3750-48PS-S does not power up No Lights, but Fans work
mprostka1
Community Member
I  have a 3750-48P when plugged in has fans that spin up, but no lights on the front of the chassis.  Does this mean the power supply is bad?  If its bad, why do the fans power up?
Mike
krun_shah
Level 7
Level 7
You need to console into the switch and check if ios is loaded or not
krun_shah
Level 7
Level 7
There is no console output, forgot to mention that.
