0 output errors, 1 interface resets
Router#
"Show VLAN" isn't valid, though here's the "VLAN DATABASE - SHOW CURRENT" for VLAN 100
VLAN ISL Id: 100
State: Operational
MTU: 1500
amit-singh
Level 8
Level 8
Why you have given, ip unnumbered under the serice-engine interface when you already have an IP assign to it. Could you try taking this command out of that interface, just for testing purpose and see if that works.
Let us know. Also try to paste the whole router confoguration.
-amit singh
Amit,
Thanks. Actually I did remove the Service Engine to make sure it wasn't affecting anything.
I erased the config and started over ... here's the new basic config:
version 12.3
hostname Router
boot-start-marker
boot-end-marker
no logging buffered
no aaa new-model
resource policy
no network-clock-participate slot 1
no network-clock-participate wic 1
ip subnet-zero
ip cef
no ip dhcp use vrf connected
ip dhcp pool VOICE
no ftp-server write-enable
voice-card 1
no dspfarm
controller T1 0/0
framing sf
linecode ami
interface FastEthernet0/0
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet3/1
interface FastEthernet3/2
interface FastEthernet3/3
interface FastEthernet3/4
interface FastEthernet3/5
interface FastEthernet3/6
interface FastEthernet3/7
interface FastEthernet3/8
interface FastEthernet3/9
interface FastEthernet3/10
interface FastEthernet3/11
interface FastEthernet3/12
interface FastEthernet3/13
interface FastEthernet3/14
interface FastEthernet3/15
interface FastEthernet4/0
interface FastEthernet4/1
interface FastEthernet4/2
interface FastEthernet4/3
interface FastEthernet4/4
interface FastEthernet4/5
interface FastEthernet4/6
interface FastEthernet4/7
interface FastEthernet4/8
interface FastEthernet4/9
interface FastEthernet4/10
interface FastEthernet4/11
interface FastEthernet4/12
interface FastEthernet4/13
interface FastEthernet4/14
interface FastEthernet4/15
interface Vlan1
no ip address
shutdown
interface Vlan100
ip classless
ip http server
control-plane
voice-port 1/0/0
voice-port 1/0/1
voice-port 1/1/0
voice-port 1/1/1
line con 0
line aux 0
line vty 0 4
Thanks!
Might try doing a debug dhcp and see if that sheds any light on what may be going on .
Problem solved; I had added a second NM-ESW-16 around the time of my upgrade (and when the issue started). Turns out dual NM-ESW-16 modules without the use of the external GB link cable causes a corruption in the VLAN routing (a bug of sorts), according to TAC. I removed the second NM-ESW-16 and all worked fine. Thanks all...
